What is the problem if the machine makes a horrible grating sound when the drum is turning?
The cycle continues but the drum appears to be struggling to turn. There is no error code showing up.
  • Washing Mach... Master
  • 1,205 Answers
Good morning to you
If you have the manual look under the heading troubleshoot.
the link here helps you find your manual, if your own is not handy.
it could be that the ball bearings are broken.
This sounds like a serious problem contact a repair man as soon as possible. Do not use the machine until you have found out what is wrong with it.
kolbrun
https://manualsonline.com/
Posted on Apr 25, 2015
My Bosch logixx 9 is struggling to spin. When it comes to the spin part of the cycle the drum churns backwards and forwards, like it is distributing the washing evenly around the drum. However this can go...
brushes are easy replacement.......just make sure you get correct 1`s there are 3 or 4 differt types you need motor make................then look at the brush holders...... these will be white, black, or brown. held in by 2 screws...or a clip at the side of the holder......then just buy replacements............total time about half an hour........
cheers
Mar 25, 2011 | Washing Machines
1. Too much vibration on spin cycle even on
loud rumbling noise when running, unplug it, take the rear cover off and remove the drive belt. Then turn the inner drum by hand. If there is a grating noise, the bearings will almost certainly need replacing.
drain port take out and give a very good clean with warm water and makes sure all the holes are cleaned right through
Mar 09, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Horrible scraping noice when drum rotates
YOU WILL NEED TO REMOVE DOOR SEALING RUBBER WHICH SEALS THE TWO HALFS OF THE DRUM THIS WILL ALOW YOU TO REMOVE SAID OBJECT
Dec 28, 2009 | Washing Machines
Hi my machine wma20 makes noise when it start spining. the noise is horrible as lots of bricks are moving along the cycle? how to fix it plz? i have already open it but i dont know how to open the drum...
Remove belt and turn drum by hand, if it is noisy, or feels rough, then main drum bearings have failed.
This a major repair, and not one I would recommend that you do yourself, it involves a complete stripdown, and is quite expensive.
Please rate my solution.
Thanks.
Aug 12, 2009 | Washing Machines
The washer makes terrible noise when it spins
do you mean up and down? or when you turn the drum like you are spinning it?if it makes a sound like an airplane takeing off or a train rolling through your house. you have a bad bearing which is a very exspensive repair.
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hoover Washer/Dryer WM120 : Dryer function - drum not turning
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
treru
Jan 25, 2009 | Hoover H120M Front Load Washer / Dryer
Hotpoint WD62 Drum wont turn
tilt the machine backwards. with a multimeter, check continuity across the brushes - if open circuit then brushes need to be replaced
Oct 02, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Aquarius WF 320 Noisy Drum
Could be your bearings for sure. And if you have been using the machine while the racket continued......you could be ruining you axle as well. So make sure your axle is fine before you change your bearings.......
Oct 26, 2006 | Hotpoint Aquarius WF220 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
