Question about Smith Corona Office Equipment & Supplies
Smith Corona XD5600 printwheel types wrong letters?
Typed beautifully and then something happened with the margin while typing in memory mode so I adjusted the margin. Perhaps I hit something? I tried changing printwheels, everything clicks in place. I just purchased machine so I don't have another ribbon yet, they are on order. While typing all my forms 125 carbonless forms, I used memory and no correction tape. but I put one in to see if that would help. I'm lost but need my machine. It stars out with correct letters but once you keep typing maybe 10 characters later, it types what ever and then sometimes I noticed it looks like the strike bar is hitting because I tried to type without printwheel and the saw the image of what was made. The wheel spins beautifully when inserted and when the lid closes. Now this machine I was told was not used for 10 years, but its clean and pretty.
JUSTOLDJIM
  • 478 Answers
SOURCE: not typing correct letters
Send it back for repairs if under warranty. This is not an office machine it is designed for very light home use.
Posted on Mar 10, 2008
JUSTOLDJIM
  • 478 Answers
SOURCE: No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Posted on Nov 06, 2008
faxman789
  • 297 Answers
SOURCE: Wordsmith 100 Wrong character typed.
Your keyboard assembly needs to be replaced.
Posted on Jan 15, 2009
  • 3594 Answers
SOURCE: Nakajima AE830 is not typing the correct letter
I just ran across this one. The pitch selector on the L. side of the keyboard may be in the PS position or just gotten dirty, slide it up and down a few times leave it at 10 or 12 and try it.
DickyO
Posted on Nov 09, 2009
  • 3594 Answers
SOURCE: when typing, the letters are
The problem may be the ribbon or the media you are typing on. try typing on a mulit part form, if the copies are good then its the ribbon (OLD) or the paper (GLOSSY).
DickyO
Posted on May 06, 2011
My smith corona sl 570 is not printing the letters c,v, b and n in both lower case and upper case. how can i fix this?
You have a key board problem. It may just need disassembly and cleaning but more likely it needs a new contact velum.
DickyO
Jan 03, 2014 | Smith Corona Wordsmith 100 Typewriter
How do you change the language on a smith corona typewriter 345dle
It sounds like the printwheel isn't honing. You most likely need a tech
Sep 09, 2012 | Office Equipment & Supplies
My Smith corona typewriter types the wrong characters.
Check to see if you are in KBII or a language mode if not look for bent or broken spokes on the printwheel.
DickyO
Apr 06, 2012 | Smith Corona Wordsmith 200 Typewriter
Not all of the letters will print lower case
Printwheel in wrong. release the printwheel, make sure the pin is aligned with the slot on the hub and snap it back in. The printwheel should spin, then home out to the left margin, then it should be ok. If not try it again.Check to make sure no pedals on the printwheel are bent.
Hopes this helps!
Feb 11, 2011 | Smith Corona Office Equipment & Supplies
My smith corona model ka11 is typing symbols instead of the letters. Can you help me get this corrected?
Hopes this helps!
Feb 10, 2011 | Smith Corona Wordsmith 100 Typewriter
Doesn't type correctly. I may be pushing a G and it will type K
Hopes this helps!
Feb 02, 2011 | Smith Corona Wordsmith 200 Typewriter
I have a XD 4800. it will not type the correct
Perhaps the printwheel is in backwards the letters must face the paper.
DiclyO
Feb 21, 2010 | Smith Corona Office Equipment & Supplies
How to change the pitch?
Here ya go...
Margins and Tabs
Margins and tabs for both Type Mode and Mem Mode are set in Type
Mode, but can be changed in Mem Mode when text is recalled for
editing. Margins and tabs are set using the typing scale which appears
on the display in Type Mode. A blinking cursor indicates the typing
position. The letter “L” indicates your left margin setting. The letter “R”
indicates your right margin setting.
NOTE: In Mem Mode, the margins and tabs used when the text
is created will be saved with the text and recalled with it,
even if they have been changed.
Margins
In Type Mode, to signal that you are near the right margin, the
typewriter will beep 5 spaces before the margin. In Mem Mode, the text
will wrap automatically when you print.
Margins are preset depending on the pitch setting, which is the number
of characters per inch. They are:
10 Pitch 12 Pitch 15 Pitch
(Pica) (Elite) (Micro)
Left Margin 12 14 18
Right Margin 72 86 108
New margin settings remain until changed again.
1. Move the Mode Selector to Type. A typing scale appears on
the display.
2. Move the cursor using the Spacebar or Back Space to the desired left
margin setting on the scale.
3. Press Margin.
4. Move the cursor using the Spacebar to the desired right margin
setting on the typing scale.
5. Press Code + Margin. A beep confirms each new margin setting.
6. You can change to Mem Mode, if desired.
Take care,
Duane ONeil
www.fjaproducts.com
800-982-9989
Jun 02, 2009 | Office Equipment & Supplies
When I type some of the letters are appearing with double lines. what is wrong?
Hi;
If you are getting to small vertical lines instead of the character then the printwheel might be bad. All the spokes on the printwheel should be evenly spaced and not bent or deformed.
Andrew
Mar 06, 2009 | Smith Corona Wordsmith 100 Typewriter
139 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Jim Goldsmith
Jim Goldsmith
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
