Question about Saws
Planes timber well but puts a dent in the timber just before it exits.
The dent runs across from left to right, every time, every timber wide or narrow. I adjusted the exit table lower, cleaned the tables but still does it. It use to be fine and is now about 2-years old with minimal use.
  • 2,827 Answers
I'd adjust the exit table higher....
Posted on Apr 25, 2015
I have a 130 BT leaf blower. It will not run at full speed. It starts and idles just fine. When I speed up, there is an increase in rpm but no where near 7500.
Here is the parts manual, incase you didn't have it.
http://www.mediafire.com/download/1dr01bcdwhik7im
have you checked the exhaust.?? If the Muffler is blocked then it will hinder the running of the machine as the exhaust gasses wont be able to escape. Check it isn't 'carboned' up and that the exit of the muffler isn't damaged. I've had it on Stihl engine where the exit on the exhaust was dented in, hindering the flow of exhaust gassed.
If you find useful, please click the 'helpful' tab. thank you
May 16, 2016 | Garden
How to attache a lean two to your house
Put a 4x2 the length of ur lean to fix to wall with large 3/8"x5" long bolts an plugs in wall if brick if timber then screw in to that, at a height u want to have the lean,.. to make a mark with a friend place timber with level on and mark wall drill the 4x2,, to take fixings 18" apart along the length then fix to wall, then u will need 2 or 3 up rights to hold roof up u will also need several cross timbers to take roof panels make sure u have a slight fall on roof to out side so rain runs of u will need cross bracing fix wall plat thats what the 4x2 is called up rights in ground add cross bracing then put all others bracing at even spaces in b tween then when all is tight put panels or plastic sheet on roof making
May 07, 2014 | Washing Machines
There is a 4 inch wide line across our 51 inch plasma tv. is it fixable
Yes the board to repair is cheaper than tv. As well you can search youtube an get info on how to do it your self. I do my repairs.
Mar 24, 2014 | Televison & Video
KP-57WV600 Sony Wide Screen tv blue arcs across entire screen
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I hope this will help in solving the problem...
Sep 09, 2011 | Televison & Video
In my lexus gs300 my cd changer is stuck and I need to know how to remove it
i had the same problem with my 99 lexus ,took front cover of frame around glove box,3 srews across the top,1 screw bottom left corner,pull entire cover comes off ,now you r looking at your cd player held in by 2 bolts 1 on each side,but i felt around the cd player found no place to push cd cartridge box out ,i got 2 dent pullers out og my tool box,DENT PULLER HAS A T HANDLE WITH A STRONG WIRE COMING OUT OF IT WITH A SMALL HOOK AT END,put one on each side and pulled came right out,turns out i didnt need to take anything apart just use the dent pullers,the problem was one of the cd wasnt in place right causing the box to exspand once it slid in the outer edge was hung on the mouth of the box,ps my cd changer is in glove box,but same scenario for trunk hope this helps GO COWBOYS
Oct 23, 2010 | Car Audio & Video
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
Paint skin not showing up on Flight Deck 5 planes
Check that you are running FSX and add-ons in administrator mode. This sounds like a user rights issue.
Jun 14, 2009 | Abacus Flight Deck 5 Expansion Pack for...
Why are Aluminum Fishing Boats the Best Fishing Boats?
A timber boat is high maintenance. Trust me, I've had quite a few. You're always sanding timber, varnishing timber, repairing timber and lots more. Now if you're happy to be doing that then that's great, but recognize that's the price you pay for a great looking timber fishing boat. And a timber boat is often heavy, and will not last well, particularly if you aren't as diligent with your maintenance as you could be. And they puncture easily when you hit something, as I did last week. But if you're not an enthusiast for working on boats then timber isn't your best choice. What you want in a fishing boat is this. It needs to be tough. It needs to be low maintenance. It needs to be puncture resistant. It needs to last forever without spending hours working on it. It needs to be easily repairable. And it needs to be cost effective. For me the best choice fishing boat is an aluminum fishing boat. Aluminum has properties which make it the perfect material for building fishing boats. It is very light and strong for it's weight, and can be easily welded, so is ideal for both building and repairing. It is extremely long lasting, and is very resistant to puncture. Now of course that doesn't mean it can't be damaged, as it can. But you need to hit it pretty hard to do some serious damage. And if you did that to a timber or fiberglass boat it will be very seriously damaged. And an aluminum boat may just dent, rather than fracture, so you can head right back home with nothing more to show than a dent, instead of possibly be the subject of a rescue from a sinking boat. And it lasts forever if treated right. If you get a great aluminum fishing boat and treat it well you may well find yourself leaving it to your kids. Because aluminum boats are light for their strength they often need a smaller engine, and the engine is probably the highest cost item. A smaller engine costs less, and uses less fuel. And with a smaller engine they are also lighter and easier to handle. And they require little maintenance. Make sure you hose your boat down after a day out, especially in saltwater, and if you drop a lead sinker make sure you pick it up, as it's not great to leave any other metal in contact with aluminum, otherwise you don't need to do too much maintenance at all. More fishing time. And because aluminum boats last so well they also retain their resale value well. I bought a used aluminum fishing boat 2 years ago and it is currently worth a little more than I paid for it. So there's plenty of good reasons to buy an aluminum fishing boat. Unfortunately they aren't cheap if you want to buy a new boat, but for the same reasons I've mentioned above, it's way better to buy a used aluminum boat, as a used boat is usually much cheaper than a new one, and retains it value well. I would never buy a new aluminum boat. So grab yourself a great used aluminum fishing boat and get fishing this summer, it's the best way to get on the water.
Dec 01, 2008 | Sea and Sea Sea Eagle Inflatable Fishing...
Paper dents
I believe you have two problems. One the dent you are talking about unless I see it I don't know for sure but I believe this is minor and something you need to live with. The paper goes through a fuser which uses a teflon sleeve over a heater surface and a lower pressure roller made of rubber. It may be that you need a new lower pressure roller they get little cuts in them sometimes. Two the spots are probably from a faulty toner cartridge. It has a leak.
Feb 13, 2008 | Canon imageCLASS D761 Copier
Aero elite:combat academy
Here is a list of the planes and how to unlock them: http://www.gamefaqs.com/console/ps2/code/559688.html Also, if you haven't checked it out yet, I suggest the Ace Combat series. It feels a little more arcadey but it has a pretty wide range of planes and is very fun.
Sep 05, 2007 | Sony PlayStation 2 (PS2) Console
Saws Logo
184 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
