Question about Cell Phones
How can I hear my phone call through my Targus Bluetooth Speaker w/ Microphone, TA-22MBSP-stp?
Raysagem
  • 1017 Answers
SOURCE: sound problem
On the side at the top of the phone there's a up or down button < > turn the sound up DURING a call.
Posted on Feb 16, 2008
  • 12 Answers
SOURCE: Sony Ericsson W880i Faulty Microphone
buy a new mic on ebay and fit it your self will take under 15 minutes and the instructions are on the internet
Posted on Mar 28, 2008
  • 95 Answers
SOURCE: can only hear a caller on speaker
Do a master reset or reset factory settings and see if it works. It would delete your data, so take a back up before you perform that step.
If that does not work, then its a hardware failure, if you phone is under warranty get it serviced.
Posted on Jan 27, 2009
  • 5 Answers
SOURCE: lg cu515 I can't hear caller but caller can hear
im a cell rep, delt with this problem before, take the back off the phone there is a white dot somewhere on there, if it's red it has water damage. if it's not your speaker for normal calling is broke, that's why you can only hear it on speakerphone and bluetooth, usually caused by water damage. there are cell phone repair shops, if you want do a search for one near you, they charge to fix the phone, but i have sent my customers there before and had their phones fixed. if it annoys you to much and you dont want to deal with it, if you have insurace i would file a claim, if not buy a phone from a friend or off craigslist or ebay, cheaper. hope i helped
Posted on Jul 02, 2009
SOURCE: blackberry bold 9000 speakerphone doesn't work!
Guys- I have had the same problem with my speaker not working and it comes down to the spacing inside the phone. Some people have resolved the problem by placing a small piece of paper or credit card between the phone or the battery back. I actually took the back cover off, the battery off, and then unscrewed the 6 tiny screws to take the back of the phone off. You'll then see two small pins that act as spacers to keep the phone back off of the speaker and you can gently bend them upward a bit more and this totally worked for me. I noticed after I was using a leather pouch to hold the phone, the only way to take it out was the pinch the phone on that area, and was thus "smooshing" these pins down and not giving the speaker the appropriate spacing. You'll void your warranty by doing so - but you should be able to fix the problem.
Posted on May 16, 2010
My samsung WEP650 bluetooth earpieces audio is not working. I am able to talk and the other party can hear me but I can not hear anything on my end. Any suggestions?
From your explanation, audio (microphone) is working: instead, speaker isn't working.
Have a phone/electronics service technician help check your Bluetooth earpiece out.
Speaker connection cable is disconnected (internally).
Otherwise, the speaker has defects and must be replaced.
A last resort may mean the Bluetooth headset board is bad.
Oct 11, 2017 | Samsung Cell Phones
Where is speaker on alcatel cell phone?
? Microphone? For the other person to hear you the microphone on the phone must work. You cannot adjust that. For you to hear them you need a speaker on your phone. You can adjust the volume of the speaker on your phone. If callers cannot hear you try putting your phone on the speaker, rather than handset mode so it becomes a speaker phone. Then, while talking to someone to test the phone, try holding it in different ways to see if you are covering the microphone with your fingers. Without knowing what model of phone (specifically) you have I can't figure out where these are located on your phone. You can google the model though and locate them yourself easily.
Aug 31, 2014 | Alcatel Cell Phones
What is the pin number for targus bluetooth speaker mid#2550913?
Password for Targus wireless speaker Mid#2550913 is 0000
Jul 12, 2014 | Audio Players & Recorders
On answering a call i can hear them but they cant hear me
I would delete all paired devices from the Parrot kit and delete the Parrot kit from your phone, then remove your battery from your phone for 5 mins, then repair as a new phone. If this does not work you have a microphone issue, check the wire is not trapped behind one of the trims.
Nov 21, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
When I make a call I can hear the person on the line but the person on the line cannot hear me. We can only hear each other when I turn on the speaker.....this probem only accured this weekend
It is quite possible the microphone on your cellphone is damaged..
You can possibly use an earphone/bluetooth to bypass this issue. Or get it repaired by your local cellphone technician..
Nov 15, 2010 | Motorola Mobility RAZR V3
No one can hear me/sound is very bad Parrot 3200
it sounds like the microphone is trapped or faulty, get the engineer back to sort it out or follow the microphone wire to see if is trapped behind the trim going down the side of the winscreen.
Dan
Feb 16, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Nokia 6085 speaker problem
It is the microphone that needs to be replaced. Usually it can be replaced no problem, I have done so on the Nokia 6085 myself. But yes, the reason the bluetooth works is because it has its own mic and the mic for the handset has gone bad.
Dec 29, 2009 | Nokia 6085 Cellular Phone
Folks can't hear me when I talk on my blackberry bold but I can hear them. This as only started since I connected with my bluetooth device. Any suggestions? The phone is only 3 months old
This could be caused by a software error in which the phone still thinks the bluetooth is still connected and is still being used as a microphone you can try a couple things here: 1. go to your bluetooth device list on your phone and delete the device 2. try to connect and then disconnect the bluetooth device and see if that returns everything back to normal 3. when you are calling or get called select the blackberry menu which is basically the blackberry icon on the keypad and go and find the option activate headset or something close to that which should activate the speaker on phone which you use for your ear.
I hope this helps,
Kyle
Jul 04, 2009 | RIM BlackBerry Bold 9000 Smartphone
Person I am calling cannot hear me
Based on the information provided it sound like the microphone has malfunctioned and these microphones can be replaced. Can you recall an incident that may have occurred to cause this issue. ie Dropped, exposed to liquid?
Possible temporary solution:
Use a wired / bluetooth headset or speaker phone option.
Where to have repairs done: www.CellularTechnicians.com
Dec 14, 2008 | LG C1500 Cellular Phone
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
