Question about Asrock Computers & Internet
How to connect the front end desk top computer with a ConRoe945 motherboard HDD sw Power on/off sw, Reset sw
ConRoe945G-DVI motherboard, cannot find repair or service manual for wiring schematics to reconnect switches to board
    Brigadier General:
  • Asrock Master
  • 3,400 Answers
Posted on Apr 27, 2015
    Master:
  • 301 Answers
Https://www.youtube.com/watch?v=DPELIdVNZUI
Posted on Apr 28, 2015
  • 34 Answers
SOURCE: How to connect power led ,HDD,Reset,power SW cables in hp motherboard s/n 383620-001
check your motherboard manual if you do not have it go to www.support.hp.com and look for manuals based on the model. this should give you detailed instructions as to which pins you plug those cables into. usually they are located towards the bottom of the motherboard to the right of your PCI Expansion slots
Posted on Aug 20, 2008
VooDooNOFX
  • 95 Answers
SOURCE: Connection to Motherboard P4IBMS
You can download a PDF of the manual here:
http://www.ecsusa.com/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=74&areaid=2&LanID=9
I have blown up the image for you to see it easier:
good luck
steven
Posted on Sep 17, 2008
ardmax
  • 155 Answers
SOURCE: foxconn motherboard pinout
Please follow this link and download the manual.
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0002117
Don't be surprise that the manual name is 662M03, it is still the right manual becuase is made for both type of motherboards.
Posted on Oct 01, 2008
ericram
  • 101 Answers
SOURCE: Front panel connections
You can download the complete user manual in English from the manufacturer's website at this link:)
http://support.asus.com/download/download_item_4.aspx?product=1&model=P4B533&SLanguage=en-us&os=17
The front panel connector pinout is on page 2-33, or page 59 in the PDF file. You should have mor ethan enough information to make all the connections you need.
Posted on Jan 02, 2009
My asrock conroe945g-DVI has no sound at the front panel
has no sound at the front panel ? not sure i understand are you getting any sound or you dont have a sound icon
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
hope this helps
Oct 09, 2012 | Asrock ConRoe945G-DVI Motherboard
I have asrock agp8x p4i65g and don`t know how connect fron power/reset buttons and fron lights. There`re 5 lines power sw, reset sw, H.D.D. led and 2 ampty
yea there are 5 lines one is power switch other is reset the power led then hdd led then in older motherboard there is provision for speaker The power switch is in the front pannel of the motherboard if you have multitester the power which will indicate 5v the power switch is to be conected to the 5v and the ground normally the front pannels details will be given in the motherboard
Mar 28, 2011 | Computers & Internet
I have a GA-81865GME-775-RH motherboard, which i put into my box, made all the connections, but have no power once I switch the box on. I suspect it has something to do with the wiring loom running from...
Hello julian_ad681
I will tell you how wire your case front panel, but before that lets test the motherboard to make sure the problem is not the board itself.
Remove all the wire connections to the front panel.
Turn the power on and with a small screw driver or anything that is metal short (touch) the two pins that are the PWR SW. (look at the list of pins I have put at the end)
If the computer turns on then it means the board is ok.
The following information is also availabe in the motherboard manual available from the gogabyte web site download section
On the motherboard next to the battery is the front panel header pins. it looks like
0 0 0 0 0 0 0 0 i also write them as numbers as well to make it easy for you)
0 0 0 0 0
1 2 3 4 0 0 0 0
5 6 7 8
1 and 2 are message LED. you don't need any connection to this.
3 and 4 are the power switch connections no polarity, just connect the wires
5 and 6 are the hard disk LED. 5 is the positive side (usually red)
7 and 8 are the reset switch. no polarity, just connect the wires.
Next to the message LED there is a three pin connection. This is for the power LED.
hope this has helped you.
please leave comment, vote if the helped
Feb 10, 2011 | Intel Motherboard
How to connect jfp 1
go to www.msi.com.tw for MSI guide , it should show you your motherboards front panel intel connection guide , it should be like this
PSWITCH PLED Open
RESET HDD SPK
Jun 08, 2010 | MSI G31M3-L V2 Motherboard
Configuring motherboard powerswitch leds reset
u will find front pannel connection pins on mother board. its in 2 lines. in onle row there is one pin slot idle. next to that vacant pin slot u insert reset sw, next to it insert hdd led, behind hdd led insert power led, next to power led (behind reset sw) insert power sw. thats it done
Jan 06, 2010 | Dell Dimension 2350 PC Desktop
How to connect HDD LED & POWER LED & RESET LED & 2 others who is blue and whid & my SPEAKERS, can you help me here?
don't you have the book for the motherbd? Most motherboards tell you right on them wat connection goes where. look for them they should be in close vicinity of each other Usually.... HDD-Harddrive connection./.RST - Reset /pwr-- to switch ....etc....
Oct 16, 2009 | Asrock ConRoe945G-DVI Motherboard
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Reset sw, power sw, and hdd led where do i put them on the motherboard
hello, your front panel connectors like reset sw, power sw, hdd led, you can search easily. a use of screw driver touch all front panel connectors, if any response of connectors connect it.
Aug 10, 2009 | MSI 745 Ultra (MS-6561-010) Motherboard
I'd like to know the sequence to connect the following connectors:power sw, reset sw, power led, hdd led from the front panel to the motherboard (motherboard foxconn sis 651 m03. Thanks West
If your board is the one in this manual, the pins are located very close to the CMOS battery. Page 21 in that manual shows the diagram. Power LED is the top two left pins. Hard disc LED is the bottom two left pins. Power switch is the top two right pins. Reset switch is pins 3-4 on the bottom row. Pin 5 on the bottom is not used.
Apr 27, 2009 | Foxconn Computers & Internet
Startek ST-693AVA/E front panel connection problem (22 pin block)
you can identify this in your motherboard but just in small letters, they are also written as RESET SW, HDD LED, POWER ON,
Dec 18, 2007 | Computers & Internet
Computers & Internet Logo
299 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
