Question about Garden
Turn the key & it just clicks . Checked the seat, handles & brake relays & they were fine . Checked the ignition key switch & it was fine . PTO clicks normally . All fuses were fine . At a loss
Has 140 hours . Needs a new drive belt
  • 3,519 Answers
Hi Wes:
First, make sure the battery is charged and all the terminals and connections are clean. Give it a try. If it still just clicks,
Jump the big terminals on the solenoid. If it starts, the solenoid needs to be replaced. If it doesn`t, let us know and we;ll think some more. Odds are you`ll be cutting grass.
Posted on Apr 25, 2015
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
Blows a fuse every time I engage the cutting deck
it is not supposed to start unless some one is in the seat
now for your problem, if engaging the cutter deck blows a fuse then check the wiring for a wire that is cut or shorting out on a lever that moves when the cutter is engaged
Apr 18, 2015 | Garden
I have a 917.289700 craftsman tractor - 24 hp 42 in deck. I cannot get it to start. When I turn the key I don't get any power, even to the LED Hours display. I have checked the battery and it is fully...
It sounds very much like the ignition switch check that you first have power to the ignition switch using a meter. Turn on switch and check there is power coming out again using a meter. if there is no power going to the ignition switch check wiring for breaks also make sure you check all micro switches
Jun 03, 2014 | Craftsman 20 Hp 42" Deck Lawn Tractor
Ignition acting funky
With many of these Tractors, as part of the safety B.S., much of the electronics run through the PTO switch. Power to the ignition runs through the PTO.
Jan 04, 2014 | Craftsman Garden
Leplease explainon the safety switchs on mtd models660-679 work? I beleave my model is an intek twin. thank you
The safety switch beneath the seat is only one part of the several interconnecting safety features of the modern riding mower. If the system works properly, you must be seated for the mower deck to operate. The tractor will continue running with the Power Take Off disengaged if the parking brake is set before the operator leaves the seat.The seat switch consists of two electrical contacts normally separated by an air gap. A spring creates an open space between the two contacts. Mounted between two plates, the switch's spring compresses under the weight of the person sitting in the operator seat and completes an electrical circuit. With the switch closed the tractor's ignition system can be switched on with the ignition key. If the operator stands, the spring forces the gap open and interrupts the electrical ignition circuit. The safety circuit allows the riding mower motor to continue running if the PTO is not engaged. When the parking brake is set a second switch in electrical parallel with the OPS closes. This bypasses the safety switch under the seat. If the operator stands, the parking brake switch still completes the ignition circuit.The mower blade turns only when the PTO engages. If the operator should leave the seat with the blade turning and under power, injuries could result. The mower blade would even continue spinning at full power if the machine overturned. To prevent this type of accident, engaging the PTO deactivates a connection in the original circuit and completes a second circuit in series with the OPS switch.
If the operator leaves the seat with the PTO engaged, the ignition interrupts and the machine stops. Until the PTO is off, no combination of settings will restart the mower.
Apr 05, 2011 | Garden
I have a Craftsman GT 5000 Garden Tractor, 25 HP, 48" mower. I recently changed the mower belt and it was working fine for about 2 weeks. The last time I mowed, the mower blades suddenly stopped and I...
Depending on your engine.. Briggs and Stratton or Kohler there are 2 different seat switches that are used to power the PTO clutch. The seat switch can cause the PTO clutch to disengage anytime there is not at least 70 lbs in the seat.
The PTO drive wiring has a 30 amp fuse in it. If by chance a stick went through the belt and tore off the wires at the PTO clutch (Common failure) even after you repair the broken wire you still need to replace the fuse.
Check the PTO clearance gap. It should be 0.012 dis-engaged. Any other value and the clutch will not work correctly. Adjust the clutch if necessary.
There is a 2 pin Pigtail just off of the PTO Clutch that you need to check for voltage at the connector. Probe the back of the wires if you can and your looking for 12V DC under the following conditions.
BRAKE ON or tied down
KEY ON
SEAT (Briggs and Stratton engine only) Someone needs to be sitting on the seat.
Then Pull the PTO Switch out. You should hear the PTO Clutch CLICK. If you hear the click there is no need to check voltage. The PTO switch is a multi function switch and it is quite possible the PTO switch failed. I doubt that the PTO Clutch has failed as they normally give you some kind of noisy indication that they are failing and don't fail straight away.
So.. In short
Check PTO Switch (Red wires) to usually red or brown thru the switch
Check 30 amp fuse
Check PTO clutch wires near PTO clutch (They get torn from something traveling through the pulley)
Check PTO clutch clearance at 0.012
Check Brake switch for an audible click as you depress it some distance No click.. possible bad switch
Listen for Seat switch Click as you slowly add weight to the seat. No Click or any click and it can still be suspect due to the Briggs and Stratton installed engine ones have more than one function.. Ignition and PTO clutch power.
The actual wiring diagram is on page 35 of the owners manal that can be found here:
http://www.managemylife.com/mmh/owner_manuals/27245/CRAFTSMAN-Lawn,-Tractor-L9910386?brand_name_search=917273023
Lastly... check each of the mower deck blade bearings. A seized bearing can cause PTO problems.
Hopefully you have enough information to solve the mystery. If not just respond here and I will help you.
Thanks for choosing FixYa.
Kelly
Oct 06, 2010 | Craftsman Garden
I have a 6 year old Craftsman rider, model 27363 w/18.5 HP Briggs engine and 42'' deck. I tried to start but nothing - no click, ammeter doesn't move, hour meter doesn't run. Checked battery, have 12.8...
The start circuit usually only goes through the clutch/brake switch, and the clutch switch. That way it won't start if the clutch isn't depessed (brake on) and the mower deck turned off. You can test for voltage on the s terminal (start) on your switch. then for 12V+ at the clutch brake switch, then at the clutch switch, finally at the solonoid. The seat switch usually only kills the ignition if you have the PTO engaged, and you leave the seat.
Jul 26, 2010 | Craftsman Garden
I have a Cub Cadet GT1554. I used it yesterday
Check the seat safety switch and the pto safety switch.
Aug 18, 2017 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
