Question about Home Security
Does model 463 837 support LED bulbs? Which type?
My led lights start to strobe when I turn on exterior light that is fed from the same line circuit. Solution?
There are two things coming into play here; the lamps and the dimmer(s).
First; LED and CFL type lamps that are to be used on a dimmer switch - must be identified for that use. Looks for the word dimmable on the packaging or bulb itself. These lamps are generally a little more expensive than their non-dimmable counterparts. If it does not indicate it is dimmable, then it isn't - and should not be installed on a circuit controlled by a dimmer switch.
Second; a dimmer switch that will be used to control LED and CFL bulbs (that are identified for use with a dimmer) must also be identified for use with dimmable LED and CFL bulbs. Again, these dimmer switches will be identified for this use and will cost more than those that work with standard filament type bulbs.
Lutron has dimmers for your circuit called a "C•L™ Dimmer" and supports Incandescent / Halogen, Dimmable Compact Fluorescent (CFL) and Dimmable Light Emitting Diodes (LED) type lamps. have a look here:
Lutron Maestro Dimmer and Switch Models
Also, be wary of the total load (wattage) of the lamps being controlled. If you have multiple dimmers in the same box, derating of the switch's wattage capacity (due to increased heat) will be required.
Dec 03, 2015 | Maestro Electrical Supplies
How can i replace a 491868 bulb with an led bulb?
Unless that is an LED number , I would replace it with the same type bulb. Bulbs are rated for different types of services and the LED you might choose might not be rated the same.
Sep 05, 2014 | Thermador Refrigerators
Led 1157 bulbs don't turn on when pluged in ? can any one help?
There may be various reasons for this issue. It is most likely that your LED bulb is defective.
In such case, I would like to recommend you replace the particular LED bulb with a new one.
You can easily replace it with a free trial and with 5 years of warranty from LED High Bay Lighting. Here, you can easily get high quality and affordable lighting solutions.
May 20, 2014 | Generic 12 Volt LED Trailer Tail Light Kit
I need a replacement screen and i'm not sure which cffl/backlight to order
Here are the eBay search results for your exact system model -
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=Toshiba+Satellite+L355D-S7809+screen&_sacat=0
Sep 20, 2012 | Toshiba Satellite L355D-S7809 NoteBook AMD...
When failed trun signal bulb, Jeep turning signal is fastly blinking. I changed rear turn signal bulb with LED bulb, but turn signal blinking speed doesn't go to normal, At first couple of seconds it is...
Try replacing with the same bulb type as was failed. Flasher unit isusually reliant on resistence from the bulbs to what speed that side will flash at when powered.Some of these led type have less resistence and that equates to a faster flash speed.That is why when one bulb blows that side will flash faster or may even stay on without flashing.You could even swap the led to the other side( to confirm.Check with the bulb retailer to whether they have those bulbs with a higher rated resistence in led.If this vehicle has leds as standard,you may need to get the correct type from dealer. Hope this helps or get back with findings if it still has fault after replacing bulb.
Mar 29, 2011 | 2009 Jeep Patriot
Burning Tail Light 999
I've heard that using plate re-locators and after-market exhausts can cause vibration that'll break the filaments in the bulbs. I just had a turn signal go out this morning. The (very standard and readily available) model 5008 is the direct replacement for the turn signal bulbs and a 2-pack at the auto store (Autozone, etc) is $1.75 or so. 12 volt, 10 watt. There are LED replacements for them that won't break, but since the stock bulb is 10 watts, you'd be hard pressed to find an LED bulb that puts out that brightness. If you go LED, you also have to make sure it has a resistor built in. LED bulbs intended for turn signal use have them, ones for brake lights etc don't. PS: I think the brake/ running light bulb is an 1157, dual filament. I haven't had to replace that one yet though so I'm not sure, check it first!!!
Nov 20, 2008 | 2006 Ducati 999 R Xerox
Home Security Logo
583 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
