LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
