What is the voltage on charger - Computers & Internet
  • 2,857 Answers
Most laptop power bricks put out 12volts.
Posted on Apr 25, 2015
Older model phone charger
4 important points or facts to note with chargers are as follows:
1. Supply voltage ~AC/Voltage (input, say 110Vac, 220Vac)
2. Output voltage (VDC)
3. Output ampere rating (amps)
4. Jack type for connecting charger to your phone.
What this implies is that you have to get your old phone to a store where phone chargers are sold or can be purchased (because of the connector jack)
However, you need to know the specific OUTPUT charging voltage (indicated as DC) and current for your phone
Oct 04, 2017 | Cell Phones
Go-go battery won't charge
PLEASE NOTE: The Low Voltage Protection feature on this battery charger will not allow the charger to activate unless it is connected to a battery pack that has a minimum voltage of 16 volts. Battery packs with voltages below that level of charge cannot be recovered or recharged. This is a safety feature to prevent overheating in the event of a faulty battery. This battery charger will not output any voltage to the XLR connector until connected to a battery pack meeting this minimum voltage requirement.
Dec 27, 2011 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
How do u charge a edelbrock power wheel corvette for kids 12 volt batteries and a 6 volt charger
Hello! Due to Charger Voltage Compatibility: Never use a battery charger unless the battery voltage matches the output voltage rating of the charger...Therefore do not use a 6-volt charger on a 12-volt battery and visa-versa...
guru...........
saailer
Sep 27, 2011 | Cars & Trucks
Where should the output from the charger be read?
Karrie if the chair has an on-board charger you can read the charger voltage at the charger port located under the front of the joystick. Set a meter to 200vdc and plug the leads into the two outter ports under the joystick Plug the charger into the wall socket and you should be able to read the charge voltage it should be 27-30 volts. If you have a off-board charger you will have to read the voltage at the batteries with the charger plugged into the the charger port under the joystick. Hope this helps
Mar 11, 2011 | Jet 3 Ultra Power Chair
How I can convert 110volts to 220 voltage in Craftsman charger 145301 because in the Peru country we use 220 v. thanks.
_Some_ chargers will allow a range of input voltages. This will probably be "Input: 100-240V" or something like that written on the charger. __You need to be sure__. Others may have a switch from one voltage to the other. The trick here is to make sure the switch is in the right position. In both cases you may also need a plug pin adapter. If the charger you have has neither of those abilities then you either need to get a different charger from Craftsman, or get a voltage converter, which will give both the right plug for your wall sockets and convert from 220V (from your wall) to 110V (to the charger). Unless the charger has voltage range or a switch, you can't just use a simple plug pin adapter.
Feb 20, 2011 | Craftsman Drills
Put chargar after 2minits notcharge
Please check your charger for malfunction. Check the voltage output of your charger. A good charger will has voltage out a bit higher than your battery voltage rate ( see voltage rate on nokia battery). The common problem for this case is the charger and is not the phone.
Regards
Jan 16, 2011 | Nokia E63 Cell Phone
Battery is not charging when connected to charger
The problem might be in the battery or in the charger. If you have a multi-tester check the output voltage of the charger. The voltage output must go with the rated voltage in the battery. If there is output volyage in the charger then the problem is your battery. If there is no output voltage then the problem is your charger. Take time to check both the charger and the battery to make sure which to replace.
Dec 07, 2010 | LG Shine KE970 Cellular Phone
New batteries does not seem to fully charge. tested the output of the charger with meter and it shows no voltage on the output of the charger, but the two lights flash quickly when plugged in to the wall...
The measurements below are for a 12 volt charger or across one battery at a time. In a 24 volt charger or across both batteries at once, double the values.
The charger will not show any output unless connected to a battery. To test the charger, attach the charger to the battery but do not plug in the charger. Connect a meter to the battery and read the voltage (9.8v - 11.6v).
Now plug in the charger. Read the battery again (13.6 - 14.2v).
The voltage must not be higher than 14.8 on the battery or the battery will over-charge - the charger needs service. If the voltage does not come up to 13.2v, the charger is not running. Again, the charger needs service.
Be patient. You can wait ten minutes and measure again. Batteries respond slowly to the charger.
Apr 02, 2010 | Pride Jazzy 1113 Power Chair
Schumacker battery charger problem?
You are charging. The meter corresponds to the level of charge in the battery. Try setting to 10 A for 4 hours, battery should be half-way up. To determine if battery id dead.. leave battery off charger once it is fully charged...test with a voltmeter after 10 min.....battery should still be above 12v...after1 hour it should still be above 12v...if not battery is spent.
Mar 11, 2009 | Schumacher & Fast Charge Starter Charger
Energizer CHDC charger suddenly not indicating if charging or not
It sounds like the PC Board which provides the circuitry for the Charger's indicating light is malfuntioning. If you have a DC volt-meter, you can check the Charger's output voltage, and then the Battery voltage to determine if your charger is functioning.
Hint: If the Charger has an output voltage, but the Battery's voltage is less than its rated voltage... it's time for a new battery.
Mar 11, 2009 | Energizer Rechargable Battery with Charger
Computers & Internet Logo
David Payne
David Payne
