Question about Ricoh Office Equipment & Supplies
Ricoh aficio 1075 code error sc 321 - Ricoh Office Equipment & Supplies
  • Ricoh Master
  • 3,960 Answers
This code comes back as: SC-321 Laser write problem, BCU board, EX-IPU board
This repair (if repairable) is in the hands of a technician. Nothing you can do to solve this one.
Posted on Apr 25, 2015
3 Suggested Answers
M2Tech1
  • 313 Answers
SOURCE: Error code, SC 547 on a Ricoh Aficio 1075
have you tried sc reset through the service mode and then turn off .. you can get to this by pressing yellow clear button then 107 then hold down the cancel stop button..wait for the screen to change then go to mode 5 and you need to arrow down to sp 5 810 sc reset execute turn off the copier and try turning on to see if it clears.. if not the ac board maybe defective caused by a power surge or static down the line..
Posted on Aug 05, 2009
SOURCE: tengo una fotocopiadora ricoh aficio
Limpie o cambie si es necesario el thermistor de la unidad fusora, luego presione total clear key tecla amarilla, introduzca 107 y mantenga presionada la tecla clear stop tecla naranja, mas de tres segundos hasta que el tablero cambie a sertvicio, apague y encienda el interruptor principal y listo...
Buena suerte...
Posted on Dec 07, 2009
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Sc 536 error code
Ol? tudo bem! o erro funcional (SC 536) trata-se de um cooler ou do sensor de temperatura que parou de funcionar levando o sistema a parar de funcionar por medida de seguran?a, infelizmente trata-se de um daqueles problemas que s? a autorizada resolve.
Jan 14, 2013 | Ricoh Toner for Aficio 1060, 1075, 2051,...
Trouble code 1075, how to repair? Thank you
i think your sc code is wrong, on your display panel it will show u the sc code?
Sep 06, 2010 | Ricoh Aficio 450 Copier
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
Aug 05, 2009 | Office Equipment & Supplies
446 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
