Question about Health & Beauty
Just replaced both batteries the chair turns on and showes full power. The seat goes up and down but the speed indicator just blinks and the chair will not move.
    Master:
  • 436 Answers
Check your connections. You may have a connection not quite tight enough. It will still allow the gauge to operate, but won't operate the motors.
Posted on Apr 25, 2015
  • 16 Answers
SOURCE: power chair lights
The problem was a bad joystick. A local company came out to replace it and it works fine now.
Posted on Mar 07, 2009
SOURCE: The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Posted on Mar 13, 2009
  • 8 Answers
SOURCE: All the lights are blinking very fast
try pushing the chair. If the chair moves your motors are disengaged. to engage your motors look at the base of the chair there should be a lever possibly 2 push, pull or turn depending and try your chair again if you need additional help you can reach me at 404-966-3734 and i can walk you through it
Posted on Jun 11, 2009
  • 8404 Answers
SOURCE: Chair has new bateries but barely will crawl when
Contact your retailer and explain this to them. They are in the best position to help you with this matter.
Posted on Mar 03, 2010
dwilkes7
  • 6 Answers
SOURCE: need a wiring diagram for jet 3 power chair
Look here: http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_Jet_3_ultra_om.pdf
Posted on May 12, 2010
WHEN POWER ON CHAIR SPEED LIGHT BLINK .BOTH BATTERY WAS REPLACE AND JOYSTICK.SAME PROBLEM
The battery meter lights will flash a flash code when something is wrong. If the lights are flashing the same number of lights each time. get that number it is a flash code. if the lights are cascading up and down that indicates that the Joystick is locked. unlock by turning on the joystick and pushing the horn button twice within 10 sec. of turning on. Or push on button and hold the joystick gimbal forward until it beeps then back until it beeps. This should have it unlocked, if not Pride Jazzy Tech 800-800-8586
Mar 28, 2016 | Pride Mobility Used Power Chairs Jazzy...
Why does my chair show a full charge yet after only a half a block it will show only red flashing lite indicating needing charge.
Your batteries are nearing replacement time. They are becoming incapable of holding a full charge.
Apr 28, 2015 | Pride Jazzy Select Elite
Help I stupidly got my dog lead caught around the left drive wheel of my M61 Pronto yesterday. A kind person got it unwound but needed to tip the chair on its side to do it. Now the far left single green...
The M61 has an elevating seat. There is a speed limit switch which consists of 2 magnets that make contact under the seat on the seat post. If the 2 magnets are together then the chair thinks the seat is all the way down. If the magnets aren't touching it activates a safety feature in the controls which cuts power to the chair by 50% hence drives real slow. Try lowering the elevating seat down through the joystick controls. If that doesn't fix it then either the magnet switches on the seat post came unplugged or broke.
Sep 16, 2011 | Invacare Supply Group Pronto M61 Standard...
Replaced batterys in jazzy chair speed indicator keeps blinking - no code for it - plug in charger works for a minute after unplugged but then goes back to blinking?
Jazzy is in lock mode try the following to unlock:
Lock Mode
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple side to side.
2. Push the joystick to the full forward position until the VSI beeps.
3. Pull the joystick to the full rearward position until the VSI beeps.
4. Release the joystick. There should be a long beep.
5. The VSI is now unlocked
Hope this helps
Mar 29, 2011 | Pride Jazzy 1113 ATS Indoor Power...
On off switch lights the red yellow green readings at full strength but continues to just blink when turned on.. get no response trying to use the joy stick. - the seat riser and speed buttons show no...
YY count the number of flashes ie 4 flashes pause 4 flashes pause. This will give you the error code and will tell what is wrong with your chair Check out my tip on Flash codes if you can't find them in your manual. Without fixing the problem that generated the flashing you won't be able to use the chair until the problem is fixed. If you want you could contact the provider that sold you the chair and have them troubleshoot the problem for you Hope this helps
Mar 07, 2011 | Pride Jazzy 1103 Ultra Standard Power...
WHEN I TURN THE POWER ON FOR MY JT3 ULTRA POWER CHAIR, THE LIGHTS THAT INDICATE THE STATUS OF BATTERY BLINK ON AND OFF (REGARDLESS OF BEING FULLY CHARGED OR NOT) AND THE CHAIR WILL NOT MOVE. SOMETIMES,...
I would replace the batteries with new ones anyway to make sure that you are getting full power and if the problem stops great if it continues then you have eliminated one possible problem. A low battery will cause the problem and these chairs diagnose themselves with the controller giving you flash codes to indicate a problem. I would just check for a loose connection in the wiring when you have the seat off changing the batteries and give the base a good cleaning( without water) (Use those cleaning wipes from dollar store) Hope this helps you
Sep 08, 2010 | Jet 3 Ultra Power Chair
How do I increase the speed . It seems that it ran faster on the straight and now I don't feel with all the bars lit that the speed is like it used to be. Please tell me what I can do to make sure I will...
How long have you noticed the decrease in speed? Are you charging the batteries regularly? Have you checked your air pressure in your drive tires?
If the batteries are getting old or the power chair has been stored for a while, the batteries may not be taking a full charge. If your speed indicator is showing full like always but the power chair is not responding like it used to, it may be a battery issue.
As you operate the power chair, listen for noise and pay attention to see if there is any vibration, this may indicate a mechanical problem that is causing power drain.
If not, your power chair may still be within normal parameters, just not "new out of the box" anymore. Make sure that you decrease your speed when going up inclines to avoid excess wear on the motors.
Aug 06, 2010 | Pride Jazzy 1103 Ultra Standard Power...
My speed indicator lights are constintly flashing- the chair works fine though
You don't say what sort of chair you have, but if it has tilt or power seating system, the speed lights flashing could be a power-limiting warning, which means you have the seat tilted or raised too high for full power so it is limited to going slow. Lower seat and then try to drive it an normal speed. If the seat isn't tilted or raised and lights are flashing, then the switch on the chair that senses the height or the tile is probably faulty and would require replacement. Do NOT disable or bypass the switch as it is a safety device to prevent unsafe operation.
May 23, 2010 | Jet 3 Ultra Power Chair
The chair does not have a manual with it. It has new batteries fully charged. How do I turn it on and make it go?
The top button on the controller with a circle and dash line is the power button. Sit down, buckle your seat belt, lower the footrest, power the chair on and press the joystick forward. You can control the speed by using the 2 lower buttons with horizontal dashes one them; 2 dashes goes slower, 4 dashes goes faster. The second row of lights is the speed indicator, you will see this light change as you change the speed.
Good luck, be safe, and let me know if you have further questions!
Dec 10, 2009 | NRS Hoveround MPV 5 - Used Power...
Health & Beauty Logo
152 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
