Question about Dryers
Why does it sound like a ball bearing rolling around?
  • Dryers Master
  • 5,323 Answers
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Posted on Apr 26, 2015
My dryer sounds like there are metal balls rolling around inside when clothes are drying
Sounds like the rollers are worn out. If they are fine then see if the dryer has glides on the drum.
Apr 23, 2014 | GE Profile Wizard DPSE592EAWW Electric...
Noise during high speed spin cycle
sounds like the bearings need replaced, when replacing bearings you need to replace all of them to ensure proper function and life longevity.
Dec 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
I need a tilt switch for the honeywell HZ-341-bl porable heater. Where do I find one and how much do they cost? Jim
Hi, Jim...
I'm presuming that your heater has a tilt switch that isn't working. Is this right?
Tilt switches used to contain mercury (which has been phased out because it's so toxic). They now contain ball bearings... which may have gotten frozen (especially if you live in a high-humidity area).
I'd first of all open up the heater, identify the switch (generally black plastic, around 1" long by 1/2" wide - something like that) and rotate the heater back & forth... listening for the sound of a ball bearing rolling back & forth. If you don't hear any sound, you can try CAREFULLY knocking the switch housing with, say, a ball-peen hammer to loosen it up.
If this doesn't work, you will probably want to replace the switch. You can find them on Google, ranging from $2-6. If you're handy with a soldering iron, you can easily replace it yourself. Otherwise, find a friend (or take it into a shop) for a very quick & easy fix. Don't forget to epoxy the housing of the switch to the heater, so it doesn't rattle around!
Mar 02, 2011 | Honeywell (HZ-341BL) Ceramic Heater
Sounds like there are balls rolling around inside.
Remove lower rear panel of washer.
Remove drive belt.
From the front of the washer spin drum by hand, if it feels rough, or is rumbling, then the main drum, bearings have failed.
This a major repair, depending on age of washer, sometimes better to call it a day and get a new one.
Hope this helps, and good luck.
Dec 14, 2009 | Hotpoint WMA50 Front Load Washer
Something rattling under the drum
Strangely enough, I found the problem to be in the motor. If the noise becomes pronounced during the high speed spin cycle, then that is the problem. I had a repairman out for mine and they wanted to replace the drum, however when I took off the back and removed the belt, I could turn the drum separate from the motor and could hear that the problem was in the motor bearing, not the drum. Hope this helps.
Nov 18, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer (He3t) front load
The bearing in the duet is attached to the outer rear tub of the washer. You have to remove the whole rear half of the outer tub. Take off the back and you will see all the screws around the tub where they attach together. you have to buy the whole rear half too. They wont let you replace just the bearings.
Leaking
Flooding like that usually means a bad drain hose or bad hose connection either at the bottom of the basket or at the drain pump. Need to check both.
Apr 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Agitator is making noise
bearings in the transmission are going out. they are fairly cheap if you can change them yourself.
Mar 29, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Dryers Logo
90 people viewed this question
Top Dryers Experts
