Question about Toys
How do I fix this problem?
Only one back wheel attempts to move at all.
  • Rhonda Wray
    Rhonda Wray Apr 25, 2015
    this is about a barbie mustang
    Top Expert:
  • Toys Master
  • 51,484 Answers
Throw away and buy new one
Posted on Apr 25, 2015
Testimonial: "I don't view this as an expert answer!"
  • ray gallant Apr 25, 2015
    you will sppend a lot fixng then end up having to buy a new one anyway . trying to save you some money SORRY
Telescopic steering wheel wont tilt
Telescopic steering wheel stopped moving - MBWorld.org Forums
mbworld.org/.../225749-telescopic-steering-wheel-stopped-moving.html
Jan 9, 2008 - Telescopic steering wheel stopped moving ... If it won't move at all, and you don't even hear a motor, it could be a fuse; check your fuse diagram ... Steering wheel adjustment motor gone bad?
Jan 28, 2008
HOW TO: Fix power steering column that will not move up and ...
Jul 12, 2007
More results from mbworld.org
Fixing the Power Steering Wheel of a Lexus LS400 - YouTube
? 2:15
https://www.youtube.com/watch?v=NP8YmnGRXWU
Jan 4, 2012 - Uploaded by AutoTech USA
If your power steering wheel is no longer working; moving up and down, back and forth, and when you attempt ...
telescopic and tilt steering not working - Cadillac Forums
Dec 01, 2015 | Cars & Trucks
Chevy transmission
Check the fluid level in the transmission. run the fault codes to check for torque converter clutch and TCM operation. Check that the park brake is actually coming free on being released and not locking up on the rear wheels.
Jan 25, 2014 | 2011 Chevrolet Impala
Riding mower won't move forward or reverse
WHAT MAKE AND MODEL MOWER? YES...YOU EASILY COULD HAVE BROKEN THE AXLE!
SEE IF EACH WHEEL WILL SPIN INDEPENDENTLY OF ONE ANOTHER IN BOTH DIRECTIONS. ALSO, SOME MOWERS HAVE A ENGAGE/DISENGAGE TRANS LEVER (USUALLY PULLS IN AND OUT AND LOCKS WITH A CLEVIS PIN RETAINER)
Jul 26, 2013 | Garden
I just parked my 2001 PT Cruiser to go in gas station. When my 3 year old and I cam back and aatmpted to leave, the ignition was locked and the key wouldn't turn. I also am unable to get the steering...
Grasp the steering wheel and firmly attempt to turn it back and forth while simultaneously turning your ignition key back and forth.
To prevent this from happening again, straighten your wheels before you shut off the ignition.
Jul 03, 2011 | 2001 Chrysler PT Cruiser
2001 Chrysler T&C LT 3.8L FWD Steering wheel and shifter is locked and key will not turn from the off position. Have tried turning the wheel in either direction while trying to turn the key. Have...
Did you pull ******* the steering wheel on the direction that it is locked? Usually rare... But I have seen the springs go bad with the tumblers in the key cylinder. You could attempt to thump under the key cylinder to attempt to bounce the tumblers while moving the key back and forth.
Jun 07, 2017 | 2001 Chrysler Town & Country
I parked my range rovver 2004 model. then after a while i came back and start the car. it started perfectly but the stearing column would'nt turn and its jammed.
take the key out and moved the steering wheel.if moves a little then put key back in and attempt to move again. still doesnt then there might be a problem with your steering pin not retracking back in.causing the pin to stick out.also be alittle rough if steering wheel is turned to hard to one side.turn to side when car on and tryback and forth.to help pin retrack back in and release lock mech.
Aug 17, 2010 | Land Rover Range Rover Cars & Trucks
When attempting to switch from 2-wheel drive to 4-wheel drive on my 94 Jeep, there was an alarming rhythmic clunking sound, so I was forced to switch right back. What could this be?
Your transfer case could be bad, or your front lock hubs need to be locked. Did you switch over while moving or were you static? If switched while moving, you definitely damaged the t/c.
Feb 03, 2010 | 1994 Jeep Cherokee Country
Wheel on 1999 Ford Expedition locking up in reverse
Bad Differential or LR- brake caliper is locking up very bad. I am leaning more towards bad differential-(rear end) Take off differential cover and look inside gear may be broken. Contact if you need more help. thanks for using FIX YA
Jan 13, 2009 | 1999 Ford Expedition
When I move the cursor to play a game, the whole screen moves too
How are you moving the cursor? Is it time to change the batteries in the mouse, if it's cordless...
Use the scroll wheel and the CONTROL key - spin the wheel back and see if the screen shrinks. Then click elsewhere on the screen to make sure you're not dragging the whole gameboard around.
Nov 11, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Toys Logo
216 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
