Question about Frigidaire FAC126P1 wall/window Air Conditioner
Can i plug a 110 air conditioners into a 220 plug in
  • Frigidaire Master
  • 3,519 Answers
Hi Shawn:
A 110 air conditioner would only use 1/2 of the available 220, so , the answer is yes, with a great BIG CAUTION!!!!!
You have to know how to safely wire in the appropriate plug.
- 220 usually will have 4 wires: Red, Black, White, and Green.
You get 220 between the red and black, the White is available for 110 to drive a fan or whatever.
- 220 sometimes only has 3 wires: Red, Black, and green
Here you have 220 with no 110, like a baseboard heater.
- 110 has 3 wires: RED OR BLACK, White, and Green.
You get 110 between the Red or Black and the white.
The White is called Neutral.
Do not use the green wire as a neutral if there is no white.
The green wire is a ground and is for safety purposes.
PLEASE!!!! If this is not perfectly clear and within your ability, DO NOT TRY TO WIRE IT! Get someone who is trade certified to help you. Also, don't even think about messing with the wiring unless the circuit breaker is turned off..
Posted on Apr 25, 2015
  • Frigidaire Master
  • 3,957 Answers
Before you damage your equipment, or even worse electrocute yourself, seek the advice of an electrician. From the unit your describe (window air conditioner) I doubt you are going to have a 4 prong 220V outlet available to tap one side off. This being the fact, if you adapt and plug into a 3 prong 220V outlet, all the smoke is going to leak out of your air conditioner, and there is no way to get it all back in. In other words - proceed with caution and seek professional help.
    Master:
  • 369 Answers
The configuration of the 120 and the 220 (250) volt receptacle outlets are different and can not.
  • Ted Maxwell Apr 26, 2015
    Thanks Jorge, Appreciate the feedback.
What do i have to do to plug my 110 air conditioner into where my 220 window unit
You need a step down transformer, to convert 220V to 110V. You can't just plug the 110V A/C unit in directly unless it is clearly marked as being suitable for multi-voltage supply (110V - 220V input).
Such a transformer has to be of sufficient capacity to handle the current, or wattage, that will be required. The Frigidaire unit in your question is a 3.5 kW cooling capacity, so the transformer would need to be about the same, ie for a 10A supply at least. They are quite big boxes, about $120.
http://welectronics.com/TRANSFORMERS/step-up-down.JPG
You would put this in the roof or in a cupboard.
Apr 25, 2015 | Frigidaire FAC126P1 wall/window Air...
My Sun beam 7500 is not cooling my bedroom.
Im not sure if this is an 110 or 220 unit but if it is 220 checheck both power pins at plug to se that u have 110 at each one
Jul 09, 2012 | Heating & Cooling
I have a 220 volt crape maker from France. Can i change the cord on it to be used in a 110 outlet? Will it still heat up enough with 110 volts?
Unfortunately, it will probably not heat up enough on 110 volts. You could change the male plug on the end of the cord to fit your 220 volt air conditioner or cloths dryer female plug.
Dec 03, 2010 | Kitchen Appliances - Others
What type of wall plug can I use for this air conditioner! My whole house is 110 or 220
If it is a 110 unit,use a regular wall receptacle ,if it is a 220 unit,use a 220 receptacle for 220 it will be made larger and different.Draw a picture of the plug on the end of the cord and go to the hardware store and get them to help you i d the plug.some 110 units are 40 amp,and are a little different than the regular 110 house hold 20 amp receptacle.
Sep 15, 2010 | Airtemp B3Q06F2A Air Conditioner
Is it a 110 or a 220?
Hello SUEK,The plug end WILL not fit a standard outlet if it is 220v.IT gets a special plug/outlet match!
Jul 26, 2010 | Carrier YCB243D Air Conditioner
My window air conditioner will not start. First time installed this season.
Make sure you have the correct line voltage at the plug.Some are 110 volt, some are 220 volt.
Here is the kicker...220 volt can be plugged into 110 volt plug at the wall with no damage.110 volt cannot be plugged into a 220volt socket at the wall without sustaining damage.
You can find out the required operating voltage of the a/c by reading the nameplate data printed on the a/c specs somewhere on the machine(not the housing}.
The plug end from the a/c should clue you into the proper machine voltage if you purchased a brand made in the USA.If it came from some third world country like Bangladesh, for example, the cheap bastards probably didn't wire the pigtail in at time of manufacture cause they are cheap ********.
You get what you pay for these days.
Call an electrician to chech it out.Don't be like the Bangladeshians!
Aug 02, 2009 | Haier Heating & Cooling
GE ASM10AK 10,200 BTU Room Air Conditioner is 115 volt, but it blows the circuit regularly becasue it has many other devices on it (IE computer, PS3, WII, LCD TV etc.). I have a 220 outlet on a separate...
It would be easier to change the 220 circuit in your house to a 110 by some creative work in the breaker panel and making it an air condtioner circuit only. You would need to check with an electrician, but would probably be worth it in the long run.
Mar 29, 2009 | Heating & Cooling
Circuit breaker
ngfam1
Happy to assist,
HOW MANY BTU IS THE AIR CONDITIONER?
And is it 110 or 220 line!
If it is using 110 or 115 volts like normal house current and it throws circuit breakers in your electric box,then you need to run a dedicated line just for the Air Conditioner!
Usually this happens to 110 -115 volt air-conditioners that are more than 12,000 BTU and do not have a dedicated electric line in the wall only for the air conditioner!
New air conditioners have a circuit breaker built into the units plug!
And I have seen some that throw that breaker to off frequently even if it's only an electric surge! Which it should not do!
if its the case and it's new, take it back to the store and ask for a different model, size, or brand!
Fedders had an 18,000 BTU/ 110-115 volt unit that did this with every single unit last year! I stopped selling that unit only!!
Ngfam1
PLEASE GIVE ME A GOOD RATING HERE FIXYA.COM BEFORE YOU SIGN OFF!
you can just use it as is as long as it survives!
Aug 29, 2008 | Amana PTH123B35AJ Air Conditioner
Frigidaire FAC126P1 wall/window Air Conditioner Logo
98 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
