I have info for a foot switch P/N 0055592000 is this correct for the PR82?
Foot control on my Juki 2010 sewing machine is not working, as if there's no power reaching it at all. There is power to my machine as indicated by light coming on when main power switch turned on.
Pam, Could be a bad/broken wire, may be repairable, you should take your pedal in to be tested, if diagnosed to be bad you may have to order a new replacement pedal. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Repair the Foot Control on Your Sewing Machine
http://www.sewingmachinesplus.com/foot-control-419451-003.php?gdftrk=gdfV210602_a_7c3285_a_7c15319_a_7cPID513
Sewing Parts Online Search
Juki Sewing Machines
Jun 09, 2016 | Juki Sewing Machines
On my 4 year old son's John Deere gator prediger riding toy when you put battery in it goes before you push the accelerator?
it sounds like the foot switch is wired backwards or if the switch was put in backwards. I would take out the foot pedal and check the switch and make sure that is wired correctly.
Apr 20, 2015 | Toys
On-off switch for sewing machine
Do you have anyone in your family or circle of friends who owns and knows how to use a multimeter? If so have them help you.
Since you didn't provide any info other than your machine is Kenmore it's kind of hard to guide you.
Good luck
Sep 06, 2012 | Sewing Machines
I have a VOX AC15C1 amp and bought a VFS2A foot switch. The foot switch right LED did not come on and I sent it back for a replacement. The replacement foot switch came and the right channel seems not to...
That supposedly is the correct footswitch for the amp... there may be a defect in the amp. Contact the factory support about this problem. Make sure you are FULLY plugging in the plug as SOMETIMES they feel like they are clear in but they are not.
Sep 19, 2011 | VOX VFS2A
NO BRAKE LIGHTS - FUSE BLOWS
Really need more info but if it blows fuses you have a hot wire touching metal somewhere......
or something plugged in where it shouldnt be.....Or wrong size fuse..You have a brake light switch attached to the brake pedal which is common to fail.....also brake light bulbs and fuse ...check where bulbs are installed at recepticles....check for naked wires touching metal.....also use a good rated fuse...
should be a 15 some are 10 some 20...i would try a 15 if you dont know..................Sometimes your foot can accidently kick wires loose under dash at brake light switch........some cars also have
a cruise control switch above brake light switch.....DONT confuse one with other....NEED MORE INFO ABOUT VEHICLE TYPE TO GIVE CORRECT ANSWER................METALPOET
Jul 29, 2011 | GMC Canyon Cars & Trucks
Pioneer PL-630 turntable won't hold correct speed with the quartz lock on or off. I cleaned the switches with no change,speed still varies.
Replace the speed selector switch, if you can still get one...They were prone to oxidation caused by gasses emitted from the rubber foot close by... The Pioneer remedy was change switch AND rubber foot for a neoprene one
Feb 12, 2010 | Audio Players & Recorders
Info screen keeps beeping to change pressure foot, and I have the correct pressure foot attached to the machine.
If this machine is a Rose, the screen flashes the foot because it thinks the foot is in the up position, not because your using the wrong foot type. There is a spring that can break and a switch that can sometimes go bad that gives that error message. A trip to your service tech is required. That part has a 20 or 25 year guarantee if you are the original purchaser. Labor was covered for one year from date of purchase.
Sep 27, 2009 | Husqvarna Sewing Machines
I need a foot pedal/power cord for my Euro pro serger model 101-854H. Can you help me find one?
Email me a picture of the spot on the machine that the foot control cord plugs in and I'll send you the link to the correct one and to order. info@sewingpartsonline.com
Apr 22, 2009 | Euro-Pro Sewing Machines
Computers & Internet Logo
294 people viewed this question
David Payne
David Payne
