Question about Associated RC10B4.2RS 1/10 Electric Buggy RTR ASC9042
My team associated ESC and FS-GT3C work fine together but the throttle controls are revesed... It goes backward when I pull the trigger and goes forward when I push the trigger forward
    Top Expert:
  • 10,875 Answers
Reverse the wires on the servo
Posted on Apr 24, 2015
Rc truck
There should be a switch on your controller that says forward or reverse, you can switch it to run the way its supposed to
Mar 31, 2013 | Team International Associated Sc10 Short...
THE FS 46C WEEDEATER WILL IDLE JUST FINE, BUT WILL NOT REV UP WHEN PULLING ON THE TRIGGER. THE THROTTLE CABLE IS NOT DISCONNECTED AND THE CARB IS CLEAN. ANY SUGGESTIONS?
easy... if the carb adjustments are still factory set the you just need to replace the muffler screen or also called a spark arrester.it covers the muffler exit....
Sep 13, 2012 | Stihl FS 85 Weed Eater
My mercury tillr 9.8 shifts backwards with throttle controller
Hi, basically it depends on the control box you have. On some you can fit the shift cable in 2 different positions, each one alters whether the cable pushes or pulls when you shift the gear lever. On others it cant be changed(not common). Regards Phil.
Sep 03, 2012 | Boating
My throttle continues to stick. The motor races and it sounds like the engine is about to explode because of its speed. I opened up the handle and the spring seems out of place. When I squeeze the trigger...
You should see some small wear marks inside the handle where the spring is supposed to rest. Also, check the throttle cable where it exits the plastic engine housing and goes to the throttle plate on the carburetor. Make sure it is connected correctly and not binding on anything on the way to the carburetor. There really aren't any diagrams or pictures available on the net of the insides of a Ryobi weed-trimmer's throttle trigger and spring.
When you squeeze the trigger the steel cable should move, the cable housing should NOT. If you look closely, you will maybe see how it works and all goes together. It is not that complicated.
May 21, 2011 | Ryobi Garden
Goes backwards sometimes not every time
Kind of sounds like the trigger on the remote is having problems completing the circuit for going backwards. Try pressing backwards a bit harder and see if that helps. The only other thing I can think of besides range is maybe the remote or the vehicle is defective or damaged.
Jan 12, 2011 | Cars & Co 110 Mad Truck 4wd Esc Monster Rc...
It wont go in reverse it only goes forward, the steering works fine
Hi
The ESC on this truck comes with a reverse lock out. The reason is that when you're racing, race requirements are that no reverse can be used. Now you may have accidently turned this on. Go to the Traxxas web site and download the ESC manual and follow the instructions for reverse lock out.
May 13, 2010 | Traxxas Stampede Monster Truck Rtrw/Xl 5
My Traxxas Rustler stopped going forwards and backwards as well. The steering does go left and right. When I rev the throttle, the motor revs like it's supposed to but the rear wheels do not move. Per...
The ESC (electronic speed control) is what the battery and motor are connected to. It gets the signal from the receiver and controls the power to the motor. If the motor revs I would check: 1) Make sure set screw is tight on pinion gear on motor. 2) Check gear mesh between pinion and spur gears. 3) Check slipper clutch to make sure it is not too loose, it should only slip for about 12-18 inches when you pull full throttle from a stop. I hope this helps, I will try to answer any questions that I can.
Jan 01, 2010 | Traxxas Stampede Monster Truck Rtrw/Xl 5
Associated RC10B4.2RS 1/10 Electric Buggy RTR ASC9042 Logo
708 people viewed this question
Top Associated Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Associated Toy Expert? Answer questions, earn points and help others
