Looking for connection details on the interlock door switch. Old unit disconnected without taking connection details.
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Two lives one neutral
Posted on Apr 27, 2015
3 Suggested Answers
lostboylad
SOURCE: Hotpoint Door Interlock Switch
If it's anything like the WM65 then I did it myself this evening. Be aware that I'm no professional. POWER SAFE? Three screws on the back of the top cover. Top off Remove the soap/fabric softener tray. Four screws off around the gap that's left. Three knobs to pull off (it helps if you remember which way they are set when you do this!) Take the rectangular control panel off, which should now be loose - it has interlocks on the right hand side, so be careful not to break them. You may need to tie or tape the panel safely out of your way to te top of the machine. Three screws off the top off the door section. Open the door unscrew the two short screws holding the lock plate. The interlock switch will fall off the back of the door, held on by it's power supply. Stick your hand round the back and pull it clear. Swap the mechanism (mine cost £14) Reverse procedure. Good luck. This wasn't the fault on my machine in the end. boo hoo!
Posted on Jan 05, 2007
barkencoa
  • 3463 Answers
SOURCE: Hotpoint Washing Machine Door Interlock (how to wire up)
The three wires you should have are
1-Brown-goes to L
2 Thin black to N
3 White to C..
Hotpoint never have incorporated a wiring diagram on any of their british made appliances, so previous comments made do not apply in this case.
Hope this helps.
Posted on Jan 03, 2010
Loose filter warning
Most projectors have a safety interlock switch installed on the lamphouse door and in the filter cavity. They are there to keep the unit from operating if one or the other aren't present. I'm not familiar with your exact model, but I've seen the lamphouse interlock switch in several Panasonic units come-loose, and slide to the point where the pin on the door doesn't push the switch any more. I would suggest looking around your filter for such a switch. The one in the Panasonic is behind a round hole, and is 'pressed' by a plastic pin on the door. Your filter may be similar. Hope it helps. :)
Apr 28, 2013 | BenQ W500 Projector
My electrolux ewf 1030 get err 44 help me pls ?
E44 - It means "Door closure sensing circuit faulty".
Replace the circuit board and restart the diagnostic cycle to check further alarm condition.
When the washing programme is started by pressing the START/PAUSE button, the bi-metal PTC (contacts 3-5 on door interlock device, no.3 on electrical diagram) is powered by the triac (DOOR TY) on the PCB: after 2 - 4 seconds, this closes the switch (5-4) which powers the electrical components of the appliance (only if the door is closed). The door interlock prevents aperture of the door while the appliance is in operation.
Microprocessor recognize closure position by sensing circuit connected to J2-1 on electronic board.
At the end of the washing programme, the PCB disconnects the interlock from the power supply, but the door remains locked for 1 to 2 minutes (PTC cooling time).
electrolux-ewf-1030-get-qdylxco5jx0zjejqiwkxkzw5-1-0.jpg Dado
Aug 12, 2011 | Electrolux EW1200i Front Load Washer /...
I have a microwave hood combo - kenmore. the power goes out when i open the door or closes it, then it comes back on -
Hi and welcome to FixYa, I am Kelly.
You have a bad door interlock switch or bent switch actuation arm. Should someone open the door while the microwave is operating without pressing pause/stop when the unit has this symptom will cause the internal fuse to blow and it will not operate until the fuse is replaced. The switches are inexpensive but takes someone with some reasonable mechanical skills and knowledge of using a meter to isolate which of the 3 door interlock switches is causing the problem.
Thanks for choosing FixYa,
Kelly
Mar 02, 2011 | Kenmore Microwave Ovens
07f error code... duet washer W9150
Tech sheet on this model:
FH: If after 30 seconds the control does not detect water entering
machine, the valves will be turned off and the error code will be
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip, the valves will
be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
-Make sure that both valves at the water source(s) are turned
on all the way.
-Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
-Verify inlet valve operation.
If there is water in the unit:
-Verify drain pump operation.
-Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
F-5 Water temp sensor failure
If during the water heating step in the wash cycle, the water
temperature sensor (NTC) value is out of range, the "F/05" error code
will be displayed. Possible cause/proceedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Refer to the
"Water Temperature Sensor" section. Check
connections to the water temperature sensor.
3. Check resistance of heating element, if present on this
model. (abnormal = infinity)
F-06 Drive motor Tachometer error
Possible causes/proceedure:
1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
F-07 Motor control unit error
2. Check wire harness connections between the drive motor and
3. Plug in washer or reconnect power.
4. Check the MCU by looking for operations of the drive motor.
5. Check the drive motor for powered rotations.
F-09 Overflow Condition
or kinked.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. the pressure switch for proper operation.
F10 Motor control unit heat sink thermal trip
1. Check for proper installation, verify the unit is not located
near a source of heat and has proper ventilation.
3. Check wire harness connections to the MCU, the motor,
4. Check the drive system for any worn or failed components.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Possible causes/procedure:
2. Check wire harness connections to the MCU, the motor, and
3. Check the drive system for any worn or failed components.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
F13 Dispenser circuit error
2. Check mechanical linkage from dispenser motor to the top of
the dispenser.
3. Check wire harness connections to the dispenser motor and
4. Check dispenser motor for powered rotations.
F14 The dreaded EEPROM error
The Central Control Unit (CCU) receives its data from an EEPROM
onboard the CCU. If there is an error reading this data it will cause this
error. Possible causes/proceedure:
¦ A power glitch may cause this error.
1. Unplug washer or disconnect power for two minutes.
2. Verify CCU operation by running a Diagnostic test or any
cycle.
F15 Motor control unit error
If the MCU detects multiple resets or errors during a wash cycle it will
go into this error mode. Possible causes/proceedure:
3. Check drive belt.
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
touch-pad/LED assembly and Central Control Unit (CCU).
F du Door unlock error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to
unlock the door 6 times before displaying the error code.
¦ Door lock mechanism is broken.
¦ Door switch/lock unit failure.
1. Check door switch/lock unit for foreign objects.
3. Check wire harness connections to the door switch/lock
unit and Central Control Unit (CCU).
NOTE: The door switch/lock unit can be manually unlocked. See
"Manually Unlocking The Door Lock System".
F dl Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
¦ Door lock mechanism is broken or removed from door.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Sud: Suds lock (overdose of detergent detected during wash cycle)
The motor control unit senses a suds lock condition by analyzing the
current draw on the drive motor. If "Sud" is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
excessive detergent, or excessive suds.
¦ If too much detergent was used:
-Run the unit through a Rinse/Spin cycle.
-Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
or kinked.
6. Check drain pump.
7. Check the pressure switch.
cycle.
Tech sheet link:
https://servicematters.com/secured/docs/wiring/Tech%20Sheet%20-%208182277.pdf
Jan 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Is'nt the door interlock of the waching mahcine actuated by electrical solenoid mechanism when it is in running cyckle. If so . why cant we open the machine machine door by unplugging the unit to...
It's both electrical and mechanical. There's a water level sensor which is mechanically coupled to the switch, so even if the machine is unplugged it won't open until it's drained (open the debris trap if there is one or disconnect the hose from the pump inlet)..
Note that the switch itself remains energised electrically for a minute or two after the power is disconnected, the power comes from a large capacitor which slowly discharges.
Sep 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sharp microwave carousel R330J 1100 watt. When the heating cycle is started the microwave light flickers on and off and there is a clicking sound. Initially high voltage fuse blown. replaced fuse and...
Hi and welcome to FixYa. I am Kelly.
1st the model number appears to be incomplete. Not an issue at this point but will be if you need parts.
You most likely have an interlock problem with one of the 2 door switches or the door interlock mechanism is broken.
There are 3 safety interlock micro switches activated by the door. One for the light, one for the Magnetron and one for the control panel power. If the problem persists with the Magnetron disconnected. The Magnetron safety interlock micro switch is supposed to blow the fuse if the unit is energized with the door open. Check continuity of your door interlocks. Pat particular attention to the NC (normally closed), C (Common) and NO (Normally Open) contacts.
NC should read to C and when the switch is activated read open at which time the NO contact will read to C.
I really suspect a bad microswitch.
Thanks for choosing FixYa.
Kelly
Aug 21, 2010 | Vacuums
Fuse blown,door switch shorted
you need to readjust the"Interlock" switch position on the door, they are made to blow the fuse purposely when the door is mis-adjusted for safety, you will need to unplug the unit and disconnect the "interlock" safety switch, then readjust and close the door,until you can get the switch adjusted so it doesn't show a short circuit on the meter,then this should stop the fuse blowing issue for you
Nov 17, 2009 | Dishwashers
Rinse cycle continues after the door is open
There is a door interlock within the door assembly. I believe it's mechanically stuck rather than needing replacing.
Turn off & unplug. You should be able to get to the internals of the door via screws around the edge. The interlock will be very close to the handle catch. Check operation by inserting a dummy catch to lock onto it.
If it is stuck solid - order a replacement.
Aug 04, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Machine came up with E91 and then powered down
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Feb 19, 2008 | AEG Lavamat 72640 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
