Question about LG Cell Phones
Lg F6 wifi button in settings is faded and wont let me turn it on/off and it used to work fine and i dont know if i did something or wat. Any ideas on how to fix it?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 56 Answers
Have you tried turning your phone completely off for ten minutes than turning it back on , this used to work with mine, also check your data usage. Sometimes when I used too much data this would happen. A clean screen can help too. Cheers
Posted on Apr 25, 2015
SOURCE: my juke is broken the
it is the same for me. what i did was i took at the battery over night and put it back in. it could make it better or worse. after, bring it to the verizon store you got it from, or if you ordered online, any one.
Posted on Nov 04, 2008
  • 61 Answers
SOURCE: Blackberry Curve 8310 buttons dont work
what i do with phones is i have the screwdriver to open it (avail at ****'s, tandy, jay-car and even bunnings a torx5 or 6 i believe), and open the phone, clean it down with metho and a cotton bud mainly on the key pad and also the gold contacts. let it dry.
Posted on Jun 05, 2009
Rahilzari
  • 135 Answers
SOURCE: my LG neon wont turn on
plz check ur battery or chang it
Posted on Sep 15, 2009
SOURCE: turn off/end call?
I had the the same problem. I was pissed off. But I turned my phone off(and i have the env touch).
And both of the power/end buttons are all fuctioning normally again.
I hope this works for you too
Posted on Oct 30, 2009
SOURCE: my blackberrys key lock wont
mine has done the same... has yours fixed yet?
Posted on Dec 28, 2010
Why does my Samsung S3 galaxy tab keeps disconnecting from wifi?
I encountered the same problem when streamed something through wifi. The solution was in wifi (on the transmitter side) settings. Having no idea what wifi point you're using have no suggestions
Sep 02, 2014 | Cell Phones
Authentication problem for wifi on LG-P750g
Try to launch a hard reset on your self-phone by following these steps:
1.If the device is off, hold down the Power button to turn it back on.
2.Afterawrds from Main Menu find and select Settings.
3.Then open the Backup&Reset (Privacy) folder and select Factory Data Reset.
4.Tap Reset Phone and read the warning when it pops up.
5.Choose Erase Everything and the phone will begin restoring.
6.Well done! The hard reset has just been performed.
Hard reset usually solves those issues.Hope i helped
Aug 22, 2017 | Computers & Internet
Wifi wont work
Go to your wifi settings. You should have a button that turns on your wifi. Just click that button.
Apr 29, 2013 | LG Marquee for Boost Mobile
Im trying to set up a wireless modem, but i dont no how to r wat the switch looks like to turn on the wireless
usually there is not a switch to turn wifi on a modem you need a wireless device to try to access its wireless network
you need to plug a wired computer into your modem and type in default ip address 192.168.x.x they are slightly different for each brand EI: linksys 192.168.1.1 Dlink 192.168.0.1 telus: 192.168.1.254
so go into your router settings and you should have a wifi tab somewere in there you can set your SSID (what your wifi will be called) for something you will remember and maybe disable security untill you get your wifi device connected then add what ever security you like
when you try to access your wifi network witha wifi device you wifi light will come on your modem
Feb 05, 2011 | Acer Computers & Internet
Code F6 Oven will not work with any button, I get
Hi janishanson,
The F6 fault code description is an EEPROM checksum error. The EEPROM checksum error occurs when the values differ. In this case, you need to replace the mainboard or control board, also called as ERC.
Hope it helps.
Thank you for using FixYa.
Jan 15, 2011 | Dacor Preference RSD30 Gas Kitchen Range
I recently receive my LG X120 with windows XP,
Function + F6 will enable/disable your wifi/bluetooth
Nov 05, 2009 | Computers & Internet
BLACK LINES TOP AND BOTTOM OF SCREEN (PIC SETTINGS)
This is an aspect ratio issue. On the remote there is a button for changing the ratio to either 16:9 or 3:4. I think it depends with ones remote control but the button has a square as its label. Try looking for it or refer to the user manual. That would be my first guess.
May 06, 2009 | LG 42LC2D 42 in. LCD HDTV
My side kik wont turn on
press the red button and hold
Jan 02, 2009 | T-Mobile Sidekick II
Won't Turn On/Charge
hi , i know a friend have one like that, same probleme he have to bring back to make it fix by the compagny,, only help can give you Yvon chow !!!
Jan 02, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Kenmore microwave
i fixed by unplugging the microwave with the door open. I plugged it back in and the F6 was gone. I was then able to set the clock and turn the light on/off . When I closed the microwave door, the F6 came back on and the microwave was making a humming noise. I slapped the side of the microwave near the keypad, and the F6 cleared from the readout and the humming stopped. The microwave is working fine now. Don't know why, except maybe slap on the side reset a relay or something. Anyway, I will never by a Sears Kenmore appliance for the rest of my life. The door rattles when you open a close it (like a part inside the door is broken) and this is the second time a fault code has appeared during use. I had GE Profile appliances at my last house, which are more $$ initial cost, but who wants to screw around buying a new microwave every four or five years. I'll happily spend a couple hundred more for the peace of mind and knowing that it will work during Thanksgiving dinner with the family over.
Sep 09, 2008 | Microwave Ovens
Cell Phones Logo
35 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
