Question about Photography
How to reset new lock code - Photography
Forgot phone lock password
HI if you forget the phone lock code then try default code like 0000 or 1234 to reset your mobile .If it didn't help to reset your phone .Then visit Unlocking4free.com here they generate master reset code for some Nokia and Alcatel mobile models at free of cost .You can use this code and reset your phone and then assign new security code.
May 27, 2013 | Cell Phones
I need to reset my phone, but im locked out. How do I reset it if it's locked and I don't know the code?
What is your mobile and model ?
If you forgot the security code you have to reset you mobile. Its the only way to use your mobile again. After resetting you can enter a new security code again.
If you use nokia or alcatel mobile means just visit here Simpleunlocking.com for the master reset code service and get the reset code........
May 14, 2012 | Cell Phones
How do I get a manual for YL88 electronic lock
Okay Guyz n' Galz...Finally I solved this by lot of iterations. I have YL-88, YL-68 and D77 Digital locks. They are all made by Yili from China with buttons placed circularly. Warning, to reset it might not work on button placed in square pattern (YL-99).
Default master code is 0123# all the locks mentioned above.
Now to reset the master code, press and hold the reset button(red) for 2-5 secs on the battery pack, and remove one battery. Release reset button. Give 5 to 10 secs. Then press and hold reset button first, put back the battery into it.
Now the lock is reset to factory default. i.e., 0123#.
Warning: Make sure the default works before you close the door and lock.
Now to apply new master code: Enter default 0123# and wait till the sound is gone and the light is still lit. Start your new code starting with '0' and end with * key (not the # key). It will beep twice. Your new master code is ready to use. Now if it does not beep twice. Try from the begining with default code.
Enjoy
Your'
Problem solver!
Jan 04, 2012 | RTO Chrome YL88 Keyless Electronic Digital...
How to reset codes on a yl88 keyless electronic digital door lock lost the manual and cannot work it have no emergency module
Enjoy
Your'
Problem solver!
Oct 02, 2011 | RTO Chrome YL88 Keyless Electronic Digital...
Any four digit code works no matter how many times you reset code. how do you erase all codes and start fresh?
How do I change the access code (and delete my old code) on my Powerbolt 1000?
The steps below are to change your access code to a new code. This will also remove any previous codes stored in the Powerbolt's memory.
pb1000programbutton
  1. Manually put the bolt in the extended (lock) position. Press the PROGRAM button once, enter your new 4 - 8 digit code and then press the LOCK button.
  2. Press the PROGRAM button twice, enter the same new code and then press the LOCK button once.
  3. Press the PROGRAM button three times, enter the same new code and then press LOCK once.
If your old code still remains in the unit, you will need to perform a hard reset of the unit. To perform a hard reset of the unit, remove all four batteries and leave them out for 1 hour. After the hour has passed, you may re-enter the batteries.
I'd recommend replacing the batteries if you haven't done so yet.
Good luck--and please provide feedback if this helps!
Aug 21, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
My cellphone is locked n i can unlocked please help me :{
Its locked to security code or Network Lock,it locked to Network means get the Network UNLOCK CODE from here
theunlockspot.com and Unlock it,It locked to security code means get the default code from service provider and reset it,you can also use the master reset code to reset Phone from security lock and password Lock,get the master reset code for Nokia and Alcatel Mobile Phones there itself and reset from security lock.
Aug 15, 2011 | Cell Phones
How can i unlock my sim, it has been locked.
It Locked to security code or password lock? You can get the master reset code and reset the phone from security lock...It locked to network means use the network unlock code to Unlock the Sim Network lock,Specify the Model and brand?
You can get the Network Unlock code and Master reset code at here
Unlocking4free.com and Unlock it or reset it...You can try default code as 0000 or 1234 for Nokia to unlock from security lock ,if not works get the master reset code and reset it.
Aug 12, 2011 | Computers & Internet
I need to reset the code
Jun 22, 2011 | Weiser Lock GED1460X3BR Lifetime Polished...
I forgot my lock code in my nokia 6120c
Try master reset codes for your phone here http://www.prounlocking.com/nokia-dct-master-code-service/rs8wp10/ by the way you can reset the security code and change new
Dec 03, 2010 | Nokia 6120
I need master reset code for v-lock ws 65"
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Jan 23, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Photography Logo
218 people viewed this question
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
