Question about Garden
Starts and idles fine and runs with feathering the throttle, but dies when I try to run it full.
Given to me by a friend that accidentally put 2cycle mixed gas. Cleaned carb and replaced lines, fuel filter and bulb.
  • 3,519 Answers
Hi Joe:
Try removing and cleaning the muffler. Sometimes there is a fine screen (spark control) that will get covered with carbon. As soon as you try to run at high speed the back pressure kills the motor.
Posted on Apr 25, 2015
  • Joe Lazar
    Joe Lazar Apr 25, 2015
    Thanks Ted, I'll give it a shot in the am.
Truck starts but won't idle. If I stay on the gas pedal it will keep running untell it warms up if I turn lights or heater on it dies right away also please help
Need help: Truck starts but wont stay running?? - FullSizeChevy.com
www.fullsizechevy.com > ... > Technical / Maintenance
Jun 19, 2005 - 17 posts - ‎9 authors The truck will start but then die right out. I can do this all day long with the same effect. I can however keep it running by feathering the throttle. if ...
Truck starts but won't stay running...?? - Dodge Dakota Forum
Nov 30, 2015 | Cars & Trucks
Fuel system running rich and stalling
Sounds like it is slightly out of time.
Apr 14, 2014 | Ford Cars & Trucks
I have a small 4wheeler that is hard to start and will not idle it will run at speed but if you stop it doesn't idle it dies
Your pilot jet in the carb is plugged up or to small you will have to pull the carb out and clean it if you have a wire brush you can use 1 of the needles off it that will fit in the tiny hole in the pilot jet push it through and then spay carb cleaner through it and the main jet put back together and it should run fine
Nov 26, 2013 | RTO 125cc Full Size Adult Quad ATV
Engine backfiring and loss of power with throttle pushed in slightly
Need to put the cat back & the Oxygen Sensors
The O2 Sensors are for adjusting fuel trim
Can't use the vehicle the way you have it & it is
against Federal Laws to remove Emissions Equip.
Sep 19, 2012 | Cars & Trucks
Engin dies when up to termpreture
I suggest to check engine temperature sensor and air intake system; additionally, scanned the computer car in order to know if have some fault code stored there.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 03, 2012 | Volkswagen Camper Cars & Trucks
1989 gmc s15 starts then dies
Your best bet ,take it to a qualified repair shop that has the diagnostic equipment to diagnose the problem . You already replaced a part that didn't need to be . This problem could be caused by any number of thing's . I would only be guessing without testing , are you prepared to replace every part suggest on here . Do you have a OBD 1 scan tool to view engine sensor data ? Do you know what that is ? Could be fuel related , crankshaft postion sensor , coolant temp.sensor , ignition module . Leaking fuel pressure regulator ,injectors leaking .
Jul 24, 2017 | GMC S-15 Cars & Trucks
you need to check the battery cables and clean them and clean them, or it could be the coil needs replaceing or there might be a fuse blowed somewhere.
Mar 17, 2012 | GMC S-15 Cars & Trucks
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
