Question about AEG Dishwashers
How to fix a c2 error message on an aeg dishwasher?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 58 Answers
C2 error may indicate a pump problem or too slow pump action this may be due to a blockage in the pump or a failed or failing pump capacitor this is not an expensive fix look for a replacement capacitor on Maplins of uk white goods web site you can get the size from the details on printed on the capacitor.
Posted on Apr 25, 2015
  • 1 more comment
  • Crofter Apr 25, 2015
    C2 error can be due to a pump problem or too slow pump action which may be due to a blockage or a failing pump capacitor the pump capacitor is not an expensive fix you can get the details from the information printed on the side of the capacitor.
    C2 Error is usually due to a pump problem too slow an action which may be due to a blockage or a failing or failed pump capacitor which is not an expensive fix you can get the details from the information printed on the capacitor.
I have a oko favorit 4071 doesnt start and display H8 error.
I think this is not the error code. I belive this is hardness of water (could be set from 0 or 1 to 10, depending of model. Read your user manual how to exit the program for adjust the water hardness).
Error code for your appliance depending on model and look like:
i10, i20,i30............ or
C1, C2,C3.............
Dado
Jul 06, 2015 | AEG Dishwashers
I have an aeg dishwasher showing error code 49 what is this and how do I fix it
Error code E49, generally speaking, at AEG dishwasher does not exist.
Dado
Jan 05, 2015 | AEG Dishwashers
AEG dishwasher C2 error
Dear Sir:
Please read the instruction manual for to fix this error.
If you do not have go for free download: www. fitness.manualsonline.com or www. retrevo.com
see the wiring diagram for help.
May 07, 2012 | Dishwashers
Aeg sensorlogic 50700 first showed c2 message; we drained & cleaned filters 3 times; worked half cycle and now showing error message c3?
Error message C3 is most likely indicating the flood switch is triggered. This means water is leaking from under the sump. The C2 error is linked to drain problems which you cleared.
Dec 29, 2010 | AEG Dishwashers
Aeg 60800 dishwasher showing c2 on panel,water still in bottom of dishwasher. will not start.
from other forum
Not pumping or pumping too slow. Check for blockages in pipework, filter and pump. If all clear, replace pump.
Curing the fault on these machines doesn't always get rid of the error code though. Some faults are locked in.
If you find this, post back and I'll try to help.
Mar 11, 2010 | AEG 24 in. Favorit 60800 Free-standing...
AEG 60830 Leak prevention system
Just pulled machine right out, tipped it over on the side, couldn't see anything obvious or a way "in", so re-positioned it - switched on - error message gone and all working fine !!?!
Feb 17, 2009 | AEG 24 in. Favorit 60830 Free-standing...
Code: C 2 ??
C2 error code means, that the drain is clutched.
Removed all dishwasher water with a cup.
Added a gallon of boiled water, waited 10 min and it worked again( so far).
Regards
Sigurd
Jan 28, 2009 | AEG 24 in. Favorit 80800 Free-standing...
C2 error
aeg lavamar error c2
Dec 25, 2008 | Maytag NFW7200TW Front Load Washer
Dishwasher fail on C3 (leak prevention system)
http://www.kunnig-elektro.de/reparatur/spuelen/aeg/zulauf2.html
in German ... anyway a couple of pictures :)
Dec 15, 2007 | AEG 24 in. Favorit 50730W Free-standing...
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
Dishwashers Logo
173 people viewed this question
Top AEG Dishwashers Experts
paulcarew
Kolbrun...
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
