Question about Teac Audio Players & Recorders
Teac cd receiver cr-h225 volume control failure
3 Suggested Answers
jerryg50
  • 1667 Answers
SOURCE: Receiver Problem.
The following is if you feel comfortable to work on your reciever.
Before replacing the volume control, go to any local electronics parts supplier and get some circuit control contact cleaner.
Disconnnect the AC cord of the reciever, open the reciever and get access to where you can spray some of this in to the control to clean it. After using the cleaner rotate the control back and forth at least 20 to thirty times.
It is recomended to not get any of the cleaner on the circuit boards if possible. With normal electronics there is no danger, but it can promote the accumulation of surface dust over time.
If the cleaner does not do the job, then you will have to replace the control. For this you would have to order the original part from the manufacture, unless you can retrofit a generic type varible resistor in to the set. The problem with retrofiting is that you will have to be able to match the resistance, characteristics, and mechancial mounting and fitting the knobs.
For the cleaning of the control or for replacing it, I would suggest having a service tech do this for you unless you are experienced in this type of work. It would be safer for you, and there would be less risk of damaging something.
Jerry G.
Posted on Apr 13, 2008
  • 10 Answers
SOURCE: how do i connect TEAC CR H225 and iPod
I think all you have to do it use the while usb to ipod conector to conect the ipod, from the looks of a picture of the teac it has USB input, failing that read the user manual or technical details off the internet, that the first thing i would do.
Posted on Mar 22, 2010
Volume control on teac crh250
Make sure the volume knob is tightened to the volume potentiometer shaft via the set screw on the knob itself.
Jun 12, 2016 | Teac Audio Players & Recorders
Why does my Teac receiver only light up the volume, then shut back off?
Your receiver has developed an internal short circuit and the unit is shutting down to prevent further damage. You might want to check the power supply for problems since it is a hard working area and prone to failure.
Sep 01, 2015 | Teac AG-V8060 Receiver
Looking for spare remote control,or universal remote that would be suitable.
go to e-bay and search for remote for teac cr-h255
you will probably get new ones or 2nd hand units
Jul 22, 2015 | Teac Audio Players & Recorders
Can I connect an active speaker to the Teac AG d7900 output
http://produto.mercadolivre.com.br/MLB-184407791-av-digital-home-theater-receiver-teac-ag-d7900-_JM
It would have helped to know something morwe about the 'active' speaker.I imagine its manual would tell you what it needs for input.
Active speakers are usually designed to be driven by volume-controlled Line Level inputs. This receiver has none except for the Subwoofer PRE Output.
Aug 17, 2011 | Teac AG-D7900 Receiver
Teac AG-V8060 Receiver No sound. If I turn up the volume all the way I get a whisper of sound from the speakers.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Jun 04, 2011 | Teac AG-V8060 Receiver
I own a TEAC AG V1020 receiver. One channel keeps cutting out then and back in after a few minutes. When I give the volume control a quick twist louder then back down, the channel returns for a few minutes...
Turn it off and vigorously operate all mechanical controls throughout their ranges many times with special attention paid to any Tape Monitor or other rarely-used controls.
Jan 10, 2011 | Teac AG-V8060 Receiver
How do i connect TEAC CR H225 and iPod
Mar 21, 2010 | Audio Players & Recorders
Audio volume control problem
Have exactly the same issue, no cure however
Mar 16, 2009 | Audio Players & Recorders
TURNTABLE PROBLEM
You have a VERY nice turntable! TWO quick questions: 1) How do you define "minimal" volume? It is not NECESSARILY unusual that your turntable / receiver combination will have lower volume than your tuner, CD or DVD player. What happens when you CRANK IT UP?! Don't worry about the position of the volume control! 2)Are you changing the turntables output settings via the switch under the platter? Please post a reply and we'll go to the next step! Note: Ceramic cartridges are pretty much extinct. They were strictly low-end, low-cost, low-fidelity devices used in cheap audio systems of "yesteryear". Have you ever seen a BSR or Garrard turntable? Or your grandad's Magnavox Console Stereo? THAT'S where you'd find a ceramic cartridge!
Jul 12, 2007 | Teac AG-V1050 Receiver
65 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
