Question about Dryers
When i turn on the fan of the aircon i need to push the fan blade before it rotates. what is the problem of this? how can we fix this problem
    Top Expert:
  • Dryers Master
  • 44,387 Answers
This will be a problem with the board and needs a technician to fix/replace.
Posted on Apr 25, 2015
Soleus Air FSH-40G fan would not start. The bad seems harder to rotate. what could have gone wrong? How to fix?
First unplug the fan for safety. Next add a couple drops of motor oil on the shaft that turns with the fan blade. Tip the fan blade at about a 45 degree angle when adding the motor oil. Spin the blade by hand at that same angle to allow the motor oil to flow down the shaft, inside where you cannot see the shaft. It should start turning by hand a lot easier now.
Sep 06, 2015 | Soleus Dryers
How does it matter which direction condensor fan turns
Yes. The fan is designed to draw air through the condensing unit to expel heat generated by compression and heat exchange in the refrigeration system. If the fan is running the wrong way, heat will not be disipated correctly and the unit will not operate efficiently. You could end up damaging the system.
Aug 18, 2014 | Dometic Rooftop RV Air Conditioner
Once you turn on aircon with fan with high speed, the air blown doesn't get cold even after a while. The fan makes some wierd high pitch sound as if like metal against each other. The fan stops once in a...
Your AC needs a good overhauling as the fan seems struck on the bearings or the blades are rubbing the sides. Also the compressor fails to cool as there can be low gas, low pumping pressure or a blocked condenser.
You need to remove clean the coils and lubricate the fan to be set back. Check the capacitor to the fan and compressor as a low value will reduce the speed and so reduce pumping pressure.
Apr 11, 2011 | Heating & Cooling
Fan won't reverse to counter clockwise
I had a hampton bay fan that absolutely did not have a revers switch on the fan anywhere! MOST fans bought today will reverse. I was not about to give up. I scoured the net for an answer and could not find anything to help. I did however find a comment somewhere that said it could be done internally. After about six months I decided to search again (now). Nothing... so I started playing with the remote and the wall switch and Shazaam! I figured it out on my hampton bay fan. Turn the fan on high... Turn the wall switch off.... wait until the fan is pretty slow in rotation... hold the HI button on the remote.... Turn the switch back on. IT Worked for me! Hope this helps someone. SparqMark
Aug 10, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Can I use a clockwise rotation Fan Clutch in place of a counter clockwise fan clutch , What are the differance and what can it hurt,,.
u can if you have the blade to go with it, cooling fan blades either push or pull but not both.
Jul 07, 2009 | 1999 BMW 323 Series
Fan blade won't turn, but will slowly turn if given a push. What is the problem? How do I fix it?
Replace the fan motor capacitor. If that does not correct the problem you will have to replace the fan motor.
May 12, 2009 | Goodman CLQ36AR49 Air Conditioner
Scraping sound inside casablanca stealth fan
You need a new flywheel. Go here: http://www.bostonplus.com/parts.html#flywheel
Jan 24, 2009 | Casablanca Fan Stealth 3211T Ceiling
Aircon makes a noise
might be coming from the following....
1) fan motor- bearings or bushings need replacement
2) fan shroud has deformed due to age and is obstructing the fan rotation
3) motor control circuit contacts are dirty or defective hence have less voltage running thru thus an underpowered system
Jan 01, 2009 | LG Electronic Window Air Conditioner
Fan blades
their is problem in push! change your fan push! then the wings are rotate
Jun 29, 2008 | Marvin 1210 Floor / Box Fan
Ceiling fan
There's a rubber circle that is the damper between the blades and the motor shaft that rotates. The circle has spokes connecting the outer ring, which the blades screw into, to the inner ring which attaches to the shaft and holds it. If the spokes break you get the symptoms you describe, motor hums but no rotation, but blades can turn manually if you hand turn them them. If this is the case you need to remove and replace the blade mounting ring/damper. (About 25 bucks online)
Apr 27, 2006 | Hunter Sontera 52" Ceiling Fan with...
Dryers Logo
63 people viewed this question
Top Dryers Experts
