Question about Sewing Machines
How to wind a bobbin on a touch and sew 649 - Sewing Machines
  • Sewing Machines Master
  • 1,860 Answers
Here are 2 link to click on for a manual, the manual should show how to wind a bobbin,, one of the links also has some part with it
Singer 649 Instruction Manual
Singer 649 Parts
Posted on Jun 03, 2015
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Posted on Dec 23, 2007
SOURCE: Elna 6003Q Sewing Machine won't snap out of bobbin winding mode
I had the same problem and fixed it myself. Remove the portion of the housing that coincides with the bobbin winder. You will need to remove two screws to do this--one is just to the upper left of the bobbin winder itself, and one is hidden under the handle on the left side of the machine (lift the handle, and look on the machine on the left side.) It takes some coaxing to remove the housing, but it can be done--be gentle. If you need to, remove the housing on the left side of the machine that covers the needle assembly. This will make it a bit easier, but still, be gentle.)
After removing the housing, you will see a black metal piece with a elongated slot and a screw adjacent to the bobbin winder mechanism. Unscrew the screw a turn or two, and slide the piece to the other side. Tighten gently. Turn your machine on, and move your bobbin winder back and forth and watch the screen change from bobbin winding to the main straight stitch screen. Now, do a brief Dance of Joy. I hope this helps.
Posted on Jan 23, 2009
SOURCE: can't wind bobbin kenmore 16221 sewing machine, no manual
On the right side of the machine there is a large knob at the top. Pull that out and you can wind your bobbin. Don't forget to push it back in so you can sew :)
Posted on May 02, 2009
  • 3 Answers
SOURCE: Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
The winding sound is the rubber O-ring against the spinning pulley (back of hand wheel) - do not let this continue, it will wear out the O-ring.
I had the same problem and I found the shaft bushing of the winder dry and needed lubed. Use oil or spray lithium grease and it should work fine. Spin the bobbin shaft by hand (not the hand wheel) to get it freed up after oiling.
You can oil from the top and should take off the side case to clean the excess oil from the O-ring. The shaft bushing is a tight fit and any dry oil will get sticky and prevent winding.
Posted on Nov 05, 2010
SOURCE: how to thread the bobbin on a singer touch and sew model # 625
how to wind the bobbin of the singer touch and sew model 625
Posted on Jul 26, 2011
I'm trying to load my bobbin on my singer 628 and the bobbin doesn't wind. Any ideas?
Anon, Found links to help with bobbin does not wind, make sure to read the articles in the forums, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://ca.answers.yahoo.com/question/index?qid=20070630202938AAGRwx2
Singer 628 Touch and Sew sewing machine manual smm043 Machines name begins...
Thread Singer 628 Touch and Sew Questions
Apr 05, 2016 | Singer Sewing Machines
Winding bobbin athena 2000
I had one of these machines, they're Touch and Sew, and the bobbin winds in place. Check to make sure you actually have the correct bobbin inserted, because the bobbin it uses is available with a metal center post and without a center post, and yours takes the one without. I had another machine that took the center post one and accidentally put the wrong one in the 2000 one day and had the same problem.
Jul 10, 2014 | Singer Sewing Machines
Singer golden touch and sew model 630
This series of machines was nicknamed "touch and swear" and "sew and throw", as well as other, less polite, names, because the bobbin winding system is so touchy. Try a couple of new bobbins, and if that doesn't work, consult the nice folks at the yahoo group "wefixit": https://groups.yahoo.com/neo/groups/wefixit/info Most of the time, though, a new bobbin fixes this particular issue.
Jan 01, 2014 | Singer Sewing Machines
I only want to know if the wheel must be loosened to wind the bobbin and if so with direction, to the front or backwards and press and turn or pull and turn.thanks
Which make and model sewing machine do you have?
None of my sewing machines need the wheel to be loosened for bobbin winding. The Singer Touch & Sew bobbins are filled in place. Use the handwheel to get the needle into the highest position (just turn the wheel). Wrap the top thread around the screw that holds the presser foot; open the slide plate part way and press the bobbin wind button. Hold the top thread and then begin winding by stepping on the foot pedal.. The thread should break after a few winds.
The Kenmore and the Husqvarna Vikings both get wound at the top. Place bobbin on winding pin. With the needle up and metal presser foot in place thread the top thread up to the bobbin (through the guides) and up through the hole in the bobbin. Slide the bobbin winding switch over towards the bobbin. Hold the thread tightly and begin winding (step on the foot control). After a few winds are on the bobbin, cut the thread that you were holding flush with the top of the bobbin. Continue winding the bobbin. (The newest Viking in the group has a computer screen; on that one, do not press OK until done winding the bobbin.)
However, if the handwheel is not turning and the needle is down, first find out why it isn't turning properly. This could indicate a tangle of thread somewhere in the system. (The older Husqvarna sewing machine in my home has a non-functional handwheel. The machine will still sew but you have to use the needle up/down switch that forces the needle to stop in the up position before you run out of bobbin.)
Please add a comment with the specifics of your sewing machine and I'll be glad to add additional information.
I hope this helps.
Feb 28, 2012 | Sewing Machines
How to wind the bobbin on the singer creative touch 1030
on touch and sew models thread the machine up as normal, select straight stitch, presser foot up, take the thread from the needle and wind it round the presser foot screw a few times, open the slide plate, push the little button over, press gently on the foot control to wind the bobbin, when finished close the slide plate to drop the winder down and pull the threads to the back and start sewing
Sep 04, 2011 | Singer Sewing Machines
We have a Touch & Sew 640 that we ARE trying to get running, and we need a manual, and specifically how do w thread the bobbin.
To wind the bobbin, select straight stitch, thread the machine up as normal making sure the presser foot is up, open the slide plate, push the little button over to raise the winder, take the thread and wind it round the presser foot screw a few times, press on the foot control slowly and the bobbin will wind, when you have enough, stop, close the slide plate to drop the winder down, pull the threads to the back and start sewing. for manuals try www.tandtrepair.com
Jun 24, 2010 | Singer Touch Sew 7462 Mechanical Sewing...
I have a Singer Touch N Sew Model 636. The
I had a Golden Touch 'N Sew many years ago and as the machine aged and parts became worn, step 4 of this bobbin winding diagram started to become a problem and I had to sometimes try several times before the "tabs" would release. If they did not release, the machine "thought" it was still winding the bobbin and would not sew.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_2001_touch_tronic_threading_diagram.htm
Mar 06, 2010 | Singer Sewing Machines
Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Jun 21, 2009 | Singer 7442 Mechanical Sewing Machine
How to thread the bobbin on a singer touch and sew model # 625
Jun 13, 2009 | Singer Sewing Machines
Bobbin won't wind
Dec 23, 2007 | Sewing Machines
Sewing Machines Logo
174 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
