Question about LG Washing Machines
LG front loader washing machine faults
Worn hoses
  • 1 more comment
  • Brad Brown Apr 24, 2015
    Hi speedhump692, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • speedhump692 Apr 25, 2015
    Thank you but there was enough info already posted
  • speedhump692 Apr 26, 2015
    Sorry Brad - thought you were referring to another problem that came up.
    Genius:
  • LG Master
  • 1,585 Answers
Get a manual
Posted on Apr 30, 2015
SOURCE: Washer LG Model WD-8013F Noisy & vibrates badfly when spinning
I had same problem, the bowl is supported by (2) large springs from the top & two telescoping shock absorbers underneath.
I inverted the machine, found a large hollow retaining plastic bolt had falled out of the shock absorber,causing the bowl to be out of balance & the drive belt to be missaligned.
I reinstated the plastic retaining pin/bolt then tried the machine again.
Now the damn thing refuses to wash or spin.
I'm not happy.
Posted on Nov 06, 2008
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
  • 6 Answers
SOURCE: Hi. My LG 7.5kg Front Loader Washing Machine
Im soory to have to tell you this but i belive it is mostlikley the motor control board and it is worth a couple hundred dollars plus lobour it is the board benith the durm in the front right corner i hope im wrong on this i bet your clother are stuck in there with the door locked full of water there is a trick to draim then unlock the door by pushing in 2 buttons at the some time but i cant think of it right now ill try to post that trick if i recall it latter hope this helped
Posted on Aug 20, 2010
I have wm1814cw lg front loader washing machine with oe light on and not draining we have clean filter unclogged drain hose and reset by unplugging and holding down power putton and start button als
The OE error or fault code indicates that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Sep 16, 2014 | LG Washing Machines
Have a load of washing in my front loader and now my LG wasing machine says 'UE'. What does this mean and how do I fix it?
is this an Lg washer ie error code is an water inlet error machine notices low water pressure , you either have kinked fill hoses , plugged screens in fill hoses coming to you watervalves or watervalve is damaged from foreing debris coming into watervalve .........
Jan 24, 2011 | LG Washing Machines
Lg tromm front loader washer wm0532hw shows oe error
that's draining error. check the filter cleanout behind lower left panel on front of machine; of course drain 1st via small drain hose. if thats o.k the drain pump itself may be jammed with debris or the drain hose could be clogged.
Jun 24, 2010 | LG WM-2277HW Front Load Washer
MACHINE MAKES DOES NOT WASH,WATER OUT FROM DRAINAGE PIPE
is it a top or front loader?is your drain hose same level as top of machine?if not ,raise hose to level and start cycle.machine will not wash if it does not fill.please reply if u need more help
Apr 05, 2010 | LG Washing Machines
My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
Sep 13, 2009 | LG Washing Machines
LG Washer front loader stopped mid wash and is lock can't open door
unplug/plug unit. drain water via hose behind lower left panel on front.
Jun 03, 2009 | LG WM-0532HW Front Load Washer
MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
May 06, 2009 | LG WM2277H Front Load Washer
The front loader for lg washer won't drain
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 29, 2009 | Washing Machines
Washing machine
cloged hoses or pump
kinked drain hose
May 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
37 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
