Question about Garden
How do I fix an exmark mower that won't start
Ran for awhile than won't start I think is a safety switch
    Top Expert:
  • Garden Master
  • 51,484 Answers
Cold be 1 of many things you got the make listed but no model walk behind , rider . check fuel filter ans hoses leading to the fuel pump I had 1 collapse on me last year .
Posted on Apr 25, 2015
When I turn on my pto motor shuts down. On my exmark lazed z ct 48"
bad safety or pto switch. somewhere. start at the seat switch.
Jun 29, 2016 | Garden
Safety switch on brake handlechecks ok but motor cuts off when released
check clutch safty switch or seat safty got to be one of those switches
Oct 03, 2014 | Kohler Engines Kohler Command OHV...
Can't get exmark mower with Kawasaki motor to start
Have had this problem with the Kawasaki engines and found the starter to be bad. The old starter was turning it over but was not fast enough to start. Have also found weak battery that did the same. The first one I ran into was a FH680 Kawasaki and spent about 2 hours trying to figure it out and it came down to the starter not turning it fast enough. Put a new starter on and started at just the bump of the switch. Let me know if this helps you out
Apr 26, 2014 | Garden
Electrical problem?
I had the same problem with my exmark. I found that there was a yellow wire that has a deans connector that plugs in around the backside area of the key ignition. that wire vibrated off. check that, it may fix it. good luck!..
Dec 07, 2013 | Husqvarna EZ4824 24 hp 48" Zero Turn Lawn...
Exmark electric clutch problem
one side of the connector gong to the clutch needs to be a ground
Aug 21, 2012 | Encore EXMARK LAWN MOWER HEAVYDUTY STEEL...
How can I move my exmark zero turn lawn mower when it won't start?
on the rear of the machine there is a release lever for each side pull that back and down to lock it in place
Jul 12, 2012 | Garden
My 50" troy bilt zero
All riding mowers have a seat safety, blade engage safety and a brake clutch safety, some mowers have a reverse mowing safety. Seat under the seat, blade and brake you will have to check the linkages underneath, and if there is a reverse mowing one I have seen them near the shifter handle right under the fender.
Aug 23, 2011 | Garden
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
Garden Logo
90 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
