Question about Singer 4411 Sewing Machine
How to oil, where to drop oil? - Singer 4411 Sewing Machine
  • Singer Master
  • 12,487 Answers
If the manual does not provide instructions for oiling, then you probably shouldn't.
Posted on Apr 26, 2015
What type of oil to use on a empisal d 270 and how put the oil
sewing machine oil ( from a supermarket or sewing shop)and just a few drops in the oil holes
Jun 20, 2016 | Sewing Machines
Where should I clean and oil an unidentified sewing machine?
cleaning out any machine is good , as most don't get \done get done to often , id be cautious on oiling a machine and only use a oil spec'd by the mfg. as some oils can soften and damage gears and such on some machines , oils should always be used sparingly and not left to drip down inside to points unknown , me id prefer to use caning wax for lubrication, as it never runs from where you put it like oils will
Feb 17, 2016 | Sewing Machines
How do I oil my sewing machine to keep it properly maintained?
the oil points will., be highlighted in your user manual
only put 1 or 2 drops in each hole but no more
do not oil anywhere else
Jan 23, 2016 | Sewing Machines
How to oil 1958 singer sewing machine
Your Singer is an oldie but goodie! As such, it needs oil, frequently. There are probably some oil ports that appear as small holes where an oil spout would fit. Apply only 1-2 drops of oil each spot. Use ONLY fresh, good quality oil (not the old stuff from Grandma's sewing box, 3-in-1, WD-40, or cooking oil).
The other thing you can do is gently hand-rotate the handwheel and watch where metal parts rub against other metal parts and apply a drop or two of oil. Do NOT oil any plastic parts, rubber, leather.
Be sure to apply a drop or two to the bobbin race where the bobbin turns. By all, means, don't skip the selector lever or dial mechanisms as those usually require oil to move freely.
After oiling, gently hand rotate your machine and if it is still sticky, then you need to hit it again. If things are stubborn, you can direct heated air from a handheld hair dryer into the mechanics.
Lots of patience, elbow grease, and good oil will generally get your machine in fine working condition.
Oct 21, 2015 | Singer Sewing Machines
How do I oil mysewing machine? It's a janome excel 5024
You don't oil this type of machine. It's not like an old one that needs oiled every two hours of sewing. You can place 1 drop of oil under the bobbin case in the center to the hook. (One drop of oil on the wick in the center of the magnetic ring.
Feb 26, 2015 | Janome Sewing Machines
How to oil a kenmore sewing machine 158.19411
Remove bobbin and presser foot, and tip machine on its side onto a towel. Remove bottom plate w/ screw driver. Oil moving parts with Zoom Sewing Machine oil, one drop, and lube up gears that show dryness with Singer lubricant in tube. One drop oil top of needle bar, one drop on oscillating hook in race shuttle. Jimmy
Apr 06, 2012 | Kenmore Sewing Machines
White quilters star 1780 is running slow, how do I fix it? Have already cleaned feed dog and shuttle, what else can I do?
You can send out to repair to have it lubricated & oiled, or you can do this yourself. Not recommended though if you have pets or kids where you are working on machine. Remove needle, thread, bobbin. There are screws underneath. Don't lose them! One drop good quality oil on moving parts so lay machine back on a towel, remove screws, keep foot pedal up on table so you don't accidentally hot it with your foot. All gears that are not greasy get a very small dollop of lubricant (Singer makes a good one comes in red &white tube). All parts moving get the oe drop oil. Put plate back on, firmly tighten screws. Never lube or oil plastic parts! A drop of oil any metal screw located on top of machine. Lift machine up and if tip can be removed, you can check moving parts needing oil there and replace lid. If front section opens--left of needle bar--open it up and oil moving parts..I usually just apply one drop oil to TOP of needle bar Close lid. Put one drop oil on shuttle hook bottom left. Never oil tension discs. Run machine with scrap of fabric to get her nice and smooth sailing. If motor sounds like it's running heavy after that, take in for service, but unless motor needs replacement, you should see noticeable improvement immediately. Good luck and hope this helps! Jimmy Remove screws on top
Apr 04, 2012 | Sewing Machines
Where do I put oil drops in my janone 2049, sometimes it gets stuck
Put just one drop of good quality sewing machine oil on moving parts. You can set machine back gently on towel. Remove bottom plate by removing each screw. Set each screw in a bowl so they don't roll anywhere. I have 30 years experience, so I personally run my machines when oiling so I can observe the parts that move. I d on't recommend this if you have pets & children, and leave that up to you! You should probably unplug machine and just look for anything that is NOT a gear, and just put one drop oil on those parts. Singer lubricant should go on actual gears, but ONLY if not already "greasy". Reassemble bottom plate. If your machine left front section opens up, one drop on those moving parts, and smear one drop of oil on hook. One drop top of needle bar. Do NOT oil or lube plastic parts. Never use cooking oil or bath oil; it will coagulate & damage machine. Always run machine with a scrap of fabric for a bit to distribute oil and to make sure excess does not get on your good fabric. Then rethread machine and replace bobbin and put fresh needle in. Yes, removed thread, bobbin, and needle BEFORE you lube & oil. Did this help? Best of days and nights sewing, Jimmy
Mar 31, 2012 | Sewing Machines
Trying to figure out where to oil my old White 265 machine. the manual only talks about how to oil the bobbin shuttle.
Hi. The rule of thumb is to put one drop (just one drop, that's all it takes) of sewing machine oil wherever two pieces of metal move against each other. You can also look for the oil ports(see tip on where to look for oil ports and for a photo, see www.robbiesews.blogspot.com). Your machine may also have small oil holes in the sewing machine housing, so put one drop of sewing machine oil in each of those.
Please use only sewing machine oil to oil your machine.
Hope this helps!
Robbie
Apr 13, 2010 | Sewing Machines
My old Kenmore sewing machine makes a loud squealing noise.
It sounds as if your machine needs a little oiling. If you have a clear machine oil (not 3 in 1). place a drop in the bobbin case area and if you will notice, you will see small holes on the bed and on the top of the machine. place a drop of oil into each of these holes. If you can take the top and bottom covers off, you can put a drop of oil every where you see a hole..some of the machines actually have the oil holes painted a red color. Also place a drop at the handwheel as well. Just remember when oiling, less is better. After oiling, run for a few minutes, if you feel it still needs a litte more, do the same, one drop at a time. After this, if you machine sets for a while, oil just before starting to sew, that way when you put the machine away the oil has been worked through and it should help prevent the squeaking when starting up again.
Mar 01, 2009 | Kenmore 15208 Mechanical Sewing Machine
Singer 4411 Sewing Machine Logo
220 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
