Question about Amana Washing Machines
What wires do I jump on my Amana top load washer for lid lock?
    Top Expert:
  • Amana Master
  • 45,493 Answers
The wires on the back of the lid micro switch
Posted on Apr 25, 2015
  • 641 Answers
SOURCE: Kenmore Model 27032 lid problems
Look for the lid switch and press on it manually. Let me know if it will operate the machine.
Posted on Sep 12, 2007
  • 37 Answers
SOURCE: Maytag Washer lid switch
Ohm out the blue/ blk terminals on the sw (remove wire harnes first and notate wire color connection) with an ohmmeter-- Reading should be zero (closed lid position)
Then ohm the ylw and white sw terminals-- reading should be 0 as well.
If I am not mistaken this sw has a plunger that sticks out, if hte unit goes off balance this could push the plunger in. to reset- pull the plunger out
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
Posted on Jun 20, 2009
  • 572 Answers
SOURCE: The lid will not lock on my Whirlpool Cabrio
id change the door switch
Posted on Feb 06, 2010
SOURCE: amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
Posted on Nov 18, 2010
tbirdfan1
  • 3051 Answers
SOURCE: amana front load washer error code "nd". Door is
Hello there and welcome to fixya
From what you're describing it sounds like the drain pump is blocked. The nd error code indicates "no drain". If the unit can't drain it won't spin. You're going to have to slide the washer out far enough to remove the rear panel; be careful not to damage the floor. Once you get the rear panel off you will see the pump. Be sure to have plenty of towels & a small container to catch water. I am sending you instructions from the service manual to remove and replace the pump. Another possibility is the drain line is blocked or something is stuck in the tub to pump hose.
Posted on Nov 05, 2011
Can i bypass the lid lock on a amana washer model ntw4605ew
Can you do it? Yes.
Do I recommend it? NO.
The lid lock it to prevent injury to the people near the washer, as without it stopping the machine, the agitator will turn with the lid open.
So.
If you will open the top up, you should see the lid switch, and you should see the electric wires attached to it.
With the machine unplugged, you can disconnect the wires to the lid switch and attach them to themselves, and the lid switch will then be by-passed.
May 10, 2016 | Amana Washing Machines
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
www.repairclinic.com/.../Washing-Machine...-/Amana-Washing-Machin...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin · Washer is making loud noise ...
Jan 16, 2016 | Amana Washing Machines
I have a Amana top loader washer how do bypass the lid lock so it can wash?..It fill with water then the lid light just blinks because it doesnt lock.
Locate the switch by the lid and simply connect a wire between the two wires going to it to affect a bypass.
Nov 01, 2015 | Amana Washing Machines
Amana top load washer running water in. Is lid suppose to lock while doing this?
it sounds like the logic board has an issue. and is resetting to start then cycles off and back to start.
Sep 24, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Amana washer lid lock wont quit blinking
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
How do i bypass the lid lock switch on my amana top load washer
I had that problem with a top loader and wedged half of a wooden clothespin between the lid and the switch to close it. Problem solved!
Feb 18, 2013 | Amana Washing Machines
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
Washing Machines Logo
104 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
