My pa60e7000ffza just made a loud pop and everything turned off and I smell burnt plastic. Help
    Top Expert:
  • Televison & ... Master
  • 44,327 Answers
Throw away and buy a new one
Posted on Apr 25, 2015
2 Suggested Answers
  • 92 Answers
SOURCE: A loud pop came from inside the TV causing the
Vizio, AKA LG.
This is a common fault, your set needs a Z-Sustain PCB.
To give you the part number I would need the actual TV model number.
However, looking at the TV from the rear, it would be the farthest most board to the Right Hand side, it is positioned in the centre of the screen, connected by 2 / 3 ribbons one side and a couple of cables the other.
A TV repair shop should be able to fix it pretty easily. If not cheaply.
Posted on Sep 07, 2009
Plugged in new oven heard a pop and a burnt plastic smell oven is dead
Call for warranty service it is in the owners manual I had a customer 2 weeks ago plugged in a 120VAC oven into a 120VAC outlet that was wired for 208/240VAC doubt if thats your problem but call for service
Jan 30, 2014 | Maytag 24" Built-In Single Electric Wall...
Loud pop then dead....
if I had a photo of the part is sent. the piece has this number (920p01601) (00x19lb this num. was blurry)
Jul 30, 2012 | Mitsubishi WS-55807 TV
My son put foil on the tip of a light bulb and screwed it into the socket well when he turn the light on i heard a loud pop. the dimmer swtich looks ans smell burnt how can i fix this?
If your dimmer smells burned, it probably is.
As general rule, there are no repair parts for in-wall electrical devices since they are contained inside sealed plastic shell to prevent fires.
The burning smell was high heat and melting that would have caused a fire if in-wall electrical devices were sold without safeguards.
Replace dimmer.
Be sure to check watt rating on side of old and new dimmers to match correct load rating.
Take out of son's allowance, and make the future electrical genius help read small print on instructions and install new device.
Turn power off to replace device.
Use non-contact voltage tester to check that power is off.
http://waterheatertimer.org/How-to-select-right-wire-nut.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Jul 24, 2012 | Lutron Ivory - Ariadni Dimmer - Magnetic...
2006 Chevy Equinox Smoke emitting from the steering column with smell of burnt plastic. I have popped off the harness cover but not been able to deduct source of smell or any damaged...
Turn signal switch is common issue, the plactic melts when the contacts overheat. look for discolored or malformed plastic, near wires and contacts.
Sep 21, 2010 | Chevrolet Equinox Cars & Trucks
Last night I heard a loud pop sound come from my computer and then it shut down. I tried to start up the computer but it didn't turn on. None of the fans turned on either so I concluded something is wrong...
Yes, and the power supply needs replacing.
4 screws hold the power supply to the cabinet or case these are usually located outside visible at the fan vents at the four corners.
Apr 19, 2010 | Ultra Products Ultra LS500 Lifetime Series...
Microwave not heating and giving burnt plastic smell
STOP USING IT!! UNPLUG IT!! Microwaves are inexpensive now. It will cost you more than a new one costs, to get it fixed.
Apr 02, 2010 | Microwave Ovens
Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Olympus E-500 flash smelling like burnt plastic
You should contact Olympus about this.
Olympus have had a recall on some older 35mm film cameras for problems with the flash circuit.
Please see -
Olympus Recall
http://www.olympusamerica.com/cpg_section/cpg_recall.asp
Hope this helps,
Vincent
Jul 08, 2008 | Olympus EVOLT E-500 Digital Camera
Dryer smelled of burning plastic, smoked stopped turning on
check the power cord itself, if you see on the back side of the cord a burnt or blackened spot then the cord is the issue
Apr 12, 2008 | Dryers
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
