Question about Garden
Countax 30 rider manual
Grass collector drive belt from engine
    Master:
  • 428 Answers
Howdie sounds like you need to go down to the Dealer And ask them Nicely hand them some cash for the Manual and then your on your Way Done
Posted on Apr 25, 2015
I need parts for a T1200 Westwood ride on lawn mower,cant find
Westwood Parts ' eBay
www.ebay.co.uk/bhp/westwood-parts
Find great deals on eBay for Westwood Parts in Lawnmower Parts and Accessories. Shop with ... COUNTAX WESTWOOD Parts Garden Tractor Breaking For Parts ... Westwood Countax T1200 Ignition On Off Starter Switch Repl Part No/ 1649.
BREAKING FOR SPARES WESTWOOD T1200 1400 RIDE ON ... - eBay
www.ebay.co.uk > Garden & Patio > Lawnmowers > Lawnmower Parts & Accessories £0.99 - ‎In stock
Breaking for parts - Westwood T1200, 1400 & 1600 years 1987-92. ... Ignition Starter Switch Fits Some WESTWOOD T1200 Ride On Lawnmower 1649.
Westwood Tractor Spares - Largest Genuine Spare Parts Dealer
www.westwoodtractorspares.co.uk/ Genuine Westwood spare parts dealer. Huge range of parts in stock for all models including T Series, S Series, X Series, W Series, V20/50 Series. We ship ...
Westwood T1200 Ride on Tractor Mower Parts
www.japgmowers.co.uk/westwood-t1200-ride-on-tractor-mower-parts-56-c.asp Mower Deck Parts Parts, spares and accessories for Westwood T1200 Ride on ... Westwood S1200, T1100, T1200 PGC Sweeper Grass Collector Drive V Belt ...
Westwood Parts - Buyamower.co.uk
www.buyamower.co.uk/category/westwood-parts.aspx Genuine Westwood Spare Parts. ... At Buyamower, we are Westwood main dealers and as such we stock thousands of ... Westwood Lawn Tractor Blades.
Westwood Parts Manual : Beltingonline.com, Supplier of power ...
www.beltingonline.com/garden...belts.../westwood.../westwood-parts-manual-850/ Beltingonline.com : Westwood Parts Manual - Rubber Timing Belts Garden Machinery ... Westwood Tractors Parts lists for ALL Models by year of manufacture ...
parts for T1200 Westwood ride on lawn mower Google Search
Apr 01, 2017 | Garden
Drive Disc on bottom of engine intermittently freezes and engine stalls out and remains frozen for some time 17.5 HP B&S on Snapper 3317523BVE 7800254 - Snapper 33 Rear-Engine Rider
check for grass and other material that is wrapped around the shaft above the disc and acting like a brake
when it is clear check for failing bearings on the disc shaft
May 14, 2016 | Snapper Garden
My poulan pro rider mower runs but won't move
Hi Kristy:
If you're lucky, the drive belt has come off.
If you're not so lucky, the drive belt has broken.
Most machines are similar to this.........
With the motor OFF, find a comfortable way to lie down and look under the machine. There will be a pulley under the motor, and a v-belt should be loosely around it.
The belt will go toward the back of the machine,past one or 2 idlers, and then around another pulley at drive.
If the belt is off any of the pulleys, put it back on.
Withe the motor OFF (I said that before but it's important), have a helper step on the Forward/Reverse pedals and watch to see what happens to the drive belt pulleys.
If the drive belt does not tighten up, try to figure out why. When you do, you'll be back cutting grass.
Jun 25, 2015 | Poulan Garden
Twin bag grass collector for a 42inch
Ken - if you locate the Model number on the lawnmower, you can look up the bags here: Snapper Parts
Feb 26, 2014 | Snapper 28"/33" Twin Bag Grass Collector...
Rider loses power after mowing for 30 - 45 minutes. Gets to a point, it won't climb a small incline. Engine sounds good & the deck runs fine. Just won't go.
Hi, the hydrostatic drive is most likely over heating. Remove the battery and battery carrier, from here you can clean all grass and debris from the hydro cooling fins and fan. Hope this helps, regards Phil.
Jun 01, 2011 | John Deere Garden
I have a single cylinder Ranch King riding lawn mower. Model # 133K6796205. Bought in 1993. I need to know what type of oil to put in it? I am also having a problem with the grass collector. Even if...
Hello You can use straight 30 w oil most engine manufactures agree for summer equipment now for winter where it gets cold like in a snow blower the request you to use 5-W30. As far as your grass collector check your blades #1 to see if they are the correct blades for that mower. #2 yes the engine will overheat as the clumped of grass will slow down the blades causing more load on the engine.This is not a uncommon problem wet or damp grass will clump up even if you do not have a grass collector,it will stick under the deck again causing problems.Hopefully this helps.
Thanks Ben
May 02, 2011 | Garden
Grass collector not filling
HMM .. if the grass is not going into the collector, I would look under the deck and see if there is something blocking the chute to the bag.
Please vote !!
May 12, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
I have a MTD yard machine ride on mower 42inch(Black beauty) i was cutting grass yesterday and heard a cluck noise and the machine stop moving while the motor was still running. the speed paddle went loose...
Sounds to me like you busted a main drive belt not making any noise from the engine ? just stopped moving if this is correct then you probably looking @ around 45-50 dollars for new belt advanced auto has alot of belts for riding mowers they can assist you with replacing the correct size belt for you mtd.also they can be inexpensive as well on the price of the belts.
Jan 27, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Husqvarna ct 135 mower,when attempting to engage cutters with lever beside steering wheel the alarm sounds and then the engine cuts out
Hi Janet,
its the warning button on the grass collector. If the button is not pressed in fully, the machine thinks that the grass collector is off, and therefore stops the engine. I had the same problem. If you take the grass collector off, you will see the button on the top left side of the back of the mower. It is covered by a strip of black plastic that slots over it.
To fix the problem my first solution was to tape a washer onto the plastic strip, thereby ensuring that the button is pressed fully in when the grass collector is on. When I got tired of the washer continually falling out, I used a screw to jam the button in. You should be aware though, that with the second method you will be able to engage the cutters with the grass box removed. Potentially a small child (with long arms) could put his/her arm down the shute and chop fingers off etc. I have no kids, and thereby feel safe.
Jul 16, 2009 | Husqvarna Garden
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
