Question about Music
How to post an item for sall - Music
    Top Expert:
  • Music Master
  • 3,130 Answers
This will vary depending on where you want to post your item for sale. Please be more specific.
Posted on Apr 25, 2015
  • Music Master
  • 5,631 Answers
Do you mean TO SELL? Where do you want to sell? If you want to sell on e-bay, you should sign up first.
Posted on Apr 24, 2015
What kind is footswich.it's broken and i have to change it
We will need more information to help you. What make and model is both the footswitch and the item you are trying to connect to? What is the switch supposed to do, and what is it doing now?
BTW- Most items like this are available either direct from the manufacturer, on Ebay, or on Amazon.
Jun 29, 2015 | Music
Hi..my ferder serial is s/n cy98110800....do you know the year and price of the guitar?
Fender Forums View topic Age of my Squier
its a 1998 model..
CY: Y = Yako (Taiwan) C = China. CY is followed by 2-digit year. CY appears on most models produced in China, and is by far the most common form. These forms are apparently associated with the change to Crafted in China, so post-1996 models only would have this form of serial number.
Some Chinese Gretsch's use a CY serial number.
As far as price goes....that is all up to you but i would check on Ebay and craigslist and look at completed or sold items and see whats trending.. Good luck
Feb 17, 2015 | Fender Music
I want to set up my behringer fbq1502
It sounds as if you are not running in series. I assume you are in an insert on the mic channel. The insert send should go to the first item in the chain, then from the output of that to the input on the next item and so on until the output of the final item in the chain goes back to the return on the insert. This is applicable to the type of equipment you have detailed, in some cases however you may be running effects in parallel. Your case is definitely a series situation.
Mar 08, 2014 | Behringer FBQ1502 Ultragraph Pro Dual...
Need to identify and find parts for the Pearl FZH725/C85 Drum Kit. It was delivered with missing parts. Specifically Floor tom, 14" tom and arms to hold it. Need some direction and guidance, thanks.
I am a drummer as well in a classic rock band. Most the time when I need a part for something for my drums. I will go to guitar center. But to save money eBay is your best bet. You go to guitar center to make sure you have the right part, but don't buy it there . Match it up and go to eBay, lot of drum companies use eBay to sell there stuff. Thanks mike
Jul 22, 2011 | Pearl Forum FZH725/C85 Drum Kit, Zenith...
Incomplete manual for the 2442USB...no real information on the foot pedal use. If the foot pedal is being installed, does this turn off the FX in the standard mix? When will they write one manual for one...
Yes, the foot pedal turns off the internal FX whatever the FX is set to... Yeah, I would rather have the manual for several items than a monstrous manual with 5 different languages to sort through...
On page 15 of your user manual the footswitch is discussed. It appears that the footswitch toggles the effects on and off... that is each press reverses the state and there is an indicator on the panel showing whether it is on or off.
Jun 27, 2011 | Behringer XENYX 2442FX Mixer
Where power supply goes into is broken and hanging out of deskcan this be replaced and where
you can take it to your local shop that you bought it from or contact Mackie and they might be able to do something for you
May 09, 2011 | Mackie ProFX12 Professional Compact Mixer
Hi! I need two input/output plates for my Kustom floor monitors (KSC10ML). By input/output plate, I mean the unit that has the volume knob plus the two input/ output jacks that is screwed ino the side...
The KSC10ML has NO volume control... only two 1/4 inch jacks. To get a matching "jack cup" you will probably have to go to Kustom. I have searched for the item on the web and only jack cups that seem to come up are for Marshall or ones that use binding posts. I found one blank one but it is 5 by 7 inches... too big for that Kustom cabinet. In a pinch if you don't need it to be recessed, cut metal or ABS plastic plates and drill for two jacks.
Apr 16, 2011 | Kustom KSC10ML PA Monitor
I want to know how much my marshall g15rcd amp is worth
Used small amps don't bring much money...
The best answer can be found by searching for COMPLETED ITEMS on eBay for like items.
Oct 03, 2010 | Marshall 15 Watt Guitar Amp
Hi. I purchased some Grover Rotomatic tuners on my electric guitar and am having difficulties figuring out how to put the strings through them. Normally where there should be a hole where the strings go...
If you see a hole on the thumbscrew post, you have to line it up with the hole in the solid post by screwing it in or out until it does. Then you put the string through. Hope this helps.
Jul 02, 2010 | Grover 205c Mini Rotomatic Guitar Tuners...
Music Logo
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
