Question about Refrigerators
Scandinova fridge freezer FF6745D. About an hour ago (after defrosting/cleaning) the red warning light had been on (not flashing) manual doesn't mention anything. Anyone know what this means?
  • Refrigerators Master
  • 5,323 Answers
No but defrost cycle should last about a half hour
Posted on May 07, 2015
SOURCE: CPCA240FFK orange (super) light keeps flashing
I had the same problem on 27th December 2007, orange light flashing. I telephoned the Warrranty company who informed me to switch it off for 10 to 15 minutes and the light should go out.
I did this and it worked however temperature with mine is fluctuating as I have bought a thermometer and am currently waiting for an Engineer to call (he's due on the 7th January). Hope this solution is useful, it may solve your problem.
Posted on Jan 03, 2008
Master_Tech
  • 770 Answers
SOURCE: fridge doesn't get cold enough
you have either a Defrost heater / a defrost timer/ or a defrost bi-metal that is bad. if you post your model # i can look it up and show you how to set it into defrost to see if the heaters are ok
Since you replaced the timer already that leaves two things you need to check set it into defrost if you know how and remove the panel in the back wall of the freezer you should see the heater(s) are on if not check pwr 120vac at the heaters if 0 volts the bi-metal is bad
Posted on Feb 22, 2008
  • 87 Answers
SOURCE: whirlpool a class freezer
Red Light : Alarm high temperature.
Amber Light : Fast freeze function (ie ignores thermostat and keeps unit freezing all the time).
Green light: mains power.
If you have lost temperature on a freezer it is usually a major fault either the compressor has failed or you have lost charge (possibly the start relay). If you are able to get to the rear of the unit and check the compressor, if it is hot then it is more likely a major fault. A good fridge guy can normally tell the problem within a short time of inspecting the unit. Sorry to not sound hopeful. Good luck.
Posted on Mar 13, 2008
MATRIX_MMX
  • 209 Answers
SOURCE: zanussi fridge freezer
dear plapy
This to me sounds as if either your gas is not circulating through the refrigeration system, or you have a problem with thermostat. If you have recently physically moved the fridge and then powered the appliance up on the mains without letting the gas settle, then you could have damaged the fridge. And there is not really a lot you can do about this, unless you want to call out a refrigeration engineer to re-gas your fridge and assess the circulation of the pumped cold air flow.
Other problems aside of gas and thermostat could be associated with the pump (if your model has one fitted), and with this in mind, i have a good mind to have a look at the SIOS (spares, Information, Ordering, System) disc for zanussi vendored models and then get back to you once i have a further solution for you. However, I will need your make and model of zanussi fridge, so if you have this to hand it will be most appreciated. In the sad event that you dont have the paperwork/ manual for the fridge, then you can find the manufacturers model details on the rear of the fridge. however, when you move the fridge, you will need to let it stand again before powering up the unit after repair, and this should be done for a period of no less than 24 hrs, and no less than 28hrs if your appliance is a fridge freezer combi.
So once again, when i recieve further information regarding your make and model of refrigerator, then i will be able to fully investigate this matter for you, and try to come up with your most appropriate solution..
In the mean time, i bid you take care, and hope to hear from you soon
Yours sincerely
oz
Posted on Apr 11, 2008
SOURCE: HOTPOINT FFA70 FRIDGE FREEZER
I had this problem and it was fixed relatively easily. Get everything out of your fridge freezer and switch it off overnight to allow it to defrost.
In the bottom freezer compartment there is a panel behind the draws which you can remove but you will need a special tool from a DIY shop. Its like an allen key, but with a star shaped end.
When I got the panel off I found that the filament was covered thick with ice even though it had been off for hours. No wonder it wasn't working properly. I melted this with a hairdryer. You want to take your time with this as you could easily damage the freezer if you try chipping the ice out.
Freezer works perfectly now and is very quiet.
Posted on Dec 05, 2009
Fridge isn't getting cold
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jan 12, 2013 | Washing Machines
Hi I have an old american style 4 door zanussi fridge freezer recently the freezer defrosted itself and the red warning light is now flashing since. The fridge above is still working fine. Sorry don&#
As far as I can tell the fridge and freezer are on two separate compressers so if one gos down the opposite will still work. As for the red light I can only think if the unit is not working that the defrost is stuck open, or the compresser relay I stuck open, or the compresser is shor, or t-stat is stuck open od there may be a drain pan sensor and it is full and not evaporating. Sorry that's all I got
Sep 06, 2012 | Refrigerators
Freezer stays frozen, but refrigerator doesn't stay cold
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Sep 13, 2011 | Magic Chef Refrigerators
Flashing light re temperature in fridge jenn air model
Your freezer may be a fan cooled system. Make sure that nothing is crammed up against the fan grill as this stops the air flow and probably causes the red light warning
Mar 28, 2010 | Refrigerators
Flashing red light
red light flashing on servis fridge freezer
Mar 19, 2009 | Freezers
The freezer is not cold enough - ice-cream is soggy! despite putting it on coldest; and the red warning light is permanently on. And I can't find the booklet. Help!
If the coils are frozen up already,putting the setting to coldest is the worst thing to do.Even though inconvenient,try unplugging for substantial amount of time (3 or 4 hours) to allow the coils to defrost.Be prepared for water leakage during this time.If this seems to work , chances are the defrost timer or defrost heating element are bad and the problem will recur after a week or two.
Jan 17, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Have a hotpoint rsf60 fridge/freezer,noticed over temp red light on, defrosted as ice buid up on top shelf of freezer.light still on red temp set at 3/4 ?
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Jul 01, 2008 | Hotpoint Refrigerators
Jun 02, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
173 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
