Question about Callaway Golf LR 550 Laser Rangefinder
How can I get a replacement battery chanber cover?
Sounds like water is sloshing around behind the dash
possibly is
at the bottom of the windscreen there is a plenum chamber that collects the water from the screen and drains it out via a tube either side into the front wheel wells
these drains can block up from leaves , dirt or rust and that will then retain water in the chamber giving you the sloshing noise as you drive
the chanber is where you normally get fresh air into the vehicle when you open up the fresh air control
Feb 10, 2017 | Cars & Trucks
Why did i loose compresion on my 2001 suzuki grand vitara 2.5liter when all i did was change valve cover gaskets and spark plugs? Now there is no compression? I'm really confused
7 posts and all great answers ignored. (a new record that 7 posts)
post the compression on all 5 cyliners
post the hard numbers, !
and do it with the :
  1. throttle blocked open
  2. battery charged
  3. all spark plugs removed for max RPM and full pressure.
150PSI or more, mine does 180 easy/ H25 is mine too.
you messed up the CMP sensor then did compression wrong.
so.... do it right. this time.
i bet:
spark is dead.
or timing way off due to CMP fiddling. or its connector is not on right.
or blew fuse, due to skipping step 1 in the FSM book, for VC gasket change outs. (factory service manual , read it yet? )
step 1: pull battery neg lug, first.
Mar 27, 2015 | 2001 Suzuki Grand Vitara
My Keurig coffee maker will not pump water into the chamber, I have tried the fixit suggestions but to no aavail. Machine was used less than 6 months.
Take the K-cup insert out.
Insert a small paperclip and carefully insert upward into exit needle, swirl to dislodge debris (clog could be preventing H2O uptake).
Do this for all three of the holes in the exit needle.
Add distilled white vinegar to reservoir.
Run "Brew" without a KCup to see if this clears the reservoir uptake and exit needle.
Fill reservoir with water and run to clear vinegar from system.
Mar 13, 2014 | Keurig B60 Coffee Maker
Where has the replacement battery CR1620 must be placed?
1) Open the main battery compartment
2) Remove the battery tray
3) Inside the battery compartment directly behind the LCD screen there is a small cover about the same size as the CR1620.
4) Remove the cover
5) Replace the battery
6) Replace the cover
7) Replace the battery tray
Jul 20, 2012 | Polaroid Battery Grip for Canon EOS-7D...
How do i replace the battery in the garmin streetpilot c330
Follow these steps : 1. Determine that you do have a Garmin GPS with a replaceable battery. Find the information by checking the manual or with a close inspection of the back and sides of the GPS unit. GPS units that have a battery that can be replaced by the owner will have a battery cover lock on the back or side; it looks like a small sliding piece of plastic with slots or ridges.
2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
May 16, 2011 | GPS
Where the hell is the water pump on my 94 jetta??? i need to replace the thermostat and apparently the housing is under the water pump... im not an idiot by far but VW has the worst designs ever!
The engines fliud containers are situated within from section. For example, the most observable fiuld compartment in engine is antifreeze chanber from where every tube connections derives fliuds for circulatiion. Observ within the engine, trance through the fluid tubes until arriving at pump very observable in features unique from fiuld containers.
Feb 10, 2011 | 1994 Volkswagen Jetta
Sigma EF-430ST not working
This indictates one of 2 condition.
1. Batteries Flat
2. Information Fault.
More than likely the second is your issue.
if you here a whirring sound when the flash starts then your fault is possibly that the inner head in the flash can not move in it chamber to adjust for the focal length of the lens.
You need to remove the 10 screws (5 each side on the head) 1 is located at the front and 4 under the plastic cover at the swivel point of the flash. These are covers are held in by twin sided tape and can be pulled off.
Now in front of the circuit board is a motor and gear - just in front f this is the flash tuble and the chanber - click the tuble back into the chamber and ensure it moves freely.
You can check that all is working now by installing the batteries and turning the unit on - should settle at 28.
Once working reassemble and all should be fine.
Jan 28, 2009 | Sigma EF-430 for Minolta Flash
How toreplace rear main seal in 92 F150 4.9 inline 6
One thing you may want to try especially if you don't have a heated garage is a bottle of Bar's leak rear main sealer. I had a leak big enough to cause my clutch to slip and it worked for me. I figure in the spring I'll replace the seal, maybe.
Oct 04, 2008 | 1992 Ford F150 SuperCab
Heater core replacement of 1995 ford f 150
If your truck has air conditioning you drain the radiator and disconnect the heater hoses on the right of the engine at the firewall.get in the cab on the passenger side and remove the grove box for better access than remove the seven screws that holds the cover on remove the vacuum source but leave the vacuum harness attached to the cover and remove the cover than remove the heater core from its chanber.Now all you have to do is put every thing back in place.
Steve
Sep 13, 2008 | 1994 Ford F150 Styleside Supercab
Callaway Golf LR 550 Laser Rangefinder Logo
624 people viewed this question
Top Callaway Golf Photography Experts
Tony
Are you a Callaway Golf Photography Expert? Answer questions, earn points and help others
