Question about Electrical Supplies
It only produces electricity for about a minute then stops and a red light comes on the internal control board.
    Top Expert:
  • 47,659 Answers
Contact the manufacturer tech support .
Posted on Apr 25, 2015
82822 / 82824 / 82826 Electric Dryer: kenmore HE2 electric dryer, beeps and all display ...
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 17, 2010 | Kenmore 82822 Electric Dryer
Kenmore dryer model # 11067072600 I am getting a F40 error code after 3-4 minutes in any cycle and then the dryer stops. I have checked all connections & continuity. During the diagnostics test mode...
i would have to guess that its a problem with the control board. if it were the user interface it would most likely fail right away and not after a few minutes.
either one are expensive, but the board should cost about 120 bucks
Mar 13, 2010 | Dryers
Whirlpool Duet Sport WFW8300SW02. makes a loud buzzing noise when we try to start a program and red light comes on to indicate the door is locked. the code F-01 comes on the display.
Nov 11, 2009 | Whirlpool WFW8300SW
Hi. My oven displays F7 in red and next to that
HI. This f-7 is indicating that the touch pad is malfunctioning. Follow the procedure below to address further.
Determine if the problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
NOTE( If your unit is equipped with an integrated touch pad, and control board, you will need to replace the entire control board in this case)
Nov 02, 2009 | GE Ovens
Control panel looks ok but dryer wont start
Sounds like an electronic problem on the timer circuit board.
Aug 11, 2009 | Siemens WT79020EU Electric Dryer
Not coming on-tries 9 times Then stops
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic chargesaccumulating on capacitors, or because of a wrong voltage read by themain chip on your monitor controller board. this started the protectioncircuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jul 02, 2009 | Televison & Video
Kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Jun 12, 2009 | Kenmore 82822 Electric Dryer
KENMORE MOD. 417.84092....RUNS FOR A MINUTE ORTWO OR FIVE / STOPS. HEATS UP OK BUT WON'T RUN FOR MORE THAN A FEW MINUTES. ERROR CODE E9E.
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Jun 05, 2009 | Kenmore 62602 Electric Dryer
Panasonic TH-42PD25 power problem
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Dec 06, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Electrical Supplies Logo
43 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
