Question about Pool & Spa
The pump kicks in but the heater not fireing up
  • 1,631 Answers
  • Which heater?
  • Make and Model?
  • Natural Gas or Liquid Propane?
  • Electronic or Milivolt?
  • Indoor or Outdoor Installation?
Is there power to heater if Electronic?
Is there a standing Pilot if Milivolt?
Posted on Apr 26, 2015
Have a sovereign hot springs spa purchased in 2000. When turning the jets on it kicks the breaker. Also, the inside control system is not working anymore. Could our friendly electrician do this easily,...
When spas turn on initially they run through a purge cycle. This when the pump runs for a few minutes to remove any air in the heating system so the heater does not dry fire.
If your system runs through the start up cycle just fine but kicks the breaker when the heater starts then the heating element is bad and needs to be replaced.
Rod
US Parts Center
888-521-6183
Mar 18, 2013 | Pool & Spa
Hi, I have an LXi heaterthat keeps kicking off! On
This usually indicates an ignition lockout...The heater tried to fire but either didn't fire or a flame was not detected. Check and ,ake sure ignition is good, gas valve is opening and make sure all grounding is intact..
Jul 30, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pump starts runs for five seconds and then kicks off will not fire
If you have never checked/changed your filter or checked the pump pressure that is where your problem is. I have a tip which will guide you through the process at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters Let me know if you need any more help. I would advise getting the pressure gauge they have for setting the pump pressure.
hardrocko
Thanks for using FixYa
Feb 20, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater not firing
Take air preassure from an air hose to turn the fan blades to loosen everything up. Time for afull service, like change the vanes in the pump, 3- filters fuel--2 air.
Dec 15, 2009 | Reddy HEATER RH125T 125,000-BTU...
Jandy Lite2 Pool heater will not stay lit after firing.
Look at the sensor that tells unit that everything is lit. There should be some sort of sensor that tells the ECU that the ingnition area is a burn temp. It sounds like the unit can't tell that flame is lit. Hope this helps.
May 17, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
Heater fires but does not produce heat
wow - sounds like the gas valve is opening without the electronic ignition not kicking in. Here is a link to the Mfg site so you can download the trouble shooting guide.
Jan 24, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Laars boiler
i'm having the same problem. I thought it was due to having to put some non-detergent oil in the siphon loop, but that doesn't work either....i'm still having the same problem...will not kick on!!!!
May 04, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heater won't fire
Not knowing what kind of heater you are trying to fix, lets look at the basics. Fuel, Ignition and Oxygen. You say you have fuel and spark, how about air? Too much fuel will not allow the unit to fire as well. Have you checked the fuel filter if there is one?
Nov 17, 2007 | Heating & Cooling
Pool & Spa Logo
63 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
