Question about New Balance 1400 Treadmill
It shows ERR4 on a new balance 1400 treadmill. How do I fix this
4 Suggested Answers
  • 4 Answers
SOURCE: Our New Balance 1400 treadmill starts to slow
Please check wheel setting ( When calipration)
sada
Posted on Jul 13, 2009
Joed911
  • 4338 Answers
SOURCE: I have a New Balance 1400 Treadmill. I turns on
I have a Horizon Treadmill that had the same error, it turned out to be a calibration using the adjustments on the logic board. The New Balance does not show the calibration procedure, but you can call 800-497-5831 for service. Hopefully it is still under warranty.
Posted on Jan 26, 2011
maxtreadmill
  • 832 Answers
SOURCE: My New Balance 1400 treadmill
It sound like either the wire harness that goes to upper console is bad or the Motor Control Board that has the 5v or 12v is missing. Here is the bad news New Balance is out of the Treadmill business and do not carry these items anymore. Their might be one other thing you might try is that if this unit was not maintain as owner's manual suggests, then the fuse may have open up. You must open the motor shroud locate motor control board find the fuse, if you have a multi meter check continuity of the fuse if open replace it with the same value ( maybe 15amps). Plug unit in if the display returns then proceed to do the prescribe maintenance in owner's hopefully that the belt and deck was not damaged when it went dead.
Good Luck!!
Max
Posted on May 09, 2011
I have a New Balance 1400. How do you do a hard reset on it?
In almost all treadmill error 1 denotes the speed sensor error.
In you case I suspect there is some variation in the alignment of the speed sensor. May it moved away from the magnet Which is fixed on the rotating wheel. Try to make it closer as much as it can, be sure not to keep a small distance .hope it will solve the problem.
If you wish to get some more details about treadmill repair and service then check the following link.
http://electro-medical.blogspot.com/
Sep 26, 2016 | New Balance 1400 Treadmill
I have an older NB 1400 Treadmill (7 years old)
Motor controls for New Balance can be found by doing a Google search on Treadmill Analyzer and look for the MCB List page of repairs offered :-)
Jul 15, 2014 | New Balance 1400 Treadmill
My New Balance 1400 treadmill recently stopped working. There is power going to the motor. The lights are on but there is no power to the display. nothing lights up and none of eh controls work. The...
Good Luck!!
Max
May 09, 2011 | New Balance 1400 Treadmill
I have a NB 1400 Treadmill that is shutting down and giving the E1 code in the display. I see that there is a solution that says it is a sensor code. What sensor and what is the solution to fix the...
The sensor is one that records the movement or speed of the belt, some machines are located next to the engine flywheel. and other off the front roller pulley on the left side exactly. physical form depends on the manufacturer and the only solution is to buy, where somewhere distributing or selling accessories for treadmills
Sep 08, 2010 | New Balance 1400 Treadmill
Have a new balance 1400 treadmill. when i power it on the screen goes blue and it will not doing anything.
Does the screen turn on (blue) and then go black or does it stay blue? Mine has a similar problem where when the main power switch is flipped, it lights up, shows the initialization screen, then goes dark. Pressing any button on the console does nothing. I opened the console up and suspect one programmable microcontroller is bad. I'm going to see if I can get that part from FitnessQuest instead of replacing the whole board.
Aug 28, 2010 | New Balance 1400 Treadmill
The belt on my New Balance 1400 has become kinked up. I tried adjusting it by loosening it up, straightening it out, then tightening it back up, but it kinks up again. Before it kinked up for the first...
Unfortunately once the belt has a crease that all she wrote. Belt replacement is the next step.Call Fitness Quest they are the makers of your treadmill @ 1-800-321-9236
Jul 31, 2010 | New Balance 1400 Treadmill
I havea new balance 1400 I keep getting two error codes on my screen the first is E1 and then A E3 on elevation.?
Hi This is dinesh here,
The E1 Error is for the sensor problem and the E3 error is for the IC crasg in the machine...
Jul 22, 2010 | New Balance 1400 Treadmill
What kind of lube do i use
There is a special wax designed for treadmills proform part number 219167.at sears parts online Or treadmilldoctor.com has lube kits you can purchase from them.
Jul 29, 2009 | New Balance 1400 Treadmill
New Balance 1400 Treadmill Logo
95 people viewed this question
Top New Balance Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
L Pfaff
L Pfaff
Are you a New Balance Exercise and Fitnes Expert? Answer questions, earn points and help others
