Question about Altec Lansing BXR1121 2 Speakers
AWM 2464 VW-ISC 80C 300 W E214382 28AWG KAI TAT AWM I A 90C 300V 28AWG FTI............... The pins in the cable to the right speaker is broken.... where i can get it repaired or where i can get a spare????????????
Awm 2896 80c vw 1 E305734
I have exactly the same problem. It seems that there is nowhere online. I can find touchpad ribbons but not power ones.
If you had any luck please help me also
Nov 17, 2013 | ASUS Computers & Internet
How do i fix a flat ribbon cable awm 20624? it only has 1 pin broken
Check most of the ribbon cable have their two ends detachable. Replace the entire ribbon is the solution to the broken pin. Attempt to fix the cable may cause short circuit on the cable which will impact on the equipment if used.
Sep 29, 2010 | Computers & Internet
Cable Wenxin E230343 AWM 20798 80C 60v VW 1H
Contact Wexin direct, very helpful, just google the cable name and details and they will pop up
Mar 03, 2010 | Televison & Video
I am looking for a webcam driver please
The markings you describe are not related to the webcam, they relate to the cord itself. AWM 2464 80 oC 300V means Appliance Wiring Material type 2464, temperature rating 80 degrees, voltage rating 300 volts.
You can use Windows to help identify your webcam so you can find the correct driver, to do this plug in your webcam and turn it on, then go to device manager, if Windows was unable to install a driver automaticaly you should see the webcam listed in device manager with a yellow icon by it and it may say unknown device or the webcam may be in a catagory called unknown devices, once you have located it in device manager double click on it to bring up its properties, click the details tab and use the drop down menu in details to select hardware id's. Copy the hardware id to google search and you should get results there to help you identify your webcam and locate the correct driver.
Jan 12, 2010 | HP Webcam
Looking for replacement cable for jvc home theatre.. the only thing i have is the cable with me now awm e225738 style 2464 vw -1sc
Ask JVC for part number QAM0381-002 (this is normaly for DD8 or DD3 models. It is 5 m. long). JVC France Customer Service
Nov 24, 2008 | JVC Audio Players & Recorders
INSTALL A WEB CAM
i can't install my web cam and i need to..
can u help me please?
Jan 18, 2008 | GE EasyCam Webcam
In Search Of The IDE Ribbon
Its a Hard drive. Why not see how long you need one and go to a puter store and get a replacement Hdd cable. Does not have to be a ribbon cable. Good Luck Please do not forget to rate this thread.
Oct 17, 2006 | Panasonic DMR-E80H DVD Recorder
Altec Lansing BXR1121 2 Speakers Logo
473 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
