How do i get to paper jam inside machine when i can not see paper
I tried to un jam paper from back and it tore now i can not see paper
  • Brad Brown Apr 24, 2015
    Hi Melody Tyson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What make and model
  • 3,320 Answers
What printer?
Posted on Apr 24, 2015
SOURCE: paper jam, open back cover, then remove paper jam
Remove the paper tray. Check that the paper length adjustment is set correctly for the paper you are using. It's the small blue dam at the center 'back' of the paper tray.
Posted on Jun 25, 2008
SOURCE: MX 310 paper jam
i have the same problem
Posted on Oct 21, 2008
solofixya
  • 34 Answers
SOURCE: Canon PC 1060 has a paper jam that we can't get to
It sounds like the paper jam is in the fixing assembly, and you can not access it unless you take it to a service center for canon products.
Posted on Nov 10, 2008
idriss47
  • 26 Answers
SOURCE: Paper Jam light on, but no paper jam
A piece of paper torn from copy paper is caught around registration switch, exit switch or feedshift switch.
so check theme.
Posted on Jan 20, 2009
SOURCE: Document Jam
Follow the advice from Guest above
Posted on Feb 03, 2009
Xerox phaser 6120 paper jam
HI,
Simply open up the back end of the printer (Not where you insert the ink cartridge).
There should be some kind of a switch of lever or get a pair of needle nose pliers or some tweezer and carefully remove the paper if you can grab it.
Goodluck,
Please don't forget to rate the solution.
Apr 04, 2008 | Office Equipment & Supplies
My D320 Cannon photocopier has a paper jam. I do not seem to be able to open the machine to get the paper out. I tore off a piece trying to get at it. Now the remainder is stick deep inside the machine, ...
I can help you get the paper out of your machine. First thing to do is remove all of the paper from it and take out the paper tray too. Then press the "enter" button on the front of the print. This will rotate the piece of paper forward towards you. Try your best to grab it before the rollers rotate it backwards again. Sometimes it helps to have someone pick up the printer and point it towards the ground while you press the enter key. Gravite can help the paper to fall out of the machine.
Hope this helps?
Apr 22, 2011 | Office Equipment & Supplies
The paper had jammed when i was printing, i removed the jammed paper and tried printing again. however, the display on the printer shows paper jammed. what now?
You may have left behind a tiny piece of paper that tore off your sheet as you removed it. Make sure that you have all of the jammed paper and look carefully for any remnants inside. Look to see if the printer did not pick up a second sheet that is still in the system somewhere.
Jan 25, 2011 | Canon PIXMA MX310 All-In-One Printer
Paper jams too often and for no apparent reason. This time tore paper and therefore unable to unjam!
To clear the paper jams always follow the instructions from the manufacturer, here is the support page from Brother website.
Also, sometimes when I get paper torn inside, I use a pair of long-nose pliers to remove it, but be careful not to damage any parts inside the printer.
If the printer is jamming constantly then that means you have a hardware issue in there. Look carefully where is usually jamming and see if you have a clip that stops the paper or a roller that's not pulling the paper and try to fix it or replace the faulty part.
Dec 02, 2010 | Brother HL-2040 Laser Printer
My MX310 got a paper jam and when i pulled the paper out a small piece of the corner tore off and is still stuck in the printer. The printer now continues to claim there is a paper jam but i cant visually...
Remove the paper following the procedure below.
(1) Slowly pull the paper out, either from the Rear Tray or from the Paper Output Slot, whichever is easier.
If the paper tears and a piece remains inside the machine, turn the machine off, open the Scanning Unit (Printer Cover) and remove it.
Be careful not to touch the components inside the machine.
After removing all paper, close the Scanning Unit (Printer Cover), and turn it back on.
If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
(2) Reload the paper in the machine, and press the OK button on the machine.
Jun 05, 2009 | Canon MX310 Office All-In-One Printer
Error Message - Paper Jam
I had a paper jam. I removed the offending sheet of paper which unfortunately tore into 4 pieces as it came out. Upon piecing the sheet of paper back together - there is a small piece missing. I've checked the printer thoroughly - nothing can be found!
Feb 25, 2009 | HP Officejet Pro L7680 All-In-One Printer
Small piece of paper caught inside printer
Here you will find a video and step by step instructions for clearing paper jams for your printer. Hope this helps. Please remember to rate this information.
Thanks
Nov 15, 2008 | HP Photosmart C6180 All-In-One InkJet...
MP390 paper Jam
check the bottom part see if you can open.
Jul 08, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Getting into my hp 3210 all in one printer for a bad paper jam
you better send it to some profession as you may not be good in opening in printer and when trying to open you may damage the parts
May 12, 2008 | HP Photosmart 3210 Printer
jasbo
jasbo
