Question about Hitachi DS18DVF3 18v 1/2-in Driver Drill Kit with Flashlight Reconditioned
Hitachi UC 18YG charger Pilot light flashing all the time
Hi there, I have exactly this problem. Pilot lamp is out till put the battery in, then the light flashes 0.5 seconds on and off. Never stays on or go off continually. I checked the fuses are in tact, no burn marks, however some residue on the mirror?silver plates which I cleaned of but didn't make difference. The batteries do charge though, but if left over night without charger or use they discharge totally. Do i need new batteries or is there something on with the charger?
    Sergeant:
  • 236 Answers
Http://www.hitachi-tools.ch/media/wysiwyg/Explosionszeichnungen/UC18YK.pdfhagbye
Posted on Apr 25, 2015
Testimonial: "Thanks, I will do some troubleshooting on the circuitry"
  • Willem Kruger
    Willem Kruger Apr 25, 2015
    Thanks, do you know where can I buy the PRINTED CIRCUIT BOARD 230V-240V only?
I have batteries and charger uc 18yrl will they fit most Hitachi drills that are a few year's old??
probably not
older chargers were made for ni-cad batteries and now they are li- ion batteries which require a different charger
to distinguish the difference , most manufacturers changed the battery pack design
talk with a battery retailer or a good tool shop or appliance repair shop
Sep 20, 2016 | Hitachi Drills
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Problem with hitachi chargers
I live by hitachi, one of the good things about it is lowes will exchange them as long as you have a receipt and it's under 30 days. If not chargers are not very expensive, or you can send it back for repairs. I have 10 of those combo packs and never had a problem with a single one, for you to get 2 is a freak accident.
Dec 14, 2013 | Hitachi WH18DLP4 18Volt Lithium Ion...
Hitachi cordless drill charger not working
The various rates of flashing are error indicator codes and should be explained on the charger case. They are for the condition of the battery's though and not the charger. It sounds like the charger itself is bad. Can you return it for a replacement? Is it still in Warranty? For whats its worth, I went from Milwaukee tools to Bosch to De Walt before being satisfied with performance. I hope this helps.
Dec 14, 2013 | Hitachi UC18YRL Universal Charger for...
My Hitachi UC 18YG charger has flashing (not steady) red light when batteries inserted. Both batteries (12 volt EB1215S) no longer charge up to full charge. Is problem with batteries or charger? If...
I've followed HELP2DIY's advice
4 #3 phillips screws will open the case
there are actually 2 fuses 15A glass type which i can see that both wires through the visible glass are intact
the rest of the resistors and capacitators & what-not on the circuit board/ breadboard also show no signs of any electrical burns
i've also have 2 replacement batteries just to test this charger & still blinking
any others found a way to fix this "made in china" product?
i also went to AzOn for similar reviews with no real answer but to just buy another one
Aug 15, 2013 | Hitachi 12v 3/8" Driver Drill Kit with...
How do i remove the black box on my screen
don't have the original remote control, I used the time warner control, I just reprogramed to control my tv without the cable box, I put the volume all the way up in the tv, then down to zero, and at the same time I hold the 0 key in the remote control, after that the screen said lamp has been reset to zero, I repeated this step because a lamp red light stayed on, after this only the power green light only stays, when installing the new lamp make sure is all the way in, you can use the white out to mark exactly where you have to push or put in the new lamp, it may not been all the way in, hope this help someone !!
Jan 18, 2012 | Panasonic PT-50LC13 50" Rear Projection...
Ferguson ldvd200 portable dvd player - my battery has been on charge for a number of hours and the chg light flashes - is there something wrong or should I wait longer?
i had this problem my self flashing charger light but not charging i fixed this by sripping the battery pack unsoldering the positive and negative from the small circuit board geting a 10v charger and directly charging the batery for a few secs checked the battery with a volt meter to insure that there was a charge in it then reasembled then run the player till it was flat put on charge did this a few times this to cycle the battery each time i did this it took more of a charge untill it was back to normal note the light should stay on not flash hope this helps
Aug 21, 2011 | Audio Players & Recorders
We have bought a battery charger HB 1206S DC6V - 12V 6AMP, but it does not state what is the state of charge do the lightes go out when it has reached changed state or light up please help
Product Detail Model No.: HB-1206S
The item is used for charging 6V-12V lead-acid batteries
Max Charging Current: 6A
AC Power Input: 64W
Output: 6/12V DC 3. 52A
Batteries Capacities: 15AHR-80AHR
Unit Packing: Colorful box
Dimension: 18cm x 10cm x 20cm
G. W. / N. W.: 1. 85KG/1. 75KG
Certifications: GS, CE, BS, ROHS, SAA
Main functions:
(1) The HB-1206S battery charger has the features of convenient operations, reliable safety and high performance.
(2) During charging, if turn up overload, the battery charger will keep itself at normal current and normal voltage with its self-automatic protecting function.
(3) If being short circuit, the battery charger will switch off itself, and turn normal after one or two minutes.
(4) The output current of the battery charger is very stationary, so it can protect the battery charger very well. It only costs 3 or 4 hours to fully charge the batteries.
(5) Indication of charging: the battery charger has 6 pilot lamps. The more pilot lamps shining, the less electric quantity is. The charging process finishes when all the pilot lamps go out.
(6) The battery charger can be switched between 6V and 12V, so it can charge for 6V and 12V accumulators. You can select 6V or 12V according to your own needs.
(7)The operations are very convenient: Put the red clip to the positive pole of the accumulator which indicated "+", and put the black clip to the negative pole of the accumulator which indicated "-", then plug in power source, the accumulator will be charged.
Aug 02, 2011 | GPS
Hitachi DS18DVF3 18v 1/2-in Driver Drill Kit with Flashlight Reconditioned Logo
454 people viewed this question
Top Hitachi Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Hitachi Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
