Question about Whirlpool Dishwashers
Whirlpool ADG 8296 error code E1 F8
Dear all, The Dishwasher announces E1 F8 error, but filters clean, drain pump works excellently, drain tube clear without any stuck in it. The water after the short cycle is drain away. The most probable reason of this error is inoperative sensor. Did anybody came into this situation? Is this reason real? Thank you Carolina
  • Whirlpool Master
  • 2,963 Answers
Check with one of the online "appliance parts" stores. Most likely they know the answer and can help with the part and it's replacement.
Posted on May 04, 2015
  • 641 Answers
SOURCE: Water Will not Drain
It could be cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine,but if you will open the rear panel you will find it easily. Clear tube from any obstruction. Good luck !
Posted on Jul 27, 2007
IrishDruid
  • 2712 Answers
SOURCE: Candy CDI1012 Integrated dishwasher. When I
Hello mm1973,
It could be because of bad door latch switches / blown thermal fuse / blown or oversensitive control board. In all these scenarios, a dismantling of the machine is required. If you have no prior experience, I'd recommend getting a professional to diagnose/service it.
Try these checks too:
  • Check water level when the fill cycle has completed. Should be just under the heating element. If not, you may need to replace the water inlet valve.
  • Check the water temperature. Should be 125 to 140°F.
  • Check pump re-circulation. Listen: does it sound like it’s spraying the water around with enough pressure?
  • Check the spray arm and pump cover for splits or leaks.
  • Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  • Make sure the dishes are loaded properly, or dishwasher is not overloaded.
Hope that helps!
Posted on May 11, 2008
  • 64 Answers
SOURCE: Whirlpool dishwasher 2966 draining failure
take the airgap apart. located on top of sink. clean out and reassemble.
Posted on Aug 26, 2009
SOURCE: Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Posted on May 29, 2010
SOURCE: whirlpool dishwasher ADG 7550. Starts
high i have the adg7550 and the beeping again and again is the water sensor inside the left hand side.apparentley taking the plug off and cleaning contacts solves the problem this did work for me twice but now its being a pig.hope this helps.
Posted on Oct 21, 2010
I have error codes E1 and F9 on my whirlpool duet washer
Duet washers use F/XX codes. I couldn't find E1 but the F/09 code is set by an overflow. To eliminate the code:
- Check for clogged/kinked drain hose
- Check wire harness connectors for pump, pressure switch, and CCU
- Check/clean pump filter
- Check inlet valve for complete shut off
- Check for pump failure
- Check pressure switch operation
Dec 13, 2016 | Whirlpool Washing Machines
Looking for answer to error code F5 on Whirlpool Dishwasher ADG 8200
Fault Code F5 or Five Flashes
Cause: Spray arms are blocked/clogged or otherwise malfunctioning.
Action: Spray arms are easily removed so take them out of the dishwasher and wash in the sink to clear out any gunk (using descaler should help shift any stubborn debris). Whilst doing this run the dishwasher on a short program without the spray arms to clear any further blockages.
Jul 14, 2016 | Whirlpool ADG8200 Dishwasher
Getting error E1 checked all as per manual but still getting it
Whirlpool dishwasher F4 F8 FA error code ... - YouTube
? 1:57
www.youtube.com/watch?v=RfeFTdSdNYQ
May 27, 2012 - Uploaded by ukanfixit Although the Whirlpool dishwasher F4 error code is "not draining" it is actually a .... switch situated? my Whirlpool showsE1 and F8 error codes.
Aug 24, 2015 | Whirlpool Dishwashers
Whirlpool dishwasher ADG 7800 manual
Spray pump bearing ... replace main spray pump
Aug 30, 2014 | Dishwashers
How to reset Whirlpool dishwasher ADP 6342; it stopped working and cancel button is blinking 8 times
F8 failure (slow/no draining)
In a consumer cycle, the appliance is indicating F8 E1 (slow/no draining). This is because of wrong signals from the circulation pump read by the control board and interpreted as "water present", when there is no water. During draining (and in fact, there is no water), the failure occurs.
1. Check if drain hose is not closed/clogged
2. Drain pump faulty, harness or wiring faulty, control board faulty
3. If machine is equipped with OWl, issue might be caused by damaged or dirty OWl. Clean the sensor lenses then , if issue is not solved, replace OWI (optical water indicator).
Dado
Jun 14, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher F8 E1 error
You have a blockage in the drain line someplace. If you have a garbage disposer, check to see that it is clear where the dishwasher connects to it. Also check and make sure that the drain hose is higher then the inlet to the disposer to prevent water draining back into the drain line from the disposer. If that's clear you have a blockage somewhere in the drainline. Best to unit from cabinet and check it
Apr 05, 2014 | Whirlpool Dishwashers
Whirlpool dishwasher adg 642 not working start light flashhin 4 times
Hello Faye,
The F4 error code is a drainage error and it means that the control board did not detect a drop in the water level in the tub so it thinks it didnt drain.
The things that could cause this are a clooged filter on the pump asm, a blockage in the drain pump or hose or even a defective control board if in fact all the water has seemed to drain out of the tub.This is how ya set the diagnostic test to clear the codes and see if it reoccurs
  • Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
  • Open the door and set the program to the first program. (Normally rinse).
  • Turn the power off.
  • Press and hold the start button and while holding turn the power on.
  • After a little while the start button will flash, release the button.
  • Press the start button once and close the dishwasher door.
  • The machine will now run through a diagnostic routine.
  • Diagnostic takes about 20 mins.
  • The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the program.
  • To exit diagnostics at any time just press and hold the start button till the program is cancelled.
    GENE
  • Nov 05, 2011 | Whirlpool 24 in. ADG7540 Built-in...
    Whirlpool 7540 start light flashs 4 times
    The #4 error code on your dishwasher says it's a drainage error and that the computer didn't detect that all the water drained out of the machine. Sometimes that can be caused by a blocked filter on the pump, a blockage in the drain hose or a water level switch failure...also it can be just a electronic anomalie and the board can be reset then the dishwasher will work as normal. Or of course it could be because the filter is clogged and needs to be cleaned so water will flow through it and drain out.
    I have written tips both covering how to clean the pump filter and resetting the control board,refer to them and see if they will resolve your dishwasher troubles.
    TIP FOR CLEARING THE ERROR CODES FROM THE BOARD
    http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
    TIP TO CLEAN THE PUMP FILTER
    http://www1.fixya.com/support/r10292354-whirlpool_kitchenaid_kenmore_diswasher
    GENE
    Sep 28, 2011 | Whirlpool Dishwashers
    Drainage blocked on Whirlpool ADG 450 slimline inbuilt dishwasher, have taken out filter and cleaned it. Still blocked.
    two things to check
    if drain is plumbed nito a spigot on the sink trap, check that ther spigot and drain hose are not blocked - this is very common
    also see if you can get to the drain pump and check there is nothing jamming the impellor. also if you have access to a multimeter, check if the drain pump is powered up
    Sep 06, 2008 | Whirlpool Dishwashers
    Dishwashers Logo
    1,067 people viewed this question
    Top Whirlpool Dishwashers Experts
    Mike
    Owen Barnes
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
