Question about Kenmore Washing Machines
Kenmore heart error code f 02 won't agitate, drain or spin
    Top Expert:
  • Kenmore Master
  • 46,177 Answers
Do not find HEART model thru google or sears but here is link to sears parts
Posted on Apr 25, 2015
  • ray gallant Apr 25, 2015
    http://www.searspartsdirect.com/partsdir...
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet-Error code F 02/wont spin and drain
Yes...the "F02" error code is a "Long Drain" error. The washer will not spin if it cannot drain the tub, first. The following link explains how to diagnose and correct the problem:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
In most cases this is nothing more than a clogged drain pump. Folow the steps outlined in teh link provided on how to check and clear the drain pump and drain lines. Now...it does not take much to damage these pumps. If anything has been left in the pump for a significant period of time it can cause irrepairable damage to the pump impeller and/or motor. The result: a drain pump that MAY run, but won't actually pump anything.
If this is the case, you will need to replace the pump. Replacements can be obtained at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Pump and Motor Parts" heading for item number 10. This next link will provide you with the steps necessary to replace the pump (if required):
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 09, 2008
SOURCE: Kenmore 80 series won't spin
If it agitates and drains. leaving your clothes clean but soaking wet. It is most likely the transmission/gearbox. the motor is working otherwise it would not agitate. it is stuck in agitate mode and cannot "shift" into spin mode. new transmission will cost 140-170 and takes 2 or so hours to replace depending on skill level. total repair cost parts+labor $300ish you may want to ante up for a new machine at this point. if you cant to the labor yourself.
part# should be this: tho double check using your own model#
Part # AP3096209
Posted on Dec 09, 2008
futureloginn
  • 734 Answers
SOURCE: Kenmore 90 series won't agitate, spin or drain
hello there,
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it. Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline
Posted on Dec 10, 2008
SOURCE: Kenmore 70 Series washer - agitates and drains but does not spin
my kenmor washes and drains but does not spin, help
Posted on Jun 28, 2009
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Posted on Jul 23, 2011
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
Kenmore washing machine won't agitate?
You are referring to the "agitator dogs". Does the unit run during the wash cycle put the agitator does not move?
Nov 24, 2012 | Kenmore Washing Machines
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Won't finish the wash cycle and flashes the code F 02
This code means that the machine is not evacuating its water.
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Jun 09, 2011 | Kenmore Washing Machines
My washer gives me a 02 F error code and does not spin the water complete the cycle. It just freezes
"F/02" Long Drain
Oct 24, 2009 | Kenmore Elite HE5t Washer
Kenmore Elite: Won't complete cycle
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 18, 2009 | Kenmore Washing Machines
Kenmore agitates doenst spin
blaker, check the lid switch, no spin, no drain, usually a broken lid switch...Catriver...post back.
Sep 15, 2006 | Kenmore 23012 Top Load Washer
Washing Machines Logo
29 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
