Question about Microsoft Windows Server Standard 2003 for PC
How to make smartcard logon as default logon for windows
I want to make the smartcard logon for windows as the default logon
  • prabhakar Nov 15, 2007
    i know the process u sugessted.but i want to make the smart card log on as the only logon to windows
  • 4,889 Answers
Check this out..
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q281245
Posted on Nov 15, 2007
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
Using smart cards with Windows 2000/XP is a two-fold problem.
First, you need to have the card manufacturer's Cryptographic Service Provider (CSP) installed. For Windows 2000/XP, the Schlumberger and Gemplus CSPs are installed and using a "Win2K Compatible" card from either of these vendors does not require the installation of additional software.
The second part to the involves getting a certificate in the correct format onto the card. Assuming you are refering to PKINIT, you will need to have a card with only a single certificate that follows Microsoft's "Smart Card Logon" profile. Additionally, you will need to do some configuration on the Active Directory side to make it work.
Microsoft summerizes the process in the following Knowledge Base article:
Smartcard cannot be forwarded to Terminal Server via RDP
Try re-registering the services on the client computer and see if that fixes it. Otherwise I would consider reinstalling Windows on the client.
Feb 11, 2014 | Microsoft Windows 7 Professional 64 Bit 3...
Tip
How to Recover Windows 2000 Password
Forgot administrator password on a system running Windows 2000 can be problematic when the administrator to perform maintenance. There is a trick that allows a computer user to reset his password, if you forgot. The process to recover a password in Windows 2003 and XP is different from the process used for Windows NT and Windows 2000.
Step 1. Insert the installation CD of Windows 2000 / DVD into the drive of the computer and then restart the computer.
Step 2. Select the destination directory for the alternative Windows operating system when the program asks you to do. This directory is not the same as the default installation of Windows. This is the computer is a dual-boot system.
Step 3. When the computer restarts, select the alternate Windows installation from the dual-boot menu.
Step 4. Find the logon.scr file. It should be located in the %systemroot%\System32 folder of the Windows folder.
Step 5. Rename logon.scr and move it into the C: folder of the hard drive. You can choose to move it to a different directory. The important thing is to remember where the file gets copied.
Step 6. Find cmd.exe and make a copy of it in the %systemroot%\System32 folder. Move this file to the C: folder of your hard drive.
Step 7. Right-click on the original cmd.exe file and select "Rename." Delete the cmd.exe text and replace it with logon.scr.
Step 8. Restart the computer and start Windows installation. Do not touch the computer until the start of the screensaver. Since the screen saver file, get the default is replaced with the file cmd.exe, then a command prompt instead of the screen saver.
Step 9. At this prompt type: net user administrator <password>
Step 10. Delete logon.scr from the %systemroot%\system32 folder.
Step 11. Issue the following commands from the command prompt:
copy c:\logon.scr c:\windows\%systemroot\system32
copy c:\cmd.exe c:\windows\%systemroot\system 32
Step 12. Restart the computer in the original. From here you can remove the additional installation if desired. If the administrator installation alternatives are on a different drive or partition to reformat the hard disk or partition is the easiest way to achieve this goal.
on Apr 26, 2010 | Computers & Internet
Tip
How to enable the NUM LOCK key for the logon screen
The status of the NUM LOCK key is specific for each user, and it is disabled by default. If you want the NUM LOCK key enabled for use before a user presses CTRL+ALT+DEL to log on (the logon desktop), you need to edit the registry. To enable NUM LOCK for the Logon desktop (shown when no user is logged on), use the steps below:
  • Click Start, Run and type regedit.exe
  • Navigate to the following location:
HKEY_USERS\.Default\Control Panel\Keyboard
  • Double-click the value InitialKeyboardIndicators
  • Set the value-data from 0 to 2
  • Close Regedit
To undo the above, change the InitialKeyboardIndicators value back to 0
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
My power glitched, now when i try to log in to windows my password isn't recognized. i've tried everything.
By default xp has an unsecured adminstrator account. At the logon screen press Ctl + Alt + Del twice to bring up the standard logon dialogue box. Type the username "administrator" without the quotation marks. Leave the password empty. Press ok to login. Hopefully that gets you logged on to windows so you can reset your user account
Jan 12, 2014 | Microsoft Windows XP Professional With...
Hi, when i try to install cisco vpn on my xp machine, it is throwing 1721 error.
Cisco VPN Client for Windows Vista, release 5.0.0.340, does not support the following:
blank.gifMicrosoft Windows NT, 98, and ME.
blank.gifSystem upgraded from Windows XP or earlier Windows operating systems to Vista. (Clean OS installation required.)
blank.gifCombination of Cisco Unified Video Advantage 2.1.2 and McAfee HIPS Patch 4 Build 688. To avoid system failures, uninstall either of these two applications, upgrade McAfee to the latest version, or use VPN Client 4.6.x.
blank.gifStart Before Logon.
blank.gifSmartCard authentication.
blank.gifIntegrated firewall
blank.gifInstallShield.
blank.gifAuto Update.
blank.gifTranslated Online Help. Online Help is provided only in English.
blank.gif64-bit Windows operating systems. For x-64 support, customers should explore with their Cisco sales representative the use of the next-generation Cisco AnyConnect VPN Client.
Nov 04, 2010 | Microsoft Windows XP Professional
Tip
Applying the settings to the logon desktop
Next, you need to apply the Screensaver settings to the Logon Desktop / Welcome Screen (Technically, HKEY_USERS\.Default registry key), so that the Screensaver is invoked when no user is logged on. Copying all the Screensaver settings to the Logon Desktop (or Welcome Screen) manually is a tough task. Use Tweak UI instead.
Download and install TweakUI.
Launch TweakUI and click Logon, click Settings.
Select Screensaver from the list box and choose Copy Now
The Screensaver settings are applied to the Logon Desktop
Restart Windows for the changes to take effect
Allow few minutes at the Logon screen, to test if the Screensaver is working properly. The Screensaver should launch after the timeout. It will look as if the Company Logo moves around.
Additional Tip
The User interface / slider allows the minimum value for picture change interval to 6 seconds only. To reduce the change interval to less than 6 seconds, alter the registry value named ChangeInterval (Set decimal value 1000 for 1 Second, and so forth) in this key:
HKEY_USERS \ .DEFAULT \ Control Panel \ Screen Saver.Slideshow
For Current user profile, make the change here:
HKEY_CURRENT_USER \ Control Panel \ Screen Saver.Slideshow
With no logon wallpaper set, Windows displays a pre-defined color for the logon desktop. ( If you have enabled Welcome Screen, press CTRL+ALT+DEL twice to see the logon screen background color. ) To change the logon background color to that of your choice, you need to alter the registry:
Click Start, Run and type REGEDIT and press Enter
Navigate to the following key:
HKEY_USERS\.DEFAULT\Control Panel\Colors
Backup the registry key by exporting to a REG file
In the right pane, double-click Background
In the Edit String dialog box, type the Color code in R G B format and then click OK.
Example: Type 0 0 0 if you want to see a Black background. You can choose any combination from 0-255
Points to ponder
If the logon Wallpaper is set, the background Color may not be visible. So, you must reset the Wallpaper value to a blank string in this key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
If the Background value is set under the following Winlogon registry key, the above setting is ignored. In other words, the Winlogon\Background value takes precedence over the .DEFAULT..\Background value.
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
DigitalPersona not visable on Windows XP Logon Screen
Don't connect to the internet with Windows XP, it is too dangerous.
May 20, 2017 | DigitalPersona DIGITAL PERSONA USB...
How to change the Windows Logon screen saver from GPO
OK I know how to change the logon screen saver. I have a small batch
file to do it as part of our install process and it works. What I
would like to do is use our university logo and have it move around
the screen.
How do I have my scr file move around the screen like logon.scr ?
---blank-scr.bat---
:: Install a blank screen saver
@echo off
copy /y %Z%\packages\blank.scr %WinDir%\system32
:: Change logo screenscaver from logon.scr to blank.scr
reg add "HKU\.DEFAULT\Control Panel\Desktop" /v SCRNSAVE.EXE /t REG_SZ
/d blank.scr /f > nul
:: Change blanking time to 60 seconds
reg add "HKU\.DEFAULT\Control Panel\Desktop" /v ScreenSaveTimeOut /t
REG_SZ /d 60 /f > nul
Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 11, 2009 | Microsoft Windows Server 2008 Enterprise...
PlatinumPAS ? preboot authentication services verify please insert a valid smartcard
Under the keyboard have a switch. Set the key number 3 in "ON". that's all folks.....
Feb 27, 2008 | Acer TravelMate 613TXV Notebook
Pssword lock out
If you still can't find the solution try this thread: http://www.fixya.com/support/t156781-forgot_administrator_password
Oct 09, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows Server Standard 2003 for PC Logo
1,320 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
