Question about Home
The hinge on our soft close toilet seat on Parisi nahm wall flush toilet has broken. Cannot get under like on an ordinary toilet. How do I remove broken hinge and replace seat? Thank you.
kachbibi1
  • 979 Answers
SOURCE: How to tighten the hinges on a slow close toilet seat?
You don't want to overtighten since you could crack the porcelain. Are your rubber washers in good shape? This will help. You should be able to do this w/out doing any damage.
Posted on Jan 28, 2009
tsolinac
  • 28 Answers
SOURCE: Toilet seat hinges are loosening
Most generic seats have a thin plastic cap that snaps in place over the bolt heads just behind the seat. Normally they hinge backwards so carefully pop them open with a flat blade screwdriver. Sometimes you can tighten the bolts from underneath even.
Posted on Feb 27, 2010
heatman101
  • 43501 Answers
SOURCE: The toilet see is not
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Posted on Aug 29, 2010
  • 118 Answers
SOURCE: I have just brought a
the mechanism may be broken. call the manufacturer it should have a lifetime warranty.
Posted on Dec 05, 2010
SOURCE: nylon bolts on Eljer soft close seat that hold
Most hardware stores would have these nylon bolts -- also, Home Depot and the like.
Charlie
Posted on Jul 16, 2011
How do I remove toilet seat?Appears to be 2 bolts with top access only.
rak soft close toilet seat - YouTube
? 0:31
https://www.youtube.com/watch?v=RLssM9BYJjg
Oct 9, 2013 - Uploaded by Paul Hooker
rak soft close toilet seat. ... How to remove and change a Villeroy & Boch toilet seat with top fixings ...
Rak Series 600 Back To Wall Toilet - YouTube
Nov 29, 2015 | Home
How do I get a toilet seat off if it doesn't have the screws under the seat and it also doesn't have the little flap things at the back of the seat with the screws under.
You will have to remove the pan to access seat fitment as sounds like a back to wall lol.
Alternatively cut through bolts holding on seat with a hacksaw blade and go to plumb center and buy a new seat with drop through fasteners
Sep 01, 2015 | Home
How do i fix a soft closing toilet seat
some of these have bolts under seat...you turn seat to left or right by grabbing while in closed position...this will release the seat from the holding bolts...then tighten the bolts....then reset the seat on bolts then lock down by doing the opposite as you took off...
Oct 10, 2014 | Home
How to remove a parisi nahm soft close toilet seat
there is 1 of two ways.
easy way is have a look where the seat mounts to the toilet and see if there is a cover that you can lift up and find a screw under it. there might be 2 pins on each side of the toilet seat hinge that you depress for you to remove the seat from the hinges to access the screws.
failing the above method the toilet has to be removed to access the screws / wingnuts from under neath. send closer picture of hinge on seat if you like.
Jul 12, 2014 | Toto Aquia II Dual Flush Toilet
Soft close toilet seat
do not think there is a fix...just replace the seat...
Jun 22, 2014 | Home
I have a Jika Mio soft close seat with a loose hinge which I cannot reach due to closeness of pan to wall!!
The top lid of my soft close toilet seat slams shut.How do I adjust Jiko Mio close coupled toilet.
Mar 27, 2010 | Villeroy & Boch Home
One of the softclose buffers on the Subway toilet seat has pulled
Each soft close 'Barrel' is handed - one left - one right. (One is grey - the other white).
Most soft close errors occur because the seat hinges come loose. When this happen, the barrels slightly pull-out of the seat. (There are silver discs on the barrels - These should be tight against the seat).
Once the barrels become loose the first thing that happens is the top cover won't soft close - but the seat still does.
To rectify - puch both barrels tighly into fitting and tighten the hinges. (See below).
To tighen the seat hinges you need to get a flat headed screwdriver underneath the chrome round hinge cover - and 'flick off'. Underneath is a X head screw which id also hexagonal. You can either tighen both by spanner - or screw driver. (sometimes these can be tricky - but it will come off).
If both cover AND seat do not soft close AND the barrel silver discs are firmly located against the seat - the barrel has probably broken.
If so - spare parts can be obtained here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
Jun 15, 2009 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
I have a Toto saftclose toilet seat but it doesnt close softly!!!
If it is something you can adjust, there will be an area on the hing. There also may be a small cover over the adjustment screw.
Apr 01, 2009 | Toto Round Maple SoftClose Toilet Seat...
Dec 22, 2008 | Toto Aquia II Dual Flush Toilet
Home Logo
164 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
