Question about Air Tools & Compressors
How much is the internet expedi 3-way spray gun number SG312 worth
Looking for campbell hausfeld airless spray gun ps220a 2/3 hp operators manual Please!
Go to the Campbell-Hausfeld website at http://www.chpower.com/, under the 'Service & Support" tab select 'Manuals/Parts Lists. Do a search for your model number and you'll be presented with the manuals and parts lists for that line of paint sprayers.
Feb 28, 2013 | Campbell Hausfeld Airless Spray Guns &...
Where can i get o-rings and seals for hds890
The Orings are simple just take them off and go to a good hareware store and match them up there standard sizes although they could be metric depending where the gun was made . You don't say what you are trying to rebuild . If you need to repack the unit likely you will need to talk to craftsman to get the kit and every thing you need to do it would be in this kit . You may have a choice between leather or nylon depending on what meterials you are spraying .Kits range form 60 to 120 dollars . You need to think if this is worth rebuilding if the pistion is scored or damaged that would cost 3 to 4 hunderd dollars to replace . The mechine is realy not a preficinal unit and if there is dryed paint in it . Its likely not worth it you could rent one for 50 bucks a day CRAFT PAINTING CO.
Jun 06, 2011 | Craftsman Air Tools & Compressors
I bought a spray gun and wanted to know the difference between the two air caps one is numbered 36SD and the other is 67PD I have a binks spray gun.
67PD PE Used for Zinc rich and other abrasive coatings, the 36sd is a general nozzle that is used for most applications, if you need assistance,, heres their number Technical Support Tel. 888-992-4657 Fax. 888-246-5732 or you can check their PDF located here . http://www.southernfluidsystems.com/BICONV.pdf
Apr 22, 2011 | Binks Model 7 Conventional Suction Feed...
Having trouble getting a good spray pattern when I use thick latex
You have two choices to fix this problem: First thin the paint and/or add a conditioner like Floetrol to make the paint flow properly. Second, use a tip with a bigger opening. On sprayer tips there is a three digit number (.ABC). The first number (A) is one half the spray pattern size when held 12 inches from the wall. A two will give you a four inch pattern, five will give you a ten inch pattern, etc. The last two numbers (BC) are the oriface size. For latex you should be using at least a .017 or .019 tip but if the paint has to be very thick you may need a .021 or larger.
Jan 05, 2011 | Campbell Hausfeld Airless Spray Guns &...
I am trying to find a manual for a binks 2001 spray gun i am having trouble figuring out where the o ring number 7 goes
I looked up same gun. I think I googled "binks model 2001 spray gun" and I got a pdf with all info and diagrams. On the available websites, I looked for the one that looked like official Binks site.
The PDF # I got is 77-2316R-14.pdf. It shows that #7 o ring
Nov 05, 2010 | Binks Paint Spray Gun Repair/rebuild Kit...
Paint sprayer won't pump
Ok, go to campbel hausfeld web site and download a manual for your sprayer : http://www.chpower.com/webapp/wcs/stores/servlet/XManuals?langId=-1&storeId=10051&catalogId=10001
Find your model number and look at parts view. Pay paticular attention to the inlet and outet valves. They must be absolutely clean to function. These pumps must be thoroughly cleaned when finished.
May 15, 2010 | Campbell Hausfeld Airless Spray Guns &...
Where can I find an illustrated parts breakdown for a vaper hvlp spray gun
mine came with a one page manual with exploded views of the guns with numbered and named parts on the back.
Nov 10, 2009 | Vaper Titan 3 Pc Hvlp Dual Setup Spray...
Worked for about 10 minutes
do you have a gun that comes apart? alot of them have that filter in the gun that clogs up with latex.you could remove gun and soak in mineral spirits if it does not have that filter.
Sep 05, 2009 | Campbell Hausfeld Airless Spray Guns &...
Need a new paasche spray gun for bigger jobs
Anest-Iwata brand spray equipment has the most versatile line of airbrushes on the market. Im sure you will find one to meet your needs. well worth the money, it's all I spray
http://www.airbrush-iwata.com/
http://www.tcpglobal.com/airbrushdepot/iwata.aspx
check it out!!
Apr 07, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
269 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
