SOURCE: Hotpoint ultima wf860
hi, i have the same machine..i have a feeling it does this annually to make you call an engineer. to reset it do this; hold the 'start' button until all lights display, then press 'start' again. hold the 'start' and 'on/off' button together until it reads d-end or d-off. it doesnt always work 1st time so keep trying, good luck x
SOURCE: wf860 message f-07
Unfortunately, the heater relay is not a replaceable part, as it is part of the main PCB, and these are not repairable, f
SOURCE: How do I replace Drum paddle on Hotpoint WF860 washing machine
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
SOURCE: Hotpoint WF860 pump obstruction. How do I get to pump?
Remove lower rear panel of washer.
Locate and remove the large black hose fastened to the bottom of the drum.
Remove and clean the plastic filter inside the hose.
Remove the hose onto the pump, and check for blockage or obstruction here and in the pump.
Thisn should the problem.
Good luck.
Testimonial: "Worked a treat. 15p and some kids things under the plastic ball in the filter and half a hair grip in the pump. Thanks for your help!"
SOURCE: test
Hi i have a hotpoint wd 860 washer dryer the display is showing f 08 heater relay cannot be activated.can you please tell me how i can fix this problem myself.Thank You
