Question about Bosch Axxis WTA 3510 Electric Dryer
Loud, low (bass) noise, not coming from the vent or the heating element
    Problem Solver:
  • 9 Answers
Most probably caused by one of the belts being frayed and about to break. You might want to replace the small drive belt (00096426) first as it does the most work of transferring the motor power to the shaft causing the drum to rotate. A worn belt can cause a low frequency hum and potentially slow down drum rotation as it slips on the hubs. Replacing the large drum belt requires a lot more work than the drive belt because you must remove both the front and side panels of the dryer; whereas, the drive belt is accessed by removing the right side panel.
Posted on Apr 25, 2015
Testimonial: "I checked both belts. both seem to be in good condition and tighten just the right way."
Goodman Heat Pump laing heat and loud noise
Taking a little bit of time for heat is normal but the "pressure" thing you are referring to leads me to believe that the reversing valve is getting stuck. You will here that "pressure release" noise with a reversing valve but it should not be happening 5 minutes after start up.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 06, 2017 | Goodman Heating & Cooling
GE profile electric dryer, sounds like something is stuck in drum
Heating problem is most likely caused by one strand of your heating element is burned out. Heating element will have to be replaced if that's the case. Noise you are hearing is most likely coming from worn front and / or back bearing. Dryer has to be completely disassembled for either repair.
Aug 28, 2017 | GE Profile Harmony DPGT750EC Electric...
How to mount a bandpass sub
usually you will get the best sound with the box mounted approximately 3" away from rear of trunk with speaker facing toward the rear of trunk if it is a single speaker enclosure you want to do the same just offset it to one side of the trunk corners always amplify sound however just so you know 10's are not really made for low bass they usually have more of a hard hitting pound instead of a low rumble usually 12's will give you the low bass better and it also depends on what kind of box a vented box would be best for low bass sealed box gives you tighter bass but you need more power ported is good for low bass but gets sloppy when loud and a bandpass is used for loud hard hitting bass
Feb 27, 2010 | Car Audio & Video
HEAT PUMP
It is not normal to have a loud buzz associated with the electric heat. Try turning the heat off and running the fan only to see if the buzz continues. The buzz could be coming from any number of sources including an electrical component, the blower wheel, a loose fastener...etc.
The temporary smoke and smell could have been the dust burning off the element if the elements have not been used in a long time. However, if the elements have been running, it could be something got loose in your system and stuck between the blower and the heating elements.....for example, the wiring diagram could have come loose and worked it's way through the wheel. I've also seen owner's manuals left in the air handler that eventually got stuck in the blower. This should be inspected to ensure there is not a fire hazard.
I hope this helps and good luck. :-)
Feb 24, 2010 | Friedrich Heating & Cooling
I just recently took apart my GE Dryer, model number DJSR473ET1WW to fix a loud noise. I put it back together and now I realize that the back of my dryer is extremely hot. Is there something I may have...
Sounds like you hava a venting problem. Disconnect the vent on the back and see if it still gets hot.
If it gets hot when the dryer is not on, then the heating element coil is shorting out on the element pan.
Hope that all helps.
Jan 15, 2010 | Washing Machines
My Amana (distinctions) central heat and air unit -loud noise
If this s an Oklahoma Tulsa area call. KOOL BREEZES 918 6878813 for a diagnostic check.
Dec 05, 2009 | Heating & Cooling
Buzzing/humming noise that increases as you raise volume. So loud that you can not even watch tv
Hello snow1525,
You may have a torn speaker element. This is usually the cause of buzzing noise in the sound, also you may have a bad capacitor in your audio section. This is what I would suggest doing as a test open the front bottom panel of your TV and visually inspect the speakers for signs of ripping and or tearing in the speaker element. If the element or elements are torn it may be possible to repair it with rubber cement or rubber paste just coat the tear with the rubber cement to hole the torn edges together and allow it to dry for two days before testing the sound. If the speaker elements are not ripped then the problem may be a bad capacitor either in the audio section (power supply) or in the filter block (usually attached to the speakers to separate bass and treble signal to the speakers.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 16, 2009 | Televison & Video
Oven made a loud noise, pop, and then black smoke....could heating element go out?
sounds like it blew a fuse or the heating element burnt out on it,look to see if the element is burnt in two
May 16, 2008 | Amana AEW3530DD Electric Single Oven
Load Clicking Noise on Deep Bass or Explosion sequences
Hi everyone having problem with B&W DM605 S2 speaker. The speakers are rated at 8ohm but during playback the impedance drops below 4ohm at low frequencies. It overloads weaker amplifiers and sometimes causes DC voltages to be injected into the speakers. Since the speakers in question are with active sub it appear that some elements on the PCB could be damaged. I would opt for LM431 (Adjustable Precision Zener Shunt Regulator) and associated elements. It could also be the rotary switch (the one used to adjust base levels - 2pole/6way) as contacts weakens over time. Possible solution: 1. switch your amp. to 4ohms 2. with the sub turned off change the position of the switch few times from max left to max right before setting it up in the desired spot.
If the problem persists: 1. replace the switch
2. replace suggested elements checking also KBL401 (Rectifier). TDA7294 (Amplifiers) are usually O.K.
Apr 18, 2007 | B&W DM605 S2 Speaker
Bosch Axxis WTA 3510 Electric Dryer Logo
120 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
