Question about Irulu 7" 4gb Google Android 2.3 Touchscreen Tablet Wifi 8gb Micro Sd Card Case Bundle
How do i fix my screen, it won't let me click on the very top part of the tablet but it will let me click on the bottom part.
It won't let me touch the upper part of my tablet but it will let me touch the bottom part of my tablet, It won't let me click on any of my apps unless i go to all apps, But it still won't let me click on anything in the top part.
My tablet comes up to ematic screen but will go no further what can I do to fix it?
Hi Patty, The link below is a YouTube video showing how to fix your phone/tablet, Also there's video's down the right side of the link that may help as well....CHEERS..
https://www.youtube.com/watch?v=0PAB6khykWE
How To fix any Android Phone Tablet that won turn on
Apr 29, 2016 | Ematic 8GB Pro Series 8" Multi-Touch...
My screen is reversed. You have to touch the opposite side of the tablet to select what you want and I just want to know how to fix that.
Here are suggestions I found online:
Press the "font size" key. It should look like Aa or some similar marking. When you click that, you should be able to change the orientation. Use the 5 way controller to move the "selection" up and down and left and right. and then press it when you are over the desired rotation. You want to select the very first A selection
Mar 03, 2015 | Tablets & eReaders
How do I fix the top of my screen to make it touch screen again?
Dropping these devices is not a good idea as the damage might be permanent. However there might be a screen calibration component in your tablet's settings that could compensate for the lost screen space.
Aug 21, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
I can't get my tablet to open up all that is on the screen is a + sign and the home symbol and others at the bottom of the screen. When I touch the + sign it just moves to a different corner of the s
It is in touch screen configuration mode. Click on the crosses as it works out where edges of the screen are. Then it should return to normal.
Jun 28, 2014 | Kocaso Tablets & eReaders
Screen flipped
I spoke with Kocaso...no fix yet, so I returned mine...I had the M9100...junk!
Jan 12, 2014 | Kocaso M752 Black WiFi 7" Android Tablet...
My zeepad screen has spiderwebed and won't register touch anylonger. is it fixable
Most places even if you have a warranty wont fix a broken screen mine has the same problem so i bought a digitized touch screen replacement on Amazon.
Feb 23, 2013 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
7" touch andoid tablet won't charge
It may be the charger has a loose wire. In that case a new charger would fix the problem. Mine has a problem with the charging port itself. I am fortunatly that my tablet is under warrenty they are going to replace the tablet for me.
Dec 27, 2012 | Nextbook Premium 7 Capacitive Touch...
Irulu tablet user manual
Can this tablet hook up to a printer?
Jun 12, 2012 | Tablets & eReaders
Something happened to where when i use the pen there is this area on the screen that will not allow the pen to touch that area of the screen or go near it, it just skips it, why?
This seems to be a common problem with this Toshiba. I squeeze the molding around the screen near the areas that the touch screen is not working. It usually happends in long blocks that don't respond to the pen.Press along the top sides and bottom running along all the edges with pressure. You may have to work with it a few times but it seems the fix mine for a while.. hope this helps
Oct 02, 2010 | Toshiba Portege 3500 Tablet PC
Irulu 7" 4gb Google Android 2.3 Touchscreen Tablet Wifi 8gb Micro Sd Card Case Bundle Logo
49 people viewed this question
Top Irulu Tablets & eReaders Experts
David Clark
David Clark
john smith
David Harrelson
David Harrelson
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
