Question about Soleus Heating & Cooling
Display on Soleus PH5-13R-35S air conditioner/heater.
All icons on the display light up at the same time. Additionally the power button on the main unit does not work, but can be controlled by the remote. The bigger issue is the fact that all the icons on the main unit display are continuously lit. Can use the remote, but would like for the main display to work properly. Thank you.
bobotfel
  • 236 Answers
SOURCE: No Display on controller
Try replacing the battery but if it wont work you need to replace the remote control itself, but for the main time you can operate the unit by pressing the emergency switch button to operate the unit manually.
Posted on Jan 09, 2008
ACTECH
  • 80 Answers
SOURCE: air condition won't work
THE CLICKING SOUND IS A RELAY PULLING IN ITS LIKE A SWITCH CONNECTING TWO WIRES. THIS IS A GOOD SOUND BUT IS USALLY FOLLOWED BY SOMETHING COMING ON FAN ETC... CHECK TO SEE IF YOUR UNIT HAS AN LED LIGHT ON IT AND HOW MANY TIMES IF ANY DOES IT BLINK?
Posted on Jan 14, 2008
  • 400 Answers
SOURCE: Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Posted on Mar 05, 2009
  • 10865 Answers
SOURCE: unable to turn on aircon with remote control and no manaul on button on the air con unit
I recommend putting new batteries in the remote. If that alone solves your problem great. If not, get back and let me know
Posted on May 25, 2009
bobotfel
  • 236 Answers
SOURCE: Remote control functions Ok (ie display appears and settings can be changed), but the air conditioner unit does not respond. Can operate using ther manual switch on the inside unit, but does not get p
Use your cellphone or any digital camera as your eyes by pointing the camera to the remote control transmitter. Light should emits on the remote control receiver. If no lights means defective remote control. But if lights emits means that either the receiver board or the main board is defective.
Try also the rst or reset button if present. Reset and try the remote.
Posted on Jun 03, 2009
My Soleus KFCHP mini-split air conditioner won't cool. Displays error F1: "the communication faults between the indoor and outdoor units." Tried tightening the connections indoors and out. Advice?
Cheryl, the first thing to do with this and any communication error is to cycle power on the unit. You could just be experiencing a blip in the control circuit that many times resets itself with a cycling of incoming power.
Oct 02, 2015 | Soleus Heating & Cooling
Display is out
Push the swing button 2 times quickly. This will turn the display back on.
Jan 15, 2014 | Soleus Air KFHHP-12 12000 BTU Mini Split...
Lg inverter air conditioner instructions manual
How many times switching the light? Count it and text me to tell you
Dec 18, 2013 | LG Heating & Cooling
How do I go from air conditioning to heat
If this is a mini split ductless system, then I would say to get the remote, flip the plastic cover open below the digital display, see if there is a mode, system or function button, & press it until the flame icon appears on the digital display. toggle the up & down arrows to change your temperature settings.
Dec 06, 2013 | Soleus Heating & Cooling
SOLEUS KFHHP-22 - Heater doesn't blow air at all, warm or cold. Cooling works great but no heat.
Doesn't matter how hot it was when installed, there still should have been proper start up performed. That means running unit thru all cycles and checking charge. If it was installed this summer then installer should warranty service to return and complete install properly.
Nov 15, 2012 | Soleus Air KFHHP-22 22000 BTU Mini Split...
What features do you get with 4 in 1 portable air conditioner units?
Obviouslydifferent models vary but in general you should expect to find the following:
  • Air conditioner
  • Dehumidifier
  • Fan
  • Heater
  • Digital clock/ display
Jul 17, 2012 | Soleus 4 in 1 Portable Air Conditioner
Cannot turn on.
Since you have power to the clock display- there is power to the unit. The "power" function button has failed because the momentary switch on the circuit board below the touch pad has failed. These little push switches have a short service life.
I suggest checking a source who sells the control circuit board for Soleus Air LX-140. Might be similiar component.
KT
Jul 30, 2010 | Soleus LX-120 Air Conditioner
UNIT WILL RUN FOR 15 MIN WITHOUT PROBLEMS THEN THE DISPLAY WILL GO BLANK AND UNIT WILL THEN BLOW OUT WARM AIR.
Check the condenser coil blower wheel. Soleus Air units use a cheap plastic wheel that comes apart after the warranty period. The condenser coil is the backside coil that is rejecting heat through the exhaust when unit is cooling.
The display going blank is a symptom of unit overheating, it's can't exhaust the heat buildup at the condenser, therefore the cabinet overheats.
If you find the blower wheel in pieces, I have a parts source for you:
www.shop.soleusparts.com
Jul 13, 2010 | Soleus LX-120 Air Conditioner
Jan 09, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
100 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Coss
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
