Question about Sewing Machines
How do I fix easyfile error code 3123 - Sewing Machines
Does the new home 3123 need oiling ?
the user manual for the machine will show oil points and how often to do it. If you do not have a user manual go to google and type in new home 3123 and download the manuals from the site.
Aug 03, 2013 | New Home MX-3123 Computerized Sewing...
HOW DO YOU FIX THE STITCH WIDTH POSITION CONTROLL BAR, WHEN IT WONT MOVE AND IT IS STUCK AT ZERO?
it would be a good idea to have the machine checked to see
if the stitch width control bar is damaged or some other part is
Jun 09, 2012 | New Home MX-3123 Computerized Sewing...
Where is the indicator to move from one pattern to another on the New Home mx 3123 ? The red light is on behind pattern 1.... How do you move it? Thanks!
it is the big knob on the right hand side below the bigger wheel that moves the needle bar up and down. You have to turn it clockwise to move the indicator to the right all the way to # 13 for straight stitch. It will make a loud click with every move. Make sure the needle is raised up because it jumps back and forth as you move the dial. When you make a buttonhole using pattern 1, when one finishes you turn the dial to #2 then back to #1 to reset the program. I have one right in front of me if you have more questions. This is an AWESOME machine and should never wear out :o)
Jan 15, 2011 | New Home MX-3123 Computerized Sewing...
My janome sewing machine isn't locking the thread
If u r new to using sewing machines please take some ones help who knows using any machine. You obviously are not fixing correctly. It should click in right place and the machine shd be able pull the thread before u begin stitching.
Oct 16, 2009 | Sewing Machines
How do I load the bobbin
what machine do you have??
Jun 24, 2009 | Janome MyExcel 3123
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
