Question about Garden
I have a yazoo kees 52" cut with the 22 hp kohler command. I can mow for 15-30 min. Then it starts sputtering and shuts off. Is it the fuel pump or something wrong with my carb?
  • 26 Answers
To me it sounds like it could be the ignition coil module could be bad or going bad
Posted on May 11, 2015
  • 3 Answers
SOURCE: Mower runs for 10-15 mins. then shuts off.
I would agree with the gas cap being the problem. There should be a insert inside the cap which helps with the tap pressure. If this is lost then the engine will run for a few min. and shut off.
There is one other thing and that is the float in the carb bowl. It may be allowing in just enough gas to fill the bowl and then it is sticking. This would account for just enough fuel to run for a brief period and then shut down.
VTX Guy
Posted on Mar 10, 2009
shadtremonky
  • 353 Answers
SOURCE: engine coughs and stops after about 15 min. of cutting
check the vacuum line from pump to crank case fo leaks
Posted on Jun 20, 2009
  • 61 Answers
SOURCE: engine runs but sputters after engaging blades
ck for water in carb bowl. also ck for filter in gas tank, or something in gas tank.
Posted on Sep 06, 2009
SOURCE: I have an 18 HP Craftsman tractor (model
The pump is not good,to test it,you take out the out fuel pipe start the engine ,see if fuel is coming out fully to the pipe,if sometimes it comes and cut,this means the fuel pump is not working properly.You have to change it.
Testimonial: "Thank you so much for you quick responses. My tractor is back up and running!"
  • 6468 Answers
SOURCE: I have A craftsman Model 917.273470 with a Kohler 20 Hp V-Twin. It will run if I spray gas in the carb. Drained old fuel, replaced fuel filter, checked gas flow into carb with pressure guage, Cleaned
check the solenoid on the bottom of the carb check for movement and power if it moves and has power open the carb and clean it
Posted on Apr 19, 2012
Why does my mower lose power after a few minutes mowing?
Pull the fuel line from the tank and check for a filter screen on the pickup..
Oct 30, 2014 | Toro Used 60" Z Master Professional 5000...
What to do? I have a craftsman GT 5000 with a 25 HP Kohler and it will run for about 10 minutes and then start cutting out and die. I have changed the fuel filter with no resolve. What should I look at...
Make sure the choke is coming off. Check the compression.Many times the head gasket may leak when the engine heats up. Also check for spark sometimes the magneto can heat up and quit after running a while. See if it will run if you prime with a little fuel, if so ,some of the Kohler engines this size have a fuel pump that could be failing. Check for vapor lock. It takes air and fuel properly mixed, spark and compression any of these missing the engine dies.
Aug 06, 2014 | Kohler Command Pro OHV Horizontal Engine...
My Kohler Command 20 HP running fine, shut down, won't restart. How should I troubleshoot this problem?
check for fuel try starting fluid if it fires on that then you have spark if it does not then you have a spark problem and seeing the command engine has two coils check the safety switches on the mower side
Aug 11, 2012 | Garden
My cub cadet won't stay running. I can mow for a will and it just sputters, and or dies. I let it cool off for about 10 minutes.It starts right up after it cools. It also starts to smoke when it gets...
Similar issue - buddies CubCadet with Kohler Courage 22 would not stay running. Turned out the coils got rusty where it interacts with flywheel. cleaned the contacts (be careful to shim for proper spacing) and ran like a top.
May 29, 2010 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
CH25 Kohler on a Kees mower. Back fires under light loads
you must have the throttle at full at all times when under load driving and mowing, back fire is do to much fuel. if your running throttle at full than look at the carburetor and then the wiring (short)
Oct 12, 2009 | Garden
15 hp kohler starts runs but when put load on it dosnt have enough power to mow help
oil pump maybe going bad throwing timing out a bit,this would cause a governer malfunction keep pushing it the timing belt will fail that's if this engine is similar to the triad 16 hp horizontal shaft,not sure about vertical
Jul 10, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Powermax water pump shuts off after 5 min or more
Either the coil/HEI module is bad or your on/off switch(kill switch) is bad. Check those first.
May 19, 2009 | Powermax XP650WP Portable 3' Water Pump...
Engine coughs and stops after about 15 min. of cutting
Apr 25, 2009 | Garden
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
